New parts arrived!
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Jimes, Sep 7, 2018.
  1. Sep 9, 2018 at 2:38 PM
    #61
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    So are these stock height or providing lift?
  2. Sep 9, 2018 at 3:13 PM
    #62
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Front sway bar is like handcuffs on your truck, especially with a high end suspension like kings. Take it off, eliminates the bobblehead effect, it won’t roll over like many people think
    Watt maker likes this.
  3. Sep 9, 2018 at 6:50 PM
    #63
    Jimes
    Jimes [OP] New Member
    Bay Area, California
    2015 toyota tundra trd pro
    They are the OEM model. Provides 2-3” lift. My Alcan Springs were made to provide 2” lift. It’s sitting high up cause everything is new. 80022808-5FA6-4988-9416-E96C433B842F.jpg
    eccracer104, saybng, TheBeast and 2 others like this.
  4. Sep 9, 2018 at 6:52 PM
    #64
    Jimes
    I’ll remove it before alignment tomorrow if that even makes a difference to do it before or after. I have the skid plate off so whomever does the alignment doesn’t have to deal with my rock light or the time to remove it.
  5. Sep 9, 2018 at 7:43 PM
    #65
    Jimes
    will do. Thanks.
  6. Sep 9, 2018 at 7:44 PM
    #66
    Jimes
    Oh ya. I forgot to ask. I added CB carrier bearing drop kit. When I put the shims and shackles on. Do I still keep the drop kit?
  7. Sep 9, 2018 at 7:46 PM
    #67
    GreatAvalon
    F me that looks awesome...
  8. Sep 9, 2018 at 8:21 PM
    #68
    GreatAvalon
    Did you install a front diff drop kit in the fronts?
  9. Sep 9, 2018 at 9:28 PM
    #69
    Jimes
    No. Was I supposed too?
  10. Sep 9, 2018 at 9:46 PM
    #70
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Neh. No need for that mess.
    TheBeast likes this.
  11. Sep 10, 2018 at 1:47 PM
    #71
    GreatAvalon
    Sweet...I’m the noob asking you veterans here :D :D I see you @Jimes got the adjustable ones based on that red knob on the remote res. Right?
    dcsleeper408[QUOTED] likes this.
  12. Sep 10, 2018 at 3:08 PM
    #72
    TheBeast The Beach
    I didn't add one when I installed my front Kings either.
    dcsleeper408 likes this.
  13. Sep 10, 2018 at 3:21 PM
    #73
    d0zer
    d0zer I beat the internet.
    Definitely somewhere
    2017 MGM Platinum
    ADS 3.0" & 2.5" AllPro APEX Sliders SCS SR8 on Cooper ST MAXX 295/70r18
    You don't need to bend anything, the bolt comes out no issues. The only issue you will have is undoing the bolt. It is tight as shit. You'll need a breaker bar 100%. Access to the bolt is tight on the drivers side.
    Also, when you separate the spindle tie it to something so it doesn't swing all over the place.
  14. Sep 10, 2018 at 3:42 PM
    #74
    Jimes
    Thanks, I finished the install this weekend. Now I just need an alignment.
  15. Sep 10, 2018 at 3:46 PM
    #75
    Jimes
    So potential stupid question. Just a heads up. So I am about to remove my sway bar and was wondering since I have an ARB front locker will removing the sway bar hurt the locker or axle when engaged? I never use my locker when turning. Only when going straight cause of the IFS and too scared to bind my axle. Rarely used, but nice to have.
  16. Sep 10, 2018 at 3:47 PM
    #76
    Jimes
    Didn’t trip off the fact that I forgot to adjust the shock to be taller. It’s only at 2”. How may threads should I be at to make a 3” lift?
  17. Sep 10, 2018 at 3:50 PM
    #77
    Jimes
    This is where they are at now. And can I adjust while on truck?
