New Taco Vs New Tundra
Discussion in '3rd Gen Tundras (2022+)' started by RookieEP, May 21, 2023.
  1. May 24, 2023 at 8:46 AM
    #61
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    incorrect, the hybrid is constantly assisting and regenerating while towing…. I see it happen every weekend
  2. May 24, 2023 at 8:52 AM
    #62
    mass-hole
    mass-hole New Member
    So you're off the throttle doing 70 mph on the freeway enough for it to regen a meaningful amount? Cause I almost never lift off the throttle on the freeway while towing, even on 5-6% grades, never mind need actual braking to keep my speed from increasing.
  3. May 24, 2023 at 9:24 AM
    #63
    spigatelli
    spigatelli New Member
    DFW, Texas
    2023 Limited Hybrid CrewMax 6.5 in Army Green
    My toy hauler is between 6 and 7,000 lbs depending on what I have loaded. I can see the hybrid kick in whenever I hit a hill. I guess it regens going down hill and charges from the alternator other times? I just know it pulls so well.
    I had a 4.6 Tundra before and it was so sad trying to pull up a hill. Great tuck, but not for towing.
  4. May 24, 2023 at 2:32 PM
    #64
    mass-hole
    How long does it kick in for? In the TFL video on the ike it kicked in until ~51mph and then shut off for the next 8 minutes and never contributed any power.
    Any TT 3.5L V6 is going to pull 10x better than a 4.6L. Even my old, outdated 2014 3.5 Ecoboost with a measly 420 ft-lbs absolutely smokes my GX460.
    DFS likes this.
  5. May 24, 2023 at 3:27 PM
    #65
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    No alternator on the hybrid, the electric motor charges the hybrid battery battery pack (and the 12 volt battery) when the vehicle is coasting or braking.
  6. May 24, 2023 at 4:59 PM
    #66
    737fixer
    737fixer New Member
    It's quite obvious the people who designed the new Tundra have all been fired or told to disappear when it came to input on the 2024 Tacoma. The new Tacoma does not have the absolute embarrassment of a front grill. The interior completely blows away the Tundra's. And what makes it a complete slap in the face to the Tundra is it will have the exact same Hybrid system which will give it 21 century MPG and very nice power for a midsize. Too bad they just couldn't make a full-size of the exact same truck.
  7. May 24, 2023 at 7:02 PM
    #67
    Will816
    Will816 New Member
    Will
    Idaho
    So all other design cues being similar to the Tundra, but a different grille (and literally just the grille), and you conclude that the designers were fired or silenced? Very unlikely. The interior is very similar to the Tundra's, just collapsed horizontally for the narrower truck (central vents under the screen instead of next to the screen, etc.). And finally, the exact same hybrid system? Dude, count the cylinders. Count the turbos. Compare the displacement. Compare the power figures from the electric motor, and from the overall gas/electric output. Count the transmission ratios. Compare the battery size. There's no standing to claim it's exactly the same. There's likely no significant shared components. Except possibly the spark plugs and oil cap.
    That being said, this is two years out from the new Tundra. Of course there will be "better" things. They've had two more years to take customer feedback into account. If the roles were reversed and the Taco came out for 2022 and the Tundra was coming out for 2024, you'd likely be able to say the same thing. The newer design is better. It has more recent feedback, tech, styling, etc.
    TweakedMang0 and Breathing Borla like this.
  8. May 24, 2023 at 7:21 PM
    #68
    nodak67
    nodak67 New Member
    JR
    after moving from a taco to a tundra and now looking at the 24 taco limited (since this trim matches the platinum trim the closet (which we have in our tundra) ...
    1. back seat is still abysmally small (this will be the #1 gripe on the taco if you had a tundra)
    2. the limited with all that chrome on the front makes the 1794 look tame
    3. the limited has all the same bells as the platinum trim if you ignore 1 & 2 (heated steering wheel was a big addition to the taco limited)
    4. the 12 way seats in the tundra still is better than the 10 way in the taco (the leg extension is a god send on long trips, once you had it, its hard to go back to 8 or 10 way seats)
    5. they finally resolved the seat literally sitting on the floor, they finally raised it to make a difference on the taco
    6. limited has hud standard
    7. tss 3.0 will be more annoying than the 2.5 in the current tundra (but i suspect the tundra a few MY down the road will get tss 3.0)
    8. would really miss the roll down window in the tundra
    9. the pano/moon roof in the taco makes the head room really fukking wonky if you are a tall person
    just my thoughts on our plat to limited observations if the wife decides to go back to a taco as we downsize after the dogs pass (no more pets after these i think)
  9. May 24, 2023 at 7:23 PM
    #69
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    I haven’t really watched many videos on the new Tacoma, but do most models have the digital display? That’s one thing I wish the limited tundra had standard.
