New to Forum and Need Help with AMP Power Step on my 2019 SR
Discussion in '2.5 Gen Tundras (2014-2021)' started by cquilichini, Oct 26, 2018.
  1. Oct 26, 2018 at 5:32 PM
    cquilichini
    cquilichini [OP] New Member
    Hey Guys,
    I'm new here. I just purchased a new 2019 Black Tundra SR 4X4 and I'm really enjoying it.
    I just received my new AMP Research Power Steps and the shop installing them is having a really hard time figuring out the wiring on this new steps.
    AMP research have not installed the 75137 steps on any 2019 Tundra so I'm in uncharted territory and they cannot confirm the compatibility of the steps with my truck.
    I was wondering if anyone can confirm if the 2019 Tundra is basically the same as the 2018 MY.
    Any help or input is greatly appreciated.
    Thanks.
  2. Oct 26, 2018 at 5:47 PM
    boomer8
    boomer8 New Member
    Evan
    Cincinnati
    2018 Platinum
    Going to attempt to install my 2018 amps this weekend. I’m not sure if it will help or not but I will pass along any info I can.
  3. Oct 26, 2018 at 5:57 PM
    JDHolliday27
    JDHolliday27 New Member
    2018 CM
    1UPPER likes this.
  4. Oct 26, 2018 at 6:00 PM
    cquilichini
    Thanks guys. Any input is greatly appreciated.
  5. Oct 26, 2018 at 6:31 PM
    Welcome from NY.
  6. Oct 28, 2018 at 9:55 AM
    cquilichini
    AMP Research 75137 Power Step is confirmed to work on 2019 Tundra models. The shop I used made it work perfectly.
    Beesta likes this.
  7. Oct 28, 2018 at 10:03 AM
  8. Oct 28, 2018 at 10:07 AM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    They work on the 19’s. 18 and up requires you to tap into a certain wire under the dash next to the steering colum. Actually a very simple install
  9. Oct 28, 2018 at 10:54 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  10. Oct 28, 2018 at 11:43 AM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    18 & 19 is the same truck
  11. Oct 28, 2018 at 12:40 PM
    GlockTeam123
    GlockTeam123 New Member
    Johnson
    New Orleans
    The 19 tundra has different color wiring for the driver side top plug. It is not pink with red strip. The wire is red. Just installed AMP steps for my 19 Platinum.
  12. Oct 28, 2018 at 1:14 PM
    Welcome from Ohio!
  13. Oct 28, 2018 at 3:49 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
    cquilichini[OP] likes this.
  14. Oct 28, 2018 at 4:25 PM
    boomer8
    boomer8 New Member
    Evan
    Cincinnati
    2018 Platinum
    Welcome from Cincinnati!
    Installing my Amps next weekend!
  15. Sep 17, 2020 at 11:30 AM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    What model amps did you guys get and how do you like them
  16. Sep 18, 2020 at 1:04 PM
    cquilichini
    AMP Research 75137 Power Step, love it. the best upgrade i've done so far.
  17. Sep 18, 2020 at 1:21 PM
    sillydadztrksR4momz
    Thank you. I’m going to get a quote
  18. Sep 18, 2020 at 1:23 PM
    sillydadztrksR4momz
    Did you get the XL? Those are the ones I’m looking at since I have a 6” lift
  19. Sep 18, 2020 at 1:54 PM
    cquilichini
    mine are the regular ones. I don't have a lift.
  20. Sep 18, 2020 at 1:56 PM
    sillydadztrksR4momz
    Still
    Seems like a reliable brand. Thanks for reply
  21. May 23, 2022 at 8:20 PM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    2019 Super White 1794 Edition Tundra CrewMax 4x4
    3/2" Readylift, TRD Dual Exhaust, TRD Sway Bar, Line-X Bedliner, ArmorFlex Tonneau, ESP 3 bin storage, Amp Power-Steps, Driver Side Grab Handle, Ronin Antenna, Window Tint, ClearBra. Coming Soon: 20" Method MR305NV. BF Goodrich KO2 275/60/20
    Hi All, resurrecting this relatively old thread.
    I have a 2019 Tundra and am in the process of install the Amp Powersteps. I'm struggling to understand the wires I tap in to. The directions seem pretty vague about what wires to tap into.
    I think I've located the driver's side top red wire. I'm fairly certain on that one. I'm not sure on the driver's side lower wire. The directions and pictures are pretty confusing. Anyone have a video or more precise instructions on which wire to tap into down low?
    On the passenger side, I haven't even gotten their yet but I anticipate similar problems. Please help if you're able...
  22. May 23, 2022 at 10:33 PM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
  23. May 24, 2022 at 7:01 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Had the same question installing on my '17, called Amp Tech Support and they were very knowledgable.
  24. May 24, 2022 at 7:58 AM
    Long Duck Dink
    Long Duck Dink Nope
    North Salt Lake, UT
    Thanks! I think I have the wires picked out and will give it a try. If it doesn't work, I'll call Amp. Thanks for your help!
    The video posted above is a great video. However, that guys is working on a 2016 or 2017 and he doesn't show in detail the wires he picks out. He just tells you their colors and the colors changed in 2018 on the wires.
