New product release for 07 to 21 Tundra!
Discussion in '2.5 Gen Tundras (2014-2021)' started by 14burrito, Jul 1, 2020.
  1. Jul 2, 2020 at 8:52 AM
    #61
    Less than a potential $750 repair/tow out of the boondocks. If there is a group buy for these Jomax's I'm most likely in at this point. Want to wait and see install pics and more input from @14burrito and Jomax.
    GODZILLA and 14burrito[OP] like this.
  2. Jul 2, 2020 at 8:56 AM
    #62
    I messed one up. $300 f up. Took only a few minutes for me to install a new one. Quite simple actually.
  3. Jul 2, 2020 at 9:05 AM
    #63
    14burrito
    14burrito [OP] IG @14burrito
    2014 SR5 CM 4x4 5.7
    Most people are able to diagnose and install a new one on their own, which helps save a bit :)
    I'll keep you in the loop if I can get a GB buckled down.
  4. Jul 2, 2020 at 11:50 AM
    #64
    Definitely the route I'd go for ABS protection. Looks to be significantly more material, and if I saw correctly, it's a double shear bolt design that's going to be far more robust than current offerings. That makes the price way less shocking. Downright fair, I'd say. I'm definitely in if a GB happens.
    Honestly, probably going to get them with or without the GB. This damn forum:mad: always making me :spending:.
    Thanks for sharing all this, @14burrito ... Bastard.:fistbump:
    Edit:double bolt, not double shear
    Tundyfundy, Black Wolf and Tundra2 like this.
  5. Jul 2, 2020 at 2:40 PM
    #65
    Tundra4x4Offroad
    Tundra4x4Offroad #somenewshitz
    Sam
    Los Angeles, CA
    08 Tundra SR5, 18 Tundra Platinum
    Too many mods to list right now for both Tundra
    I broke one ABS 500 miles from home on a 3 day adventure. Lets just say if you invested in an ABS guard it'll save you a piece of mind. Here's what will happen if you brake an ABS sensor starting with the worst case scenario first:
    1. in 4-lo broken sensor will lock you in and will not disengage from 4-lo therefore your either driving 4-lo all day long or tow your vehicle.
    2. A broken sensor in 4-Hi, its possible that it may disengage and and engage in 4-hi but you will not have any notice unless you are listening to the actuator.
    3. Broken ABS sensor in regular 2WD, Dash light will for ABS comes on, 4HI and 4Lo Flash, no communication to 4-wheel control module, center differential lock code, open circuit code.
    Usually, a broken sensor will cause a combination of 1 and 3, and 2 and 3. You may get lucky replacing the ABS without having to reset the codes on your OBII. If you don't have Techstream to diagnosis, a trip to dealership starts at $150 and it goes up from there.
    All it takes a small rock to smash the Abs sensor.
    Petrone, dgtulsaguy, TTund16 and 3 others like this.
  6. Jul 2, 2020 at 2:46 PM
    #66
    14burrito
    2014 SR5 CM 4x4 5.7
    That's awesome you have an outline of what happens in what modes when a sensor shits the bed on you, appreciate posting that info up! Thank you
  7. Jul 2, 2020 at 5:31 PM
    #67
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Hella beefy! That price is painful but I can see why they are better than the other options. If I didn’t already have sdhq I may bite.
    Tundyfundy, Black Wolf and GODZILLA like this.
  8. Jul 2, 2020 at 5:46 PM
    #68
    14burrito
    2014 SR5 CM 4x4 5.7
    TommyTran and Flyinryank like this.
  9. Jul 3, 2020 at 7:52 AM
    #69
    14burrito
    2014 SR5 CM 4x4 5.7
    Little helper this morning :)
    Tundyfundy, Petrone, TTund16 and 4 others like this.
  10. Jul 3, 2020 at 9:36 AM
    #70
    14burrito
    2014 SR5 CM 4x4 5.7
    More detailed pics will be posted later :)
    GODZILLA and Black Wolf like this.
  11. Jul 3, 2020 at 3:09 PM
    #71
    14burrito
    2014 SR5 CM 4x4 5.7
    Fronts,
    If anyone would like, I can DM some coverage pics of my previously installed shields. I'd rather not post those pics here, but I did post one quick overview shot of them side by side.
  12. Jul 3, 2020 at 8:01 PM
    #72
    14burrito
    2014 SR5 CM 4x4 5.7
    Rears
    Still working on the GB for those who were interested.
  13. Jul 3, 2020 at 8:22 PM
    #73
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Very nice. Interested in a GB. I don't do a lot of wheeling, so its hard to justify, but I can absolutely appreciate the craftsmanship.
    Black Wolf, GODZILLA and ElNopal like this.
