New tires but now a light
Discussion in 'Wheels & Tires' started by mundra, Dec 5, 2019.
  1. Dec 5, 2019 at 6:09 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Does the display show the pressure in each tire?
  2. Dec 5, 2019 at 6:10 PM
    18" TRD Off Road Wheels
    I can't say for certain on a 2020, but my 2019 shows the pressure in each tire.
    Tchase[QUOTED] likes this.
  3. Dec 5, 2019 at 6:21 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Mine shows the same. I before Discount Tire fixed it, I had the dealer check it and they can't seem to reset it and reprogram it with their machine. The trucks TPMS computer just started reading the sensor after rotating it by 180. After I insisted for them to try it. Hold and behold, it's been working flawlessly, from 700 miles. I have 3100 miles now on the clock.
    OR18TRD likes this.
  4. Dec 5, 2019 at 6:21 PM
    mundra
    mundra [OP] New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    I’d rather have my Oem sensors in reality, truck only had 4000 miles on it. Yes my 2019 shows each tire pressure.
    OR18TRD likes this.
  5. Dec 5, 2019 at 6:45 PM
    SprinterAE86
    Ian
    1.) Ask @Roman for the part number for your Rock warrior tpms and the platinum tpms to see if it's the same pitch that it can be swapped out.
    2.) If it's the same part number, you can have it swapped out.
    I have steel wheels with 255.70.18 they dismounted my TPMS, installed it in the new wheel and new tires. They bought my tires for $180 too and price matched the online deals.
    The only reason I can say that they are charging you with $200, is for dismounting both of wheels, mounting and balancing both set of wheels and tires again with a new valve stem on each of them. They can do that and you really do not have a choice. But you can have them be accountable for a product that they sold you that did not work. Call corporate and have them fix it. Or even take it to a different Discount tire store. Each store is competing for your business even though they are all the same. I am confident that they will fix the TPMS sensor issues even if they have to dismount and remount the wheels several times.
    OR18TRD likes this.
  6. Dec 6, 2019 at 3:30 AM
    mundra
    2019 platinum 4x4
    I reset them again this morning. I pressed the button 3 times, tire icon started flashing, then went solid and stayed on. I checked on my drive and the dash is not recognizing them being in the tires.
  7. Dec 6, 2019 at 4:29 AM
    ScarWars
    ScarWars New Member
    2019 Toyota Tundra TRD PRO Super White
    I got some Nitto RG installed on my Tundra Pro 2 days ago. I bought the tires from Direct Tire but did not want them to install because I don’t trust them. Took mine to a reputable tire shop that does custom wheels. I paid a little more for them to do it but I don’t have any lights on and the didn’t scratch up my blk wheels. They just swapped my tpms sensors over but didn’t charge for the swap over. Hope you get it worked out.
    mundra[OP] likes this.
  8. Dec 6, 2019 at 6:39 AM
    mundra
    2019 platinum 4x4
    Appointment set to swap stock sensors back in today with credit back of other sensors. Really glad it’s being taking care of without a big deal being caused!!! I buy several vehicles tires from this discount tire location and referred my club to them as well.
    GODZILLA likes this.
  9. Dec 6, 2019 at 6:47 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Discount has never charged me to swap sensors.
    OR18TRD likes this.
  10. Dec 6, 2019 at 4:03 PM
    mundra
    2019 platinum 4x4
    Went to swap sensors. They were able to swap 3 of them but one tire was put on with the wrong long nut. Rock warriors use a different lug but so by the time they realized the wrong lug nuts was used they broke 2 lug nuts and now the tire/wheel won’t come off. I have to go to a different shop to see if they can get it off. I hope my RW wheels don’t get messed up. But at least discount is stepping up to as they should.
    OR18TRD and SprinterAE86 like this.
  11. Dec 6, 2019 at 4:23 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    can you imagine if the light never came on you would've never knew about the wrong lug nuts.
