New software not compatible with device
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nopuff2413, Dec 6, 2022.
  1. Dec 6, 2022 at 8:45 AM
    Nopuff2413
    Nopuff2413 [OP] New Member
    2016 SR5 TRD
    This message started appearing on my 2016 Tundra head unit the other day. No update available, clock is gone. Any ideas how to get my clock back or what’s going on? Can’t find anything more recent than 2020 in the forums and they’re all unresolved.
  2. Dec 6, 2022 at 3:46 PM
    TTund16
    TTund16 New Member
    The updates are on Toyota website and you can copy to a USB drive and install. dealer has the navigation and map updates according to the site.
    As far as I know, the software doesn't automatically update. What happened to yours that stopped working? Did you try to install or change something?
  3. Dec 6, 2022 at 5:32 PM
    Nopuff2413
    2016 SR5 TRD
    Nice! I’ll try the site. Thanks much! I had a Maintenance Required displayed on my dash last week and I cleared it. I assume it was for regular scheduled maintenance. I started getting the signal the next day. Maybe that had something to do with it...?
  4. Dec 6, 2022 at 5:51 PM
    SES378
    SES378 New Member
    2015 Toyota Limited TRD Offroad 2WD
    Bilstein 6112/5160, Total Chaos UCA, Coachbuilder Shackles, Toyo AT2 295/70/18 tires
    I cleared the Maintenance Required light last week on my 2015. No signals and everything worked fine.
  5. Dec 6, 2022 at 9:43 PM
    TTund16
    TTund16 New Member
    What's the history of your 2016? Purchased new?
    Anyone ever tweaked any software or any electronics or hardware mods related to that system or any other system?
    Have you ever had the battery disconnected for a while for example for any unrelated reason like replacing the battery with a new battery ... and after restoring the power, was everything fine?
    How did you clear the maintenance required signal? Maybe somehow the firmware got zapped.
  6. Oct 8, 2023 at 4:54 PM
    TN1794
    TN1794 New Member
    2016 Tundra 1794
    Leveled out, airbag system for towing
    I know this is an old thread but I have experienced the same issue with my 2016 Tundra. After OTA update I had no clock! Called Toyota and they were no help, tried to update via USB and it won’t allow it. Gray box meaning update not necessary from what I’ve read. Even tried factory reset on unit and that failed!
