New Morimoto 14-21 Tundra Taillights have FINALLY arrived!
Discussion in 'Lighting' started by Headlight Revolution, Mar 24, 2022.
  1. Nov 28, 2022 at 9:41 PM
    #181
    textundra12
    textundra12 New Member
    Anyone know when the third brake light is going to be released? Def getting it.
  2. Nov 28, 2022 at 9:48 PM
    #182
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    g6t9ed likes this.
  3. Nov 28, 2022 at 9:49 PM
    #183
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    Should’ve already dropped on their website! I actually ordered one a few days ago (BF deal), looks like it’s slated to ship out maybe late Jan
    Edit: @memario1214 beat me lol
  4. Nov 29, 2022 at 10:14 AM
    #184
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    Just ordered the black taillights from Hotshot Off-road, -20% + no sales tax and free shipping is absolutely killer.
    RobertD likes this.
  5. Nov 29, 2022 at 8:41 PM
    #185
    textundra12
    Dang i paid full price like a week ago :/
  6. Dec 2, 2022 at 5:04 PM
    #186
    SILVA1181
    SILVA1181 New Member
    Marc
    Houston, TX (Spring Area)
    I went to install the new tail lights this evening and did the driver side first. The resisters were not attached to the back of the new tail, so i didn't attach it. I installed the driver side and worked fine. I then proceeded to the passenger side and it worked with no issues. I tested the brakes and they worked. I went to test the driver turn signal again and hyper flash started after about 30 seconds. I then tested passenger side and hyper flash started.
    I tested the emergency lights and no hyper flash. I removed the driver side XB and placed the OEM back on, and the left the XB in the passenger side, tested the driver side and no hyper flash. Tested the passenger side, no hyper flash. Put the XB back in driver side and hyper flash started again after about 30 seconds.
    I have the OEM LED headlight upgrade with Ihacker harness and have not had any issues with hyper flash. Does anyone know if the hyper flash will continue if I install the resistor on the back of the XB tails? I don't want to install resistors on my front headlights if I can avoid, just don't want to hassle with it. I spent a hour trying to troubleshoot the issue and called it a night after a long day of work. I put my OEM's back on and reboxed the XB's.
    Any input is appreciated
    CorpsTundra likes this.
  7. Dec 2, 2022 at 5:34 PM
    #187
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    You HAVE to install the resistors. Trust me, I had the same issue. Problem will be solved. It's more fun when you add the gen 2 morimoto xb headlights. I had to undo the turn signal switch recall which was really easy.
  8. Dec 2, 2022 at 5:41 PM
    #188
    SILVA1181
    Marc
    Thanks, I will give it a try tomorrow with attaching the resistors.
    I had read in another post (can’t find the post now), about the drive side resistor obstructing the tailgate shock absorber. Did you have an issue with this?
    Is this dangling black plug for the resistor
  9. Dec 2, 2022 at 5:52 PM
    #189
    RoniusMaximus
    J
    No. I used a zip tie on each side to keep everything together and only behind the tail light.
  10. Dec 2, 2022 at 5:55 PM
    #190
    SILVA1181
    Marc
    Thanks again. Will give update tomorrow.
  11. Dec 3, 2022 at 4:46 AM
    #191
    SILVA1181
    Marc
    So I forgot to mention last night that both my XB tail lights have the similar defect that others have mentioned. The defect exist on both lights. Has anyone received a set that didn’t have this defect? Will this allow for condensation issues?
  12. Dec 3, 2022 at 11:17 AM
    #192
    SILVA1181
    Marc
    Talked to hotshots and we will see what Morimoto says about the defect.
  13. Dec 3, 2022 at 7:11 PM
    #193
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    I ordered these tail lights on Black Friday and have the same headlights set up as you. I don’t know anything about installing anything to do with trucks. That being said what is a resistor and is it something I have to purchase from somewhere? They are supposed to arrive in late December.
  14. Dec 3, 2022 at 7:19 PM
    #194
    SILVA1181
    Marc
    These are the resistors. They were included with my tail lights.
    From what I understand you can attach them to the back of the tail lights with the little screws that come in the box. These prevent hyper flash. Maybe others who have already installed the resistors can advise better as to installation of the resistors.
  15. Dec 11, 2022 at 11:05 AM
    #195
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Indeed. I want to see more pics of the red and black/clear lens. I like the black but the red looks more OEM to me. Also concerned the clear lens on the black may become oxidized much faster than the red lens. Perhaps PPF would delay that ?!