  10. May 24, 2023 at 7:29 PM
    #70
    nodak67
    nodak67 New Member
    JR
    i know the limited does, and i think the trd pro and trail hunter also do.
    not sure on the trd sport
    sr > sr5 > trd sport > limited > trd pro > trail hunter
  11. May 24, 2023 at 7:36 PM
    #71
    trazerr
    trazerr New Member
    Oregon
    I’m pretty sure the sport manual TFL showed off had the digital display, but I didn’t really pay too close attention to that video.
    Edit: sport manual has the full digital display in their video. SR and SR5 probably don’t but everything above probably does. That’s my guess.
    nodak67[QUOTED] likes this.
  12. May 24, 2023 at 7:44 PM
    #72
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    LOL.
    As a guy who pulls freight for a living, at tonnages that make class 8 trucks look like toys, I can assure you that more horsepower is ALWAYS better. Period.
    I’m dealing with a 17,589 ton unit coal train right now (stopped waiting for signals to move), I have 3 locomotives totaling 13,100 HP. This train would be way way better with another 4300-4400HP 6 axle locomotive. Like night and day better.
    Black widow TRD likes this.
  13. May 24, 2023 at 8:48 PM
    #73
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    My cat love the space in the Tundra CrewMax :)
    22whatwedo likes this.
  14. May 24, 2023 at 8:51 PM
    #74
    Will816
    Will816 New Member
    Will
    Idaho
    I think your ">" should be "<" and you forgot TRD OR, which is likely between sport and Limited
  15. May 25, 2023 at 5:36 AM
    #75
    DexterL
    DexterL New Member
    Coasting and braking it regens, engine braking downhill charges the battery up fast. Ive had it running pure electric at 80+mph going down inclines with slight acceleration via the pedal.
    It really is an amazing driving experience in the hybrid. My bro is law has a non hybrid and driving them side by side he is always bummed with his choice
  16. May 25, 2023 at 5:47 AM
    #76
    shorenetworks
    shorenetworks New Member
    East coast California DBA New Jersey
    2023 Tundra self destruct edition
    Things I wish our trucks had
    1. Tow hooks
    2. Digital gauge cluster seems like all Tacos get it
    3. the rotary temp knobs
    4. in bed storage compartments
    5. dual tailgate buttons I totally thought that was a gimmick but I use it all the time
    I'm glad this wasn't out as I would have been inclined to pivot to a Taco but between towing and wanting to carry a sled or atv on my Diamondback cover I would be pushing that little 2.4 to the limit.
  17. May 25, 2023 at 6:52 AM
    #77
    Will816
    Will816 New Member
    Will
    Idaho
    Has digital gauge cluster across the lineup been confirmed? Usually promo material (like the interior shots we've seen) showcases the higher level trims and options, and so far I think we've only seen the interior for the Trail Hunter and TRD Pro, both of which are hybrids. All Tundras with the hybrid option have a digital cluster, it could follow the same for the Tacoma. I'd be highly surprised if the SR and SR5 had a digital cluster. I'd even be surprised if the TRD OR and Sport had them when paired with the non-hybrid 2.4
  18. May 25, 2023 at 6:57 AM
    #78
    shorenetworks
    The Sport non hybrid with the manual transmission that's had several videos has the digital cluster.
  19. May 25, 2023 at 7:04 AM
    #79
    Tibetan Nomad
    Tibetan Nomad New Member
    Coming from 7 years of owning a current gen Tacoma to recently getting 23 Tundra and when i saw the upcoming 24 Tacoma i felt 0 buyers remorse. :hattip:
  20. May 25, 2023 at 8:13 AM
    #80
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    While I've seen great payload numbers for the new Taco, I still wouldn't default to it for towing or hauling. Looks like it'll do well with the trendy "overlanding" (we used to call it car camping) crowd.
  21. May 25, 2023 at 10:51 AM
    #81
    Coal Dragger
    Kung Fu Dick
    Real world differences would be found on long steep grades. As you suggest at some point there would be a diminishing return if your tow vehicle is only rated to tow 7,000lbs. Once the tow vehicle can pull any grade you point it at with the trailer on the hitch, with enough power to maintain the posted speed limit plus say 5MPH over to allow you to safely pass slower moving traffic if needed then anything beyond that is probably not a “need” but more of a “want”.
