New on board air compressor from NSV soon to be released
Discussion in 'General Tundra Discussion' started by 1UPPER, Nov 29, 2016.
  1. Nov 29, 2016 at 6:06 PM
    1UPPER
    1UPPER [OP] Not A New Member
    TEXAS
    Flux capacitor!
    i have been in the market for an on board air compressor for airing up my tires and found this new product from NSV auto. It's the first time I've seen an on board air compressor designed specifically for the Toyota Tundra. It installs very neatly under the rear seat. This is literally just about to hit the market. The Rep said he doesn't have the exact cost yet but it may range around $400-$600 but he doesn't have the cost yet. If anyone is interested in this as I am please let me know? I will see if we can do a group buy for a better discount. IMG_5095.jpg
  2. Nov 29, 2016 at 6:11 PM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    would need to provide some specs on it. what kind of CFM are we talking about??
  3. Nov 29, 2016 at 6:13 PM
    TheBeast The Beach
    that is pretty cool. yeah we need specs.
    Tundyfundy and zcarpenter92 like this.
  4. Nov 29, 2016 at 6:19 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Under the rear seat how and where?
    Tundyfundy and gosolo like this.
  5. Nov 29, 2016 at 6:23 PM
    1UPPER
    TEXAS
    Flux capacitor!
  6. Nov 29, 2016 at 6:24 PM
    1UPPER
    TEXAS
    Flux capacitor!
    It mount underneath the rear passenger.
  7. Nov 29, 2016 at 6:37 PM
    1UPPER
    TEXAS
    Flux capacitor!
    Until the product has been fully released for sale I don't have all the answers. Just thought I would post some pics of what's coming out soon.
    Tundyfundy likes this.
  8. Nov 29, 2016 at 6:37 PM
    Mike Tread lightly.
    south carolina
    I read on fj boards it's around I like 1cfm... It's a great idea if you can get 4 or 5 cfm..
    I will keep my co2 tank with 1600 psi. :)
  9. Nov 29, 2016 at 6:40 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I thought he Rep said it's a 4 cfm output. If it's a decent system I'm going to add a separate Aluminum tank to it under the truck for additional air supply and my train horns.
  10. Nov 29, 2016 at 7:08 PM
    IB-IN-YA
    IB-IN-YA RUNAMUK !!!!!
    Republic of Texas
    2017 TRD PRO TUNDRA
    Count me in on one.
  11. Nov 29, 2016 at 7:33 PM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    dude this is nice! more pictures!?
  12. Nov 29, 2016 at 8:08 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Excuse my ignorance Mike, but what's the benefit of filling tires with CO2 versus O2?
  13. Nov 29, 2016 at 8:57 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    I might be wrong here but I'm pretty sure CO2 is inert making it less susceptible to psi changes with temperature change?
    Edit: I'm an idiot. Don't listen to me.
  14. Nov 29, 2016 at 9:06 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    FlashCulprit likes this.
  15. Nov 29, 2016 at 9:07 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    Wait I lied, that's nitrogen.
    TheBeast and joonbug like this.
  16. Nov 29, 2016 at 9:08 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Yup... that sounds right too
    ccdawnpatrol and FlashCulprit like this.
  17. Nov 29, 2016 at 9:09 PM
    FlashCulprit
    Joe
    Salt Lake City, UT
    I took one semester of Chemistry. It didn't stick. :goingcrazy:
  18. Nov 29, 2016 at 10:28 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Very cool. I assume it is only for the 3rd gen guys where they cut out the foam to insert for a clean install.
  19. Nov 29, 2016 at 10:48 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    When i went down to SD and purchased some stuff from CM_Lenny, he popped his hood and showed me his compressor set-up and it was pretty awesome. He'd be worth getting ahold of and maybe asking a few questions. He did an awesome job on his.
  20. Nov 30, 2016 at 5:07 AM
    Mike Tread lightly.
    south carolina
    Co2 is nothing but a compress gas (liquid). One pound is equal to about 9 cubic feet or air when you do the expansion on it... Also co2 doesn't add water vapor into the stream like the compressor does. Therefore if you run air tools for example co2 you don't need a drier on it.. if you are running a locker for example (arb) I don't think you want water going into your diff case do you? More reasons to use co2 then compressor unless you run dryer inline.. co2 tank is portable i can take my tank out and go anywhere with it and have pneumatic power...
    Only down side is filling it but over 2 year period I have only filled my 20 pound once at 20 bucks and 10 lbs on my tundra never used yet it's still full.
    Never use o2 straight.. if you like to cut metal you can use nothing but o2 and a tip... Both are in the same hazard class (2) non flammable gas.. other problem with o2 is special tank required to transport o2. Only advantage is cubic feet is about 12 cubic feet 3 feet pass co2. Running pure o2 the cost to refill is up there...
    Both co2 and o2 the cubic feet changes as per the temperature of the gas in the tank mind you.
    After a small lesson here co2 will keep water from getting inside the tires and in cold weather not introducing water to freeze in inside the tire vs air compressor gas or o2 gas.
    NewImprovedRon likes this.
  21. Nov 30, 2016 at 6:39 AM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    seems like a cool idea, but the compressor inside the cab would be loud, especially if you're airing up and you have small ones in the back seat, or even a passenger.
  22. Nov 30, 2016 at 6:48 AM
    1UPPER
    TEXAS
    Flux capacitor!
    It's actually very quite. I'll try and post the video of it running
    Tundyfundy and dragos28 like this.
  23. Nov 30, 2016 at 9:09 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Interesting...keep us all updated! :popcorn:
  24. Nov 30, 2016 at 11:47 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    That's what I was wondering. Looks like it probably won't work for the Crewmax with ESP neither. That would be a shame.
  25. Nov 30, 2016 at 12:57 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I found out the CFM output for the compressor is 2CFM. I'm waiting on the spec sheet. I'll post it when I get it.
  26. Dec 9, 2016 at 8:21 PM
    IB-IN-YA
    Republic of Texas
    2017 TRD PRO TUNDRA
    ANY UPDATE ....
  27. Dec 9, 2016 at 9:11 PM
    1UPPER
    TEXAS
    Flux capacitor!
    The on board compressor is on backorder for three months. The company rep is going to get me a group buy price for this and all the other products they sell for the members on the forum. I should have the cost next week.
  28. Sep 18, 2017 at 6:27 PM
    elrob
    elrob New Member
    17' SR5 CM TSSOR
    Saw that NSV just started posting about the compressor again. Any more info about specs and wiring?
    Group buy?
  29. Sep 18, 2017 at 6:30 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I can ask about a group buy. I'm already working with the main sales rep for a discount on the NSV light bar. NSV is reluctant to give discounts though because they don't want to have there dealers who vary their products being undersold. I'll ask though. As far as specs, I'll see if he can send me the specs.
  30. Sep 18, 2017 at 6:32 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nice find at @1UPPER that's definitely pretty cool. Those 2 pics you posted look very different tho.. first looks nice n sleek, second one of the specs looks huge.. I'd be in on that for a group buy for sure.. :bananadance:
