New member + old truck + dead cylinder
Discussion in '1st Gen Tundras (2000-2006)' started by kirbotc, Oct 10, 2021.
  1. Oct 11, 2021 at 7:32 PM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Pics are mandatory. If you drop the pan and dont get pics of the naughty bits, we will heckle.
    bmf4069 likes this.
  2. Oct 11, 2021 at 9:47 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I think if it was missing the rings it'd be rattling like a 90s diesel, right? And if the valves were open when the piston came to tdc, that'd hit and make noise, right? I'm thinking a pan drop and look in the pan for pieces of piston.
    2mchfun and Sirfive like this.
  3. Oct 12, 2021 at 9:59 AM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    You can roll the engine over by hand using a wrench on the front of crankshaft watching the camshaft to determine what stroke you're on to get compression stroke with piston at top. While doing the rotation you can also watch the valve stems to make certain they are moving properly or since you got major problems, just pull the engine to give you access to disassemble for repairing, replacing or whatever you decide to do. It would be work toward final repairs.
  4. Oct 12, 2021 at 10:27 AM
    Going back a page since this still isn't solved. These are the winners:
    And here's why. Time is money, and while other suggestions in this thread are technically accurate and sound advice, some involve opening a can of worms when fishing isn't necessarily something we have time or money to support (words I hope my wife never learns). You can get a wild variety of bore scopes/endo scopes on A-Zon for under $100. Hell, there's even a few 2-3mpx versions for $50 or less that are Prime-eligible.
    Why is this the best solution? It checks a MAJOR box, and the only work required to achieve it is removing a spark plug. With one tool you can have as cheap as $35-50, or even borrow from a relative, you should know 100% if your piston head is chunked, maybe even if you have rings or drain-by problems. If you toss the scope on and find that is NOT the problem, THEN start doing the more rigorous and invasive stuff.
    K.I.S.S. applies here, and I'm not talking about the band.
    Desert Dog[QUOTED] and 2mchfun like this.
  5. Oct 12, 2021 at 11:27 AM
    Desert Dog
    Desert Dog Nobody rides for free
    2001 SR5 AC 2WD 4.7l
    Bilstein 5100's, SPC UCA's, ATS HD leaves
    Couldn't have said it better myself and exactly why I suggested it. I believe I've even seen 2-3mp borescopes on there for ~ $25-30 recently. For that low of a price one could use it once if that's all they wanted and sell it and recoup their money.
    shifty`[QUOTED] likes this.
  6. Oct 12, 2021 at 11:53 AM
    2mchfun
    OP should be able to get the piston to TDC and feel around inside the cylinder with a piece of wire to get an idea of the piston condition. Geez, you guys need more time with women.
    bmf4069, Desert Dog and shifty` like this.
  7. Oct 12, 2021 at 12:01 PM
    Hey, you may like sticking metal things in spark plug holes, I think I'll stick to poking the ladies with appendages. :rofl:
    2mchfun[QUOTED] likes this.
  8. Oct 12, 2021 at 12:17 PM
    Desert Dog
    I know at least 30 who would disagree. Besides, I want to see the target also. I'm weird like that. ;)
  9. Oct 12, 2021 at 12:17 PM
    2mchfun
    Just like in the bedroom OP, use your dipstick to feel around inside her.
    bmf4069 and shifty` like this.
  10. Oct 12, 2021 at 12:23 PM
    :yes: :rofl:
    MY MAN LIKES TO WAAAATCH! C'mon, OP! Don't disappoint us here! WE LIKE PICS @bmf4069
    bmf4069 and 2mchfun[QUOTED] like this.
  11. Oct 12, 2021 at 1:37 PM
    kirbotc
    kirbotc [OP] New Member
    2001 tundra
    Instructions unclear. Got finger stuck in radiator
    Bakershack, landphil, Tundra2 and 5 others like this.
  12. Oct 12, 2021 at 1:40 PM
    Desert Dog
    LMAO! I'm..."cultured", as @empty_lord would say.
    Seriously though, if there is a hole in a piston I would like to see it. Catastrophic failure gets my attention also.
    shifty`[QUOTED] and 2mchfun like this.