  14. Jul 3, 2020 at 8:27 PM
    #74
    I think these kinda fall into the skid plate category of "rather have and not need, than need and not have" type of items. A piece of road debris on the highway will smoke sensor just as easily as a rock on a trail.
  15. Jul 3, 2020 at 8:35 PM
    #75
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Ok...
    That’s a good design.
    Black Wolf and 14burrito[OP] like this.
  16. Jul 4, 2020 at 2:48 AM
    #76
    Tundra4x4Offroad
    Sam
    Los Angeles, CA
    It is a very thought-out design though. It took the best of the current ABS guard which has a rotation error and made 2 bolt for complete coverage of the ABS sensor and prevent rotation of the guard. Although going this route you are now a niche for Tundra and not for many other vehicle which I don't know if that's Jomax intention. This limit the market capitalization of making one product for a broad spectrum of vehicle.
  17. Jul 4, 2020 at 5:12 AM
    #77
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Can you post a pic of the sensor Before installation. Then during....
  18. Jul 4, 2020 at 5:32 AM
    #78
    DZ_
    DZ_ New Member
    Frederick Co., MD
    That is true. I am big on that "have and not need" stuff.
    GODZILLA[QUOTED] likes this.
  19. Jul 4, 2020 at 5:56 AM
    #79
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    On my 2010 I was on a trip and pulled over to check something on the trailer. When I pulled out some large gravel had some ice so put it in 4hi and pulled out. Some of the gravel chunks were flying around in the wheel well and I got the "Christmas tree lights" on the dash. I was able to go to 2wd but the lights stayed on until I had to stop for gas and restarted and I was back to normal. I'm not certain of what happened, but suspect one of the sensors was hit and sent the abs system into a state of confusion. After that had no problem.
    On my 2020 I installed single bolt guards just to be sure. I don't do any heavy off road wheeling, but the stock ABS Sensors are NOT protected and are vulnerable. My currently installed aftermarket ABS Sensor protectors do have cooling vents and not sure if this is needed, or just keeping them lighter?
    The 2 bolt design is really nice and would certainly be more robust for off roading. I might have used those had they been available even for my highway towing and very light off road use. Great protection suggestion that I'd certainly recommend to mitigate damage and costly repair much less being stranded.
  20. Jul 4, 2020 at 6:09 AM
    #80
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I certainly don't need these, but I definitely want these for peace of mind. Beautiful design and by the looks of it, worth the money for the superior design and build quality.
  21. Jul 4, 2020 at 7:38 AM
    #81
    14burrito
    2014 SR5 CM 4x4 5.7
    Post 72 has a before and after for rear.
    I'll upload front before and after later today.
    Being that they are installed, I have no during...but I'm not sure what you are looking for in regards to a during pic?
  22. Jul 4, 2020 at 2:29 PM
    #82
    14burrito
    2014 SR5 CM 4x4 5.7
    GODZILLA likes this.
  23. Jul 4, 2020 at 5:37 PM
    #83
    wiretwister
    wiretwister Sorta new guy
    NJ
    '22 SR5 CM
    What's the possibility of not being able to properly torque those hub bolts having aluminum underneath them? Or having them possibly loosen after the aluminum compresses? The mounting location and specific hardware used makes me nervous.
    Vizsla likes this.
  24. Jul 4, 2020 at 5:49 PM
    #84
    rebmo
    Rural SE Wisconsin
    I used some Loctite on my single bolt guards.
    14burrito[OP] likes this.
  25. Jul 4, 2020 at 6:01 PM
    #85
    Not sure if this will help, but these are the install instructions. You use loctite, so it should all hold. He even gives the torque specs.
  26. Jul 4, 2020 at 7:54 PM
    #86
    14burrito
    2014 SR5 CM 4x4 5.7
    Post 85, Adam beat me to it.
    I'll be rechecking my torques after a week or two. I might also have a tow of our 6k trailer on it. I already have some dirt mileage as well which will only rack up as the weeks progress.
  27. Jul 5, 2020 at 7:49 PM
    #87
    14burrito
    2014 SR5 CM 4x4 5.7
  28. Jul 7, 2020 at 4:05 PM
    #88
    14burrito
    2014 SR5 CM 4x4 5.7
    Little CAD rendering :)
  29. Jul 8, 2020 at 4:41 PM
    #89
    14burrito
    2014 SR5 CM 4x4 5.7
    Typically the only "wash" my truck ever see's lol
    https://youtu.be/hWoeUKKG-Uk
    If anyone has any questions or would like additional pics of the Jomax Armor, please feel free to reach out here or via DM!
  30. Jul 9, 2020 at 7:36 AM
    #90
    14burrito
    2014 SR5 CM 4x4 5.7
    Local AZ buddy of mine just got a set installed. Working on a truck is nice when you have such easy access to a lift lol
    GODZILLA and Tundra4x4Offroad like this.
