New Switch Pros 9100 Switch Panel!
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Jan 25, 2018.
  1. Jan 25, 2018 at 8:57 AM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    PRODUCT OVERVIEW:
    Features:
    • Eight user-programmable switches
    • Four 35A circuits and four 18A circuits, with over-current and short circuit protection
    • Waterproof, Solid State 125A Power Module
    • RGB Backlighting provides unlimited color options, using Color Picker on App
    • Daisy Chain up to 3 Switch Panels to One Power Module
    Switches can be programmed for:
    - On/Off or Momentary
    - Ignition or Battery Input
    - Flash or Strobe, with User-Selectable Strobe patterns and One Touch activation
    - Memory Function
    - Master Mode, with ability to turn multiple outputs On AND Off with one touch
    - Automatic Power-Up upon vehicle start up
    • Two External trigger inputs can each activate up to four outputs (Active Hi or Active Low)
    • Lighting outputs can dim from 100% to 10%, with ability to dim during Flash or Strobe patterns
    • Sleep Mode for minimal power consumption
    • Color Coded Output wires
    • 100 User-selectable switch legends
    • LED Input Status Indicators for easy troubleshooting
    • Time Delay Off function available for all circuits
    • Splash proof switch panel with Polycarbonate overlay faceplate
    • Program and control the system from switch panel pad or smart phone
    • Bluetooth interface with FREE Apple or Android App
    • Battery Voltage Readout on App screen
    • No Fuses or Bulky Relay box
    • Built-In Bluetooth Module
    Switch Panel Specs:
    • RGB Backlighting provides unlimited color options, allows for exact matching to factory dash lighting
    • Built-In Bezel Style Switch Panel enclosure measures 4” L x 2” W x .375” H ; includes concealed mounting hardware for factory-look installation
    • Orange LED switch indicators
    • 100 User-Selectable Legends
    Power Module Specs:
    • 8 Outputs: 4 rated @ 35A, 4 rated @ 18A
    • 125A maximum rating
    • Waterproof and Solid State
    • 6”L x 3”W x .5”H (excluding connectors)
    • Underhood rated 125°C to -40°C
    Kit also Includes:
    • 11’ of Communication Cable between Switch Panel and Power Module
    • Wire harness with Waterproof, sealed automotive grade connectors
    • Power Cable with 125A inline fuse
    http://store.sdhqoffroad.com/switchprossp91008-switchpanelpowersystem.aspx
    THESE ARE IN STOCK AND READY TO SHIP!
    Don't forget to check out our Tundra Switch Pro Mounts as well!
    Platinum and Limited Mounts - http://store.sdhqoffroad.com/14-currenttoyotatundrashifterpanelswitchpromount.aspx
    SR/SR5/Pro Mounts - http://store.sdhqoffroad.com/2014-currenttundrashifterpanelswitchpromount.aspx
    Under Hood Module Mount - http://store.sdhqoffroad.com/14-18tundraswitchprospowermodulemountingsystem.aspx
  2. Jan 25, 2018 at 9:22 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Joey, anyway we can get custom switch stickers for the SP system?
    831Tun likes this.
  3. Jan 25, 2018 at 10:02 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  4. Jan 25, 2018 at 10:51 AM
    sdhq_offroad
    GILBERT, AZ
    They do not do any custom stickers.
    dcsleeper408[QUOTED] likes this.
  5. Jan 25, 2018 at 10:52 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    SDHQ going to make some custom stickers..? :D
  6. Jan 25, 2018 at 2:01 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Got mine! Should be installed soon :bananadance:
  7. Jan 26, 2018 at 5:13 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    What’s new on the 9100 compared to the 8100? Do you have a list of the new features? I’m not familiar with either.
    Also is there a wigwag mode?
    Eclipsed & Floating likes this.
  8. Jan 27, 2018 at 7:41 AM
    sdhq_offroad
    GILBERT, AZ
    The biggest difference is the 9100 has higher amperage circuits. 4 35A and 4 25A compared to the 8100's that were 7 18A and 1 30A circuit. This allows you to run the bigger bars without having to do in-line relays and what not.
    - The master switch in the 9100's will be a master on AND master off. The 8100's was only a master on.
    - The 9100 allows you to dim lights from 100% down to 10% and the ability to dim lights while flashing/strobing.
    The 9100 also has a RGB keypad backlighting so that you can fine tune the color to your interior. The 8100 series were only offered in green, blue, and red.
    There is no wigwag mode built into these.
    dcsleeper408 and BlueBottle like this.
  9. Jan 27, 2018 at 8:22 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks Joey! I need this!
  10. Jan 28, 2018 at 4:47 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Cant wait for mine to show up tuesday with the platinum SDHQ mount!
    sdhq_offroad[OP] likes this.
  11. Jan 30, 2018 at 7:23 AM
    SATX_ProRunner
    SATX_ProRunner New to forum, not new to tundras
    2018 Blazing Blue 1794 4X4 ProRunner
    Still in progress
    Just got off the phone with @sdhq_offroad and mine is on the way for my 1794. Can’t wait to get this installed.
  12. Jan 30, 2018 at 7:31 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    is the dimming ability only when using the strobe/flash?
  13. Jan 30, 2018 at 8:03 AM
    sdhq_offroad
    GILBERT, AZ
    No, it is available during normal use as well.
  14. Jan 30, 2018 at 8:03 AM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    very nice!
  15. Feb 16, 2018 at 8:25 AM
    sdhq_offroad
    GILBERT, AZ
    Both units are completely different.
  16. Dec 14, 2018 at 3:23 PM
    longhornfan2324
    longhornfan2324 New Member
    Are these the same ones that you guys are selling through Amazon? Wanting to know because i have a few of the amazon gift cards from the holidays and was going to put them towards that. I already have the shifter trim panel for my platinum from you guys i just want to make sure it is the one that will fit correctly.
  17. Sep 2, 2019 at 4:11 PM
    lbcdan
    lbcdan Zip it up and zip it out
    Daniel
    Long Beach, CA
    2018 Toyota Tundra CrewMax 4x4
    Toytec Boss Coilovers, Total Chaos UCA, Icon 57720P Shocks, Toytec Shackles, TRD Off-Road Wheels, SpiderTrax Spacers, BakFlip MX4, Clazzio Seat Covers, Rough Country Light Bar, BajaDesigns Foglights
    old thread, but I am curious on if I can order the Platinum shifter panel even though I have an SR5? Not sure if they are different fits or not but I like the leather option better.
  18. Sep 3, 2019 at 8:48 AM
    sdhq_offroad
    GILBERT, AZ
    The panels themselves are the same fit. The difference is that the Platinum is a leather wrapped as the SR5 is plastic. Other than that, they are swappable and have had quite a few people do it.
  19. Sep 3, 2019 at 8:49 AM
    sdhq_offroad
    GILBERT, AZ
    We do sell the 9100 series on Amazon
  20. Sep 3, 2019 at 8:54 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Did you guys ever make a mount for the plastic trim where the sunglasses go? I ask because us with the 6 seater trucks don’t have the center console.
  21. Sep 3, 2019 at 9:18 AM
    sdhq_offroad
    GILBERT, AZ
    Its been on the list of things. Unfortunately the local guy that has been wanting it keeps rescheduling on us. We are able to do "custom one off" ones as we have done in the past, but we would need the truck here until we finalize a production unit to offer for the 07+.
  22. Sep 3, 2019 at 10:43 AM
    fisherman951
    Tony
    2017 crewmax 4x4
    Darn alright I thought that console on the headliner was all the same for trucks with center console or with out.
