New Owner 2005 SR5, Some Quirks
Discussion in '1st Gen Tundras (2000-2006)' started by trumbo71, Mar 6, 2021.
  1. Mar 6, 2021 at 8:33 PM
    trumbo71
    trumbo71 [OP] New Member
    2005 TRD Double Cab
    New owner of a 2005 Tundra SR5 double cab. Runs great but has some quirks.
    1st Quirk. When coming to a stop sign as soon as I release the brake there is a light clunk and a little bit of jump before I can even press the accelerator, tends to happen more often in residential areas where I only get up to 20-30mph and happens less often when coming to lights where I was just doing 45mph+.
    2nd Quirk. Exhaust Heat shield right under driver side rattles like crazy when hot, I know it is it because if I hold onto the hangar it stops rattling. Bolts are a little rusty but they're all there so not sure why it's rattling?
    3rd issue is exchanging the stereo, I have the JBL premium audio system and am looking at this wiring harness. Is this correct? With that harness can I swap all the door speakers out or will I have to run new wires for all speakers?
    Last but not least here's some photos of her, very clean truck.
    YardBird, hammeron, revtune and 2 others like this.
  2. Mar 6, 2021 at 8:57 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Nice truck :thumbsup:
    First quirk I would check the carrier bearing and see if there is excessive play in it. Could be you just need to change the tranny fluid. Hopefuly something simple :fingerscrossed:
  3. Mar 6, 2021 at 9:09 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Rear half of driveshaft may need to be cleaned/lubed.
    Also check rear leaf packs.
    Voss and FrenchToasty like this.
  4. Mar 6, 2021 at 10:01 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Common problem that’s really a non issue on these trucks. You brake, rear end preloads, ie rotates, slip yoke extends, you let off the brakes just enough so that the springs unload and then the slip yoke jams back in real quick.
    Really the only solution, if 4wd, is to pump the yoke full of grease. The 2wd yokes don’t have a grease zerk so you just learn to live with it.
    Oh and for sure, don’t flush the tranny as stated. If anything only do a drain and fill.
    Failure2comply and revtune like this.
  5. Mar 7, 2021 at 6:14 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from so cal
  6. Mar 7, 2021 at 6:19 AM
    Welcome from NY.
  7. Mar 7, 2021 at 6:21 AM
    Professional Hand Model
    Hand Protectors
    1) Grease all drive shaft zerks. Do a search here. You also may have loose/missing transmission mount bolts if yours is 2wd.
    2) Buy some 3” Stainless Hose clamps from Big Box and remove the old and reclamp with new. Your shields are rattling probably and this is a fix.
    3) Nice engine feather dusting!
  8. Mar 7, 2021 at 6:35 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
  9. Mar 7, 2021 at 6:50 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Agree with the group on the fixes, and welcome from True NorCal!
  10. Mar 7, 2021 at 7:34 AM
    trumbo71
    2005 TRD Double Cab
    I also thought this but this adapter does not work the adapter has 20 pin outs on the radio here is a photo of the plugs in the dash. It is also 2 WD so no zerks, carrier bearing has play in it but not sure how much is to much? I can move it up and down maybe a 1/4 inch.
  11. Mar 7, 2021 at 7:47 AM
    Hand Protectors
    It can move a little. Depends on the Rubber Condition. If its never been changed before its probably time. Spicer makes one. There is a thread here somewhere where you source it straight from Spicer for $60ish vs the $180 I spent before learning. :annoyed::rofl:
    Failure2comply likes this.
  12. Mar 7, 2021 at 7:53 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  13. Mar 7, 2021 at 2:02 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Ohhh. If 2wd there are 4 bolts for the transmission mount that like to come loose &/or disappear. They are a known cause of this clunk/shudder. If they are there I recommend using some blue loctite on them.
    1/4" play should be ok. It's if it's super loose and knocks around that you'd replace it.
  14. Mar 7, 2021 at 3:19 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
    You may need the amp bypass harness Metra 70-8117. On my 06 DC Limited the amp is located behind the rear drivers seat back bolted to the back wall of the cab.
    You can download a pdf of the 2005 Toyota Factory Service manual at the link below
    https://drive.google.com/file/d/0B-5MhfqaHsHObmt6RDVhOGtKWjA/view
    abcinv likes this.
  15. Mar 7, 2021 at 3:42 PM
    trumbo71
    2005 TRD Double Cab
    N84434 likes this.
  16. Mar 7, 2021 at 3:46 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    I have a Kenwood KSC-SW11 under the rear passenger seat. It won't rattle the widows but has enough bass that's good enough for me.
  17. Mar 7, 2021 at 4:04 PM
    trumbo71
    2005 TRD Double Cab
    I was looking at that model and a few others because I would have to fabricate a box to fit into the jack storage compartment and not really wanting to put in the labor haha. But I would like the extra boom from 2 8's so Im still thinking over it.
  18. Mar 7, 2021 at 4:48 PM
    Grumpy74
    Grumpy74 New Member
    2005 White Tundra SR5
  19. Mar 7, 2021 at 5:11 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  20. Mar 7, 2021 at 7:17 PM
    N84434
    Milwaukee WI.
    2001 Limited TRD
