New Morimoto 14-21 Tundra Taillights have FINALLY arrived!
Discussion in 'Lighting' started by Headlight Revolution, Mar 24, 2022.
  1. May 12, 2022 at 3:41 PM
    #61
    tundratoofun
    tundratoofun Yall better rednekonize
    Glendale
    Beast
    Thats sexy
  2. May 12, 2022 at 4:37 PM
    #62
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Mine are In but I won’t be home till next week! :annoyed:
  3. May 12, 2022 at 8:29 PM
    #63
    kogswell21
    kogswell21 New Member
    So.Cal and da 808!!
    2019 MGM 4x4 crew cab
    They look NICE. Might have to order some…
    Y0TA PR0 likes this.
  4. May 18, 2022 at 1:19 PM
    #64
    Y0TA PR0
    Rafael
    2017 TRD PRO
    @Asimov2025 what are these for? I didn’t see them use these in the video. For hyperflash fix?
  5. May 18, 2022 at 2:07 PM
    #65
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Correct. FYI, if you have Morimoto headlights like I do, bear in mind this will not fix the hyperflash to the front. When I installed mine, my tail lights would work normally but would hyperflash in the front. You will need to add the resistors to the front turn signal wires. Hope that helps.
    bulldog93 and Y0TA PR0[QUOTED] like this.
  6. May 18, 2022 at 2:56 PM
    #66
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Thanks! I do not have morimoto headlights, just oem led headlights
    g6t9ed[QUOTED] likes this.
  7. May 18, 2022 at 3:00 PM
    #67
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I have the factory led lights and I did add them. There should be 4 screws and you arrange them on the back of the light and screw them down. The leads plug into the empty leads on the lights. Install the lights and good to go.
    Everything is working great since installed.
    Y0TA PR0[QUOTED] likes this.
  8. May 18, 2022 at 4:21 PM
    #68
    mZiggy
    mZiggy Honey badger
    Marc
    2020 Tundra SR5-CM; 2020 4R TRD Pro; 2008 4R SR5 v8
    I have morimoto headlights. Does this mean those resistors are required then, or are they just there for "just in case"?
  9. May 18, 2022 at 4:47 PM
    #69
    g6t9ed
    Your situation may not be the same as mine, but just to elaborate, I had Morimotos up front and had Spec-D LED tail lights in back. Didn't have any hyperflashing with this set up. When I installed my Morimoto tail lights, the tail lights would turn sequential normally but the front turn signals would hyperflash. The emergency lights would make everything sequentially blink normally. It didn't matter if I added the included resistors to the tails. The fronts would just hyperflash away. It confused me because not only did I not experience hyperflash with my previous LED setup, I was under the understanding the Morimoto head lights had built in resistors.
    So, long story short, if you install the tails and your fronts hyperflash, add resistors to the headlights. You can either splice the existing resistors that came with the tails or buy another aftermarket resistors. I opted to just go with the VLED VLR-6 series just because their install method seemed high quality and confident for me.
    Edit: Here's a video of how they install and why I chose them.
  10. May 18, 2022 at 6:16 PM
    #70
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Sweet thanks!
  11. May 20, 2022 at 2:03 PM
    #71
    Y0TA PR0
    Rafael
    2017 TRD PRO
  12. May 20, 2022 at 2:26 PM
    #72
    WFD473
    WFD473 Long Live The V8
    Northeast Illinois
    2014 MGM SR5 CM 4x4
    Very nice!!
  13. May 20, 2022 at 2:36 PM
    #73
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Thanks!
  14. May 20, 2022 at 5:11 PM
    #74
    copmagnet82
    copmagnet82 Member
    Paul
    Chicago
    2010 SR5 & 2021 TRD Pro
    Looking good @PRO BLANCO :thumbsup:
    Can you post more pictures, especially close-ups to see how they fit compared to OEM?
  15. May 20, 2022 at 5:17 PM
    #75
    Y0TA PR0
    Rafael
    2017 TRD PRO
  16. May 21, 2022 at 1:59 PM
    #76
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Excellent!
  17. May 29, 2022 at 4:07 PM
    #77
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    I received these Morimoto XB LED tail lights today. Went to install them on my 15 Tundra SR5. Got the brake and driving light connectors together ok but the turn connector on the new tails wouldnt engage correctly. I nearly couldnt even get the connectors together. How about you? I requested an RMA. These were 630.00 on sale. I shouldnt have any troubles.
  18. May 30, 2022 at 7:36 AM
    #78
    g6t9ed
    I didn't have any issues. Did you by chance take any photos? I'm curious to see what it looked like to cause such an issue.
  19. May 30, 2022 at 7:40 AM
    #79
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Ill take some snaps later today. I was really suprised the female connector wouldnt engage very easily and once it did, the male pin on the lamp side wasnt even close to the turn harness connector.
    g6t9ed likes this.
  20. May 30, 2022 at 9:49 AM
    #80
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    Senior moment. I was attempting to plug the turns into the wrong connector. I looked again and saw the turn receptacle on the tails. They went together just fine an are operative. All is well.
  21. May 30, 2022 at 10:56 AM
    #81
    g6t9ed
    Lol, glad you figured it out. :thumbsup:
  22. May 31, 2022 at 12:24 PM
    #82
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    So the included resistors you installed with the Morimoto tails right? I just wanted to double check as I have the black factory LED headlights waiting to install and the Morimoto tails. I figured I'd bang them both out this week sometime. Didn't want to install the headlights and then realize the resistors should be for them.
  23. May 31, 2022 at 1:02 PM
    #83
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    I did install them. No issues.
    Nbab23[QUOTED] likes this.
  24. May 31, 2022 at 5:50 PM
    #84
    JordanSmith127
    JordanSmith127 New Member
    Jordan
    San Luis Obispo
    2020 TRD PRO
    Got mine today, quick/easy install and everything works great.
  25. Jun 2, 2022 at 3:12 PM
    #85
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Will get some pics soon but I finally installed my morimoto tail lights. Really easy install and I did have to use the included resistors as my oem 2020 TRD Pro LED headlights were hyperflashing without the resistors. Very happy!
    Nbab23, WFD473 and Tundra234 like this.
  26. Jun 2, 2022 at 6:02 PM
    #86
    RoniusMaximus
    J
    I will get more pics after I wash it...20220602_175823.jpg 20220602_175754.jpg 20220602_175715.jpg
  27. Jun 10, 2022 at 2:24 PM
    #87
    15SR5CM
    15SR5CM New Member
    Roseville, CA
    2015 SR5
    Bilstein 6112/5160 3/1 w/CB shackles Ironman front bumper, 18+SR5 Honeycomb grill
    love these lights but i already have a hard enough time paying the 600 to upgrade my headlights lol
  28. Jun 22, 2022 at 1:12 PM
    #88
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Anyone else have spots on both taillights that look like little chips? Middle inside of each light? Just installed mine today. Love the look but my left one looks chipped from a distance. The right one up close. 0D3F2D89-9DF6-41BC-8B75-FA17604A2D34.jpgBAF62B3E-8FDD-470D-81BA-87DD4212EE4B.jpg
  29. Jun 22, 2022 at 1:42 PM
    #89
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Here’s a slightly better photo of the left one.
  30. Jun 22, 2022 at 2:01 PM
    #90
    That would drive me absolutely nuts.
    Fish Wagon and Nbab23[QUOTED] like this.