    There’s also going to be a big difference in performance at high altitudes. If one of those engines is turbocharged and the other one is naturally aspirated the turbocharged engine is going to mop the floor with the naturally aspirated engine towing in the mountains. So you could see a 310HP turbocharged engine stomp on a 360HP naturally aspirated engine on the pull up to the Eisenhower Tunnel at 11,000ft above sea level, because the turbo engine is probably still pretty close to full rated power, and the naturally aspirated engine will be capable of only 241HP up there.
  22. May 25, 2023 at 11:38 AM
    #82
    Coal Dragger
    Kung Fu Dick
    What if you made the Tundra out of titanium alloy? Now that Tundra has a curb weight closer to 3000lbs. Does that mean it’s not a 1/2 anymore? The difference in payload between current 1/2 tons and these midsize trucks is miniscule.
    The market demand right now is to offer 1/2 ton and under trucks that are really just big all weather family sedans with a bed. Any more payload and ride becomes too truck like, and that is where 3/4 ton and 1 tons come into play… for people that actually need a truck to use hard.
    So unless some very cool new suspension technology comes out that is affordable to put into mass production there will not be a big difference in payload between a midsize truck and a 1/2 ton truck. Manufacturers are doing everything they can to make both options as versatile as possible while still riding well so families will buy them. As consumers we have a great choice now of just how big of a roughly 1/2 ton or maybe better termed non-heavy duty truck to buy. Need more space inside and a wider bed for bulky stuff like furniture, appliances, or other crap in that nominal 1300-1600lb payload all these trucks are playing in? Buy a full size, and it will tow a bit more. Need similar payload but need it to fit in narrower spaces, fit a smaller garage, get better mileage and still hauls weight in the bed? A midsize could be a great solution, and now it doesn’t have to be a penalty box to spend time in.
    I still maintain Toyota could do themselves and the North American market a favor and bring an HD Tundra. All the bitching about payload on the 1/2 ton Tundra would end practically overnight as Toyota faithful with bigger jobs could just go buy the 1 ton Tundra they really want, and stop jumping through their own asses trying to make a 1/2 ton do 3/4 ton and 1 ton shit.
  23. May 25, 2023 at 6:21 PM
    #83
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
  24. May 25, 2023 at 10:38 PM
    #84
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Idk…I think I want those seats.
  25. May 26, 2023 at 12:14 AM
    #85
    Coal Dragger
    Kung Fu Dick
    Those seats do look pretty baller, being honest with myself and how I use a truck they’d probably be overkill for my use. Not a lot of high speed off-roading to be had in my AO.
    iiawah808 likes this.
  26. May 26, 2023 at 12:59 AM
    #86
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Great idea and great concept.... However, given the number of folks that are flat out being told to basically pound sand when they try to get basic QC issues sorted out (hell even a second key fob), why would I want to pay extra for a seat that has even more parts that need proper assembly, maintenance and replacement??? Surprised they are not remote tuned via the app and require a monthly service fee to operate :D
    shorenetworks and Silver17 like this.
  27. May 26, 2023 at 1:54 PM
    #87
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    The Tacoma back seats fold down for a flat floor. Do the Tundra seats do this yet ?
    He said 95% of owners don't tow over 5000 lbs. Thats why the target is 6400 lbs.
    up to 1700 payload. I figure its going to be 1200 -1300 on most of them which is almost like the Tundra.
    The only thing it is missing is a roll down window. Decent power in the bed ac and dc.
    Seems to me with the videos I have seen that it is very focused on truck utility and they want it to remain the world class leader.
    The 6 foot bed is like a Goldilocks size.
    https://youtu.be/Fh-s9O3EgRs
    RookieEP[OP] and Tripleconpanna like this.
  28. May 26, 2023 at 2:42 PM
    #88
    Tripleconpanna
    Now that feature (fold down flat rear seats) is a game changer; especially for those of us w/dogs!!!!
    RookieEP[OP] likes this.
  29. May 26, 2023 at 2:57 PM
    #89
    Shamrock92
    Shamrock92 New Member
    IDk - but I think they may have something that would temp me out of my Tundra.
    Now the tricky part - do I sell the Tundra now while price is high - and wait for a Tacoma - or hold the Tundra and trade/sell when my allocation arrives ? Talked to local Toyota here - names on the list for a Tacoma Pro - we will see - unless this thing comes in at 65k plus sticker - it looks good.
  30. May 26, 2023 at 4:21 PM
    #90
    nodak67
    nodak67 New Member
    JR
    the problem with the seats is that it only gives at most 7% benefit. for the roi, its not really worth it and you can probably find better seats aftermarket.
