New member - Steering wheel vibration solved
Discussion in '2.5 Gen Tundras (2014-2021)' started by daylorb, Jun 19, 2018.
  1. Jul 8, 2019 at 10:44 AM
    daylorb
    daylorb [OP] New Member
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    I know - that is what I would have assumed from the start. But the vibration completely disappeared with the last rotor turn and replacement of old pads. Now it is back - I didn't change anything like tie rods/bushings/etc. the last time and it was solved. Likewise on the wheels - had them road force balanced and it did nothing.
  2. Jul 9, 2019 at 9:22 AM
    daylorb
    Austin, TX
    2016 Limited 4X4
    Go Pack!
    Went back to the drawing board last night and through the process of everything that changed when the vibration went away last time.
    * Turned rotors
    * New pads
    * Subsequent new rotors...
    Realized a critical component is the removal re-install of the wheel...
    So - loosened, re-set, and re-torqued the front wheels to 110. Vibration is now gone.
    I'm pretty sure I have these wheels, powder-coated black: https://www.autorimshop.com/toyota-tundra-2016-20-wheel-rim-69533.html, the torque specs say to go to 97, https://21cylinders.com/toyota-tundra-lug-nut-torque-size/, although I've seen a lot of folks posting they do 110 for whatever reason. Will do a separate post on that.
    Skew12 likes this.
  3. Apr 9, 2021 at 3:56 PM
    texastundralover
    texastundralover New Member
    Brandy
    2018 Silver Tundra Limited 4x4
    Hi! I’m interested if the re-torquing fixed the problem for good? Is your truck 4WD? What tires did it have on it?
    We do have the same wheels with the exception of color.
    Also, did you notice any uneven tread wear on the outsides of your tires? Ours are nearly bald on the outsides of the tires with only 26k miles. The tires are rated for 55k.
    We bought our 2018 Tundra Limited 4x4 brand new with 4 miles on it. The issue was noticeable and very bad within just weeks of having it. We took it to the dealership and they gave us two new front tires and it helped but didn’t fix the problem. We have taken it in multiples times subsequently and still have no resolution.
    I am contemplating printing all of this information, along with our services records and filing for lemon law protection before it runs out.
    I feel like they are stringing us along knowing there is a major issue with these trucks.
    Has anyone noticed similar issues or found a resolve since? Anyone ever been able to successfully prove it’s a lemon??DB6893D1-CB15-4C12-A8AB-EDCB4A2009E8.jpg935F5410-F893-4D7B-B435-BE53B683FD47.jpg 64D91580-EE65-46CA-892E-72AA1E4909AB.jpg
  4. Apr 9, 2021 at 4:33 PM
    Glennjc1978
    Glennjc1978 New Member
    Glenn
    2021 trd pro lunar rock
    Welcome from Maryland
    texastundralover likes this.
  5. Apr 9, 2021 at 4:47 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Truth be told resurfaced rotors are 50/50. better to just buy new. I had the same problem with a Lexus. Always had a slight vibration. Guy at work had a corvette doing the same thing. they told him it was his rotors, I told him no way. He said it fixed his problem. I changed my rotors problem fixed, that was 10 years ago still zero vibration.
  6. Apr 9, 2021 at 4:49 PM
    texastundralover
    Brandy
    Thank you! Hoping to get some resolution to this craziness!
    We love our Toyota’s, have had a Tacoma, Prius and our Tundra. This has been the only major issue we have ever had! Need some suggestions to take to the dealer so they can check it all out! :burnrubber:
  7. Apr 9, 2021 at 4:58 PM
    texastundralover
    Brandy
    Thanks! That’s one of the things they tried (without our permission) was to turn the rotors. We went to pick it up and they said, we turned the rotors so the problem should be fixed. Didn’t help a bit and my husband was mad because at that point we only had 20k miles and they just cut our rotors life in half.
    I plan on just making a list of all of the services we have had, the ones they haven’t performed and ask them to try whatever they want because if it doesn’t fix the problem-it’s something more than the rotors.
