New tires and wheels- need tpms help
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bergy24, Jun 7, 2022.
  1. Jun 7, 2022 at 9:13 PM
    Bergy24
    Bergy24 [OP] New Member
    2021 Cement Crewmax Limited TRD 4X4
    Sorry for the double post. Not getting any attention in wheels and tires.
    I have a 2021 Limited with push start.
    My OEM Valve stems/tpms look like normal rubber valve stems from the outside. (Snap in style)
    I just bought some PRO BBS Wheels and I believe they came off a 2019. These valve stems/TPMS also look like normal rubber valve stems from the outside. (snap in style)
    I plan to keep both sets of wheels and tires for now and would like TPMSoperational in both sets if possible.
    From all the reading I have done it appears the 20 and 21's have a different Frequency and will not allow the 2019 sensors to work.
    I have done a lot of reading on here and it seems there is a lot of confusion.
    I found that there are 2 different part numbers but not sure what I need
    42607-06030 Labeled "PMV-C015" on the sensor
    42607-0C091
    From what I can tell, the 42607-06030 is for the push to start but not 100% positive .
    According to my dealer, my vin shows that the 42607- 02050 sensors came with my truck from factory. They want $75 each plus $200 to install (mount/balance) and program the sensors. If I buy these sensors, can I register and calibrate them using the button inside my truck?
    Can anyone confirm what number I need to use?
    Will I be able to use this method to register and recalibrate the new sensors?
    If I go the aftermarket route, are the Autel Sensors and tool my best option and again, which one exactly do I need?
    Thanks for all the help with this.
  2. Jun 7, 2022 at 9:39 PM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Do you currently have TPMS on your dash? Go left twice on arrow menu, and down.
  3. Jun 7, 2022 at 9:42 PM
    Bergy24
    I’ll have to confirm tomorrow evening. I know I have a tpms button though
  4. Jun 7, 2022 at 9:45 PM
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    Your Limited should have came with TPMS. I highly doubt it came with rubber valve stems unless if it was swapped out prior or if you aren’t the 1st owner of your vehicle.
    The frequency between 19s and 21s are different and therefore you can only use OEM OR you can use AUTEL, but need a TS to relearn the sensors.
    Easiest way to swap to your BBS wheels is to take out your sensors from your Limited wheels.
  5. Jun 7, 2022 at 9:58 PM
    Bergy24
    I don’t want to swap sensors though. I want to use both sets and need new sensors. My limited does have the snap in style tpms from factory.
  6. Jun 8, 2022 at 4:50 AM
    TBS
    TBS New Member
    2021 SR5 CrewMax 4x4 Barcelona Red
    E50 extinguisher, Valhalla Plates, ESP Storage, Chrome Delete, Pwr Tailgate Lock,
    I installed the Autel MX sensors.
    https://www.amazon.com/Autel-MX-Sen...e-Monitoring/dp/B07X8HRZX7?pd_rd_i=B07X8HRZX7
    I cloned my original tires using the TS508. I think there are other programming models out there.
    BUT you do not have to clone like I did. I am told you can just install the new sensors and have your truck relearn.
    The Autel's are cheaper and you do not have to deal with which OEM's you have. I have a '21 but had the '19 sensors directly from the factory. Go figure.
    Bergy24[OP] likes this.