  16. Dec 11, 2022 at 12:12 PM
    #196
    SILVA1181
    Marc
    I added red lens to my MGM Crewmax
  17. Dec 11, 2022 at 3:19 PM
    #197
    Tundrastruck91
    Looks great ! All plug and play right ? Did you go with the seq turn signal or reg ?
    edit: also matches oem brakelight perfect
  18. Dec 11, 2022 at 3:24 PM
    #198
    SILVA1181
    Marc
    Yes P-N-P. They came set as sequential and I left them as sequential for now. I am thinking of switching to regular since my fronts are regular but I guess it really doesn’t matter since I can see them myself, LOL. I wonder if other members who have regular turn signals up front left the rears as sequential or switched to regular.
    Video Uploaded
    https://youtu.be/xV5mL4mssI8
  19. Dec 19, 2022 at 6:38 PM
    #199
    mZiggy
    mZiggy Honey badger
    Marc
    Received the taillights yesterday, had ordered them from Hotshot Off-road during their Black Friday sale; put them in this afternoon.
    They came set for sequential already, and that's what I left them as since it's what I wanted. Went with the black set to match the Morimoto XB headlights that I've got up front.
    They look great, they really do. I did need the resistors. When I hooked up the first light and tested the turn signals, it had the hyper-flash. Put the resistor on and it was resolved. Zip-tied the resistors to one of the holes in the metal of the taillight cavity.
    Before (stock):
    After:
  20. Dec 22, 2022 at 4:45 PM
    #200
    Franco4x4
    2019 tundra CM
    just received my tail lights did you install yours? I’m confused on where to put the resistors. Can find a video of someone using them.
  21. Dec 22, 2022 at 4:57 PM
    #201
    SILVA1181
    Marc
    You're supposed to be able to attach them to the back of the housing. You should have received a packet of 4 little screws and then you'll see the little holes on the back where you can attach them. However, I tried this for the driver side and it wouldn't work because when I installed the taillight the tailgate shock absorber would push against the resistor and back of light, pushing it out of the opening. So on the driver side I zip tied the resistor to a section of the bed in the back side of the tail light opening and it worked.
    For the passenger side, I attached the resistor to the back of taillight with the little screws and was able to install the light easily as there's nothing to obstruct it on the back side in the opening.
    To date, I've had no issues. I did not take photos, sorry. Check this link from The Retrofit Source website, install guide.
    https://www.morimotohid.com/core/me...2Mh6-hl5WQvnMBFrhdePh3y_z-8p6HmSzn861ZLKCwwrA
  22. Feb 22, 2023 at 7:46 PM
    #202
    JordanSmith127
    JordanSmith127 New Member
    Jordan
    San Luis Obispo
    2020 TRD PRO
    Has anyone received one of those third brake lights yet? Would love to see it installed with the tails
    Y0TA PR0 likes this.
  23. Feb 22, 2023 at 9:13 PM
    #203
    memario1214
    Colton
    Missoula, MT
    Negative. Morimoto hasn’t shipped any yet. Probably looking at about 3 more weeks.
  24. Feb 24, 2023 at 10:21 PM
    #204
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Patiently waiting still.
    WFD473 likes this.
  25. Mar 8, 2023 at 10:31 AM
    #205
    Rod702
    Rod702 New Member
    Rod
    Cherry red Barca tundra !
    Oem
    So I have issue with xb tail light. Keep in mind I also have xb led headlamps which was on truck first with oem tail lights which was working fine.
    So I plugged in passenger side xb tail light and I get hyper flash both in front/rear passenger side but only when lights are in off position in cabin. When lights are on on position hyper flash intermittently goes away but comes back.
    I switched both xb from driver side to (problem) passenger side and I get the same hyper flash. So I know the both units are fine. I installed the oem tail lights and both are working fine. I left oem tails on because I didn’t want any shorts happening.
    I checked all fuses in cabin by emergency brake, and also fuses in side engine bay. Everything looks good.
    Really weird issue. Called and emailed Morimoto but they are slower than molasses getting back to u. Anybody have any remedies ?
    thanks in advance!
  26. Mar 8, 2023 at 10:34 AM
    #206
    Fuses dont cause hyperflash. Hyperflash is caused by the load change as Leds use
    less power. This is fixed with resistors. @memario1214 might be able to assist.
    memario1214 likes this.
  27. Mar 8, 2023 at 10:40 AM
    #207
    Rod702
    Rod702 New Member
    Rod
    Oem
    thanks man really appreciate, they are sick ass lights. Really want them to work
  28. Mar 8, 2023 at 11:22 AM
    #208
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    Did you put the resistor on the tails?
  29. Mar 8, 2023 at 11:28 AM
    #209
    Rod702
    Rod702 New Member
    Rod
    Oem
    yes in pics I wired both resistors in.
  30. Mar 8, 2023 at 11:45 AM
    #210
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    I don't see the resistors in the pic, but if you wired them in then I unfortunately am of no help.