    Unfortunately, it’s very significant and more than just a slight vibration. It’s so bad that it actually shakes your hands while holding the steering wheel. I also don’t think rotors would cause uneven tread wear on our tires. So bad that at 26k miles we need new tires. My husband takes very good care of this truck as you can see from the photo in my post.
    This is a serious issue to us because we have kept all of our Toyota’s long after they are paid off and planned to do that with this truck. But if it’s eating tires, brake pads, rotors and not even a nice ride-why pay $50k for a brand new pickup to have these problems? I could get a 1-2 year old truck for half the price and have a better ride.
  8. Nov 8, 2021 at 6:02 PM
    HartysTundra
    HartysTundra New Member
    Been reading a lot of these threads as I’m experiencing this same problem.
    2016 4x4 with 28k miles.
    Had vibration as I would break so I upgraded rotors to heavy duty slotted recommended by my mechanic. Shaking went away during breaking but now I have my steering wheel shake without breaking at 50-65mph.
    To add, I never changed my break pads as they had a lot of life left.
    Would new rotors cause something like this? Where do you recommend I start looking into to fix the problem.
    Thanks in advance.
  9. Nov 8, 2021 at 7:00 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome, @HartysTundra, from LA (Lower Alabama)! You found an old thread and revived it, which may not get a ton of responses. So if you don't get your answer here, you might try posting a new thread.
  10. Nov 8, 2021 at 9:06 PM
    plact88
    plact88 MGM SR5 CM
    Tucson, AZ
    2021 MGM Tundra Crewmax
    VLED Interior VLED Cargo Light VLED Reverse Light Driverside Grab Handle Bilstein 5100 front 2nd setting TRD Dual Exhaust Black Chrome AJT Chrome Delete TRD Air Filter Tyger Side Steps TVD Vinyl Decals MGM Tundra Radio Decals TVD Vinyl Decals MGM Tailgate Handle Decals Tundra Tailgate Badge Chrome Moto Metal 970 wheels 275/70/18 KO2 Tires TRD Rear Sway Bar MGM Door Handles and Mirror Caps TRD Pro LED Black Housing Headlights Black Housing LED Fog Lights AJT Black Door Handles AJT Black Steering Wheel Controls Tacoma Leather Steering Wheel Pedal Commander TRD Pro Hood Scoop 12 Volt Solutions Remote Start Clazzio Leather Seat Covers
    Welcome from AZ
  11. Nov 9, 2021 at 5:06 AM
    Retired...finally
    Don't overlook rust buildup on the rotors outside the pad contact area. A small ball peen hammer and dust mask are now part on my brake servicing tools Tap tap tap tap tap.....
    I learned this years ago after crossing a very rough RR crossing and a vibration immediately developed. Car was a 1981 Lancia. Dealer said it was bad CV joint. RR cut me a check and I started work finding the hard jolt knocked some of the rust off the one rotor. Chipped the rest off and test drove. BTW, The check was returned to the railroad.
  12. Nov 9, 2021 at 7:25 AM
    3jet3
    3jet3 New Member
    FL
    2021 Tundra TRD
    ----Suspension---- 6112 Bilstein Front 5160 Bilstein Back 3 CB .5" Shims(2 driver side, 1 passenger) CB 3+ Shackles Differential Drop kit Carrier Drop kit ----Wheels---- Tires - Falken WildPeak A/T- 295 70 18 Wheels - Raceline Gauge 18" ----Accessories---- GoRhino RB20 Running Boards
    Welcome! thanks for sharing!!
  13. Oct 3, 2022 at 4:30 PM
    2017 Tundra crew 4x4
    2017 Tundra crew 4x4 New Member
    Daniel
    2017 toyota tundra crew 4x4
    5 inch zone lift
    Chasing shaking in the steering wheel. Replaced rack. Relpaced inner and outer tie rods. Replaced upper and lower ball joints. Replaced tires. All made it better, but still happens every now and then at 60 mph. The rack still would move when the steering wheel was moved. Added a nut to the top of the rack, built a mount off of it to the frame. Replaced rack mounting bushing in the frame. Problem fixed. Solid as a rock. Hope this helps someone. I've been working on this truck for a while.