    OR18TRD, 14burrito and GODZILLA like this.
  12. Dec 6, 2019 at 5:00 PM
    mundra
    2019 platinum 4x4
    Yep, I knew last night but wasn’t sure how bad. I wasn’t aware my tire wasn’t able to be removed that’s for sure. Lol
  13. Dec 8, 2019 at 10:10 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Fingers crossed, but you may have given me the ammunition to get mine fixed. Thank you!:fistbump:
  14. Dec 8, 2019 at 10:15 AM
    sdde4n
    sdde4n New Member
    Sorry, I missed this. Where is the button to reset?
  15. Dec 8, 2019 at 10:39 AM
    mundra
    2019 platinum 4x4
    B
    Button on right hand side on front of lower dash panel
    sdde4n[QUOTED] likes this.
  16. Dec 8, 2019 at 11:52 AM
    It's under your steering wheel to the right a bit. If I am understanding correctly, this button doesn't do anything except reset the expected pressure for the monitoring system to what it is currently reading from the sensors. If your sensors are not linked/providing data this will not fix that. It's purpose would to recalibrate the dash if you were to switch to tires that had a different optimal pressure from the stock tires.
  17. Dec 8, 2019 at 11:58 AM
    sdde4n
    sdde4n New Member
    Makes sense. Thanks for the clarification.
  18. Dec 10, 2019 at 8:06 AM
    mundra
    2019 platinum 4x4
    Was able to get the 2 damaged studs out no damage to RW wheels! Now back to discount tire to have stock sensor installed. Currently running 3 but nothing g is showing on the dash for tire pressure on any of the 3 installed. Is this normal?
  19. Dec 10, 2019 at 8:08 AM
    #49
    Honestly, I wouldn't worry until they get them all installed and have a chance to sync them all up. At this point we already know you have patience! :laugh::thumbsup:
  20. Dec 10, 2019 at 9:42 AM
    #50
    mundra
    2019 platinum 4x4
    I try to have patience. I found out years ago once I loose my patience I get myself into situations I should not be in. Lol so I’ll wait and see.
    OR18TRD and GODZILLA like this.
  21. Dec 10, 2019 at 12:46 PM
    #51
    Tchase
    Tchase MostlyLurk
    Buckley WA
    In work
    Well I had a shit tire day yesterday less than 2k on the oem tires (no I'm not buying new ones until I run these down commuting). I've basically had good experience with Discount they may screw up but they always make it right. I went to the bank, then costco, hop in the truck my light is on, check the display back passenger is at 27 psi, then 26.. hop out sure enough I hear air. So I roll to discount to get it patched. 2 hours later I leave with a new tire and 174 bucks out of pocket :(
  22. Dec 10, 2019 at 1:06 PM
    #52
    mundra
    2019 platinum 4x4
    Stock tires are very thin. They are rated for crossover light truck
  23. Dec 10, 2019 at 1:16 PM
    #53
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I had a local guy swap sensors from my 18's into the 20's. 3 of the 4 came out. 1 ended up being seized and breaking, nothing the installer could do. Good ol' MN road corrosion.
    I said eff it and put rubber stems in. I put a piece of tape on my dash light to cover the indicator light. The 3 working OEM sensors are 11 years old. They'll probably crap out sooner than later anyways. Back to the dark days of manually checking tire pressure!
    OR18TRD likes this.
  24. Dec 10, 2019 at 2:28 PM
    #54
    mundra
    2019 platinum 4x4
    I agree. Now to go back one last time!!!
    OR18TRD[QUOTED] likes this.
  25. Dec 12, 2019 at 7:53 AM
    #55
    cmack
    cmack New Member
    AZ
    2018 Burrito
    Mine showed 3 on the dash with 0 PSI for the one discount broke for about a day. Then they all showed nothing and a message of just a malfunction is on the screen currently. Headed back to discount for my 3rd trip Saturday to see if they can finally get it right.