    2D114E74-48D5-4DAE-88B0-63FE5CB4BFF7.jpg 1FABB1E2-990A-46BB-A681-F9668D934C76.jpg
  18. Sep 10, 2018 at 3:54 PM
    #78
    TheBeast The Beach
    give it a try. You might be able to squeeze 2 turns. First try I had to remove them and use a springs compressor. then second time I was able to get 2 more full turns driver side with them on ( was correcting driver lean ). I snapped their tool right in. bitch to remove..
    Edit to add: looks like you have oem KINGS settings: 7~8 threads each side. Measure the height difference between driver and passenger. in my case I added 5 threads driver side.
  19. Sep 10, 2018 at 4:03 PM
    #79
    Jimes
    Oh damn. That doesn’t sound like a good time. I really don’t want to have to remove the shock again. Ahhhh! What’s weird is that when I took my measurements for Filthy Motorsports my truck was only off by 1/4”. So my lean isn’t too bad at all. But I only have the 25 gallon tank. Weak
  20. Sep 10, 2018 at 4:19 PM
    #80
    TheBeast The Beach
    I believe Toyota correct one side vs the other on their stock suspension already. When you go to aftermarket, you reset those settings so the lean might be more pronounced.
    with stock TRD I think i had about 1/4" lean. As soon as I switched to Kings I was almost 1". same gas tank as yours. So before going for your lift height, fix the lean first.
  21. Sep 10, 2018 at 4:30 PM
    #81
    Jimes
    Ah. Ok. Cool. Will check the lean. Haven’t done that yet.
  22. Sep 10, 2018 at 4:36 PM
    #82
    Jimes
    Ok. I guess I’ll do it right. Damn. Now I have to buy a spring compressor. I appreciate the info
  23. Sep 10, 2018 at 4:54 PM
    #83
    Jimes
    I’m looking online at the moment. Think I might just buy one. I like to own lots of tools. Since I may have to use it more than once. Any recommendations on one that works well?
  24. Sep 10, 2018 at 6:42 PM
    #84
    Squatchtundra
    Squatchtundra Hammer Down
    Olympic Peninsula
    2018 limited cm MGM
    Kings and Total Chaos UCA with ko2's
    Coachbuilder shims are the way to go. Then you are not preloading your driver's side spring way more than the passengers side
    Drivers side 2 shims
    Passenger side 1 shim
    SoCal619 likes this.
  25. Sep 10, 2018 at 7:09 PM
    #85
    Jimes
    I’m not going the shim route. I’m actually going to sell my CB shim and CB+3 shackles. So anybody who has King OEM shocks how many threads are showing to create a 3” lift? I have 7 on one side and 8 on the other.
  26. Sep 10, 2018 at 7:22 PM
    #86
    Squatchtundra
    Olympic Peninsula
    2018 limited cm MGM
    King says 7 threads is 2.5" and every 5 threads showing after that is approx 1". Just remember kings have a fine line where the ride turn to sh!t if you have 600# springs.
  27. Sep 10, 2018 at 7:27 PM
    #87
    Jimes
    Even if I told them I wanted to use them at 3” and got them custom valved? I’m emailing Filthy Motorsports to ask them if that’s cool, but I know they are super busy and won’t get back to me till tomorrow.
  28. Sep 10, 2018 at 7:28 PM
    #88
    Squatchtundra
    Olympic Peninsula
    2018 limited cm MGM
    Yup. That's a question for them :thumbsup:
  29. Sep 10, 2018 at 7:51 PM
    #89
    Jimes
    Thanks everyone for the responses and info.
  30. Sep 11, 2018 at 12:54 PM
    #90
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    I got my Kings from Filthy Motorsports too, I had them value them for 100% off roading. They ride awesome on road, but even better off road. I choose to go with a 700 coil spring and it was a great call. Especially like when you are off roading definitely helps me when I off-road fast. Here is a photo of the rear shocks, I dont have a picture of the coilovers on my phone. IMG_6551.jpg