  13. Oct 12, 2021 at 3:45 PM
    kirbotc
    2001 tundra
    No real updates today. Shopped around for motors some, and did some more cleaning out the interior. Still trying to get the smell of mouse turds out.
    On another note, does it looks like it has a leveling kit or something? The front struts look fairly new, and it looks a little on the higher side to me. Just trying to get an idea what tires I’ll end up ordering
  14. Oct 12, 2021 at 3:46 PM
    kirbotc
    2001 tundra
    Destruction pics will come sooner or later, but seeing how cheap used motors are, I’ve just accepted I’ll be doing a swap, so I haven’t been in a big hurry to dig into it. It’s still running/movable now, so I’ll probably keep it that way until I have to motor to drop in.
    2mchfun likes this.
  15. Oct 12, 2021 at 5:49 PM
    kirbotc
    2001 tundra
    Wasn't really trying to spend any money right away, but my brother just sent me a running motor a few hours away for $350....
    Might just try and get that on sunday.
  16. Oct 12, 2021 at 5:52 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    :anonymous:
  17. Oct 12, 2021 at 6:35 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    350 is a hard price to pass on, even if you didn’t need it!
  18. Oct 12, 2021 at 8:14 PM
    kirbotc
    2001 tundra
    Well, it’s official, I just bought myself a motor. Picking it up Sunday evening. 300k miles on it, but it runs…. Kinda scary amount of miles, but the price was right, and I know these things can last forever. I’ll do the timing belt and water pump, and whatever gaskets it looks like it could use.
    Already got brand new coil packs, plugs and a starter from my old motor. Other than that, I’ll probably run a can of sea foam through it, and cross my fingers for another 300k.
    Didn’t plan on spending more money just yet, but hey. I bought the truck itself by accident too
    2mchfun and bmf4069 like this.
  19. Oct 12, 2021 at 8:18 PM
    #49
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    300k ain't scary.
    Sounds like you go a good plan. Keep us updated!
  20. Oct 13, 2021 at 3:41 AM
    #50
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Subscribed
  21. Oct 13, 2021 at 11:49 AM
    #51
    Someone on here posted wiser words than me on this topic recently: "It's a Toyota, not a GM, Dodge or Ford" (or similar)
    Big thing for you is this: Test as much as you can on the new engine when you get it. At least test for good compression on all cylinders. And I wouldn't swap the motor until you scope your current one to at least try to figure out if the piston, ring, or cylinder wall is mangled somehow. Then I'd also scope all 8 on the new one too :D
  22. Oct 13, 2021 at 1:53 PM
    #52
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    It's hard to say for sure, but it looks like there may be a spacer on the bottom of the coil
  23. Oct 13, 2021 at 2:24 PM
    #53
    2mchfun
    If it was mine, it would probably see a total bottom end rebuild before going in. Plus the other planned items.
    Since we are looking and discussing, kinda hard to know what springs those are and what rating. Secondly, no recent impact of bump stops on LCA. That tells me that OP might be blowing out a shock or two if they bottom before bump stop contact. Just sayin' OP should probably investigate a bit, might need some bump extensions.
  24. Oct 13, 2021 at 4:40 PM
    #54
    kirbotc
    2001 tundra
    I think there’s actually a couple relatively new parts on the front end. Upper ball joints look new. Lowers, not so new, but they’ve been greased recently. I’ll have to jack it up and see if I can shake things around a bit.
    Dont think it’s a spacer on the bottom. Might actually just be a stock replacement strut. I was comparing it to more pictures of stock Tundras, and I don’t think it’s as much higher as I thought.
    2mchfun likes this.
  25. Oct 14, 2021 at 8:33 AM
    #55
    rock climber
    Actually it look's like the Monroe (or some other knock off) replacement. I had those when I bought my truck and they were absolutely awful. They also use some weird coil that won't fit on anything else so you'll have to get new coils to replace them.
    bmf4069 likes this.
  26. Oct 14, 2021 at 10:27 AM
    #56
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I concur. Monroes are trash. I have them currently.
  27. Oct 15, 2021 at 8:42 PM
    #57
    kirbotc
    2001 tundra
    $350 later
    MS22, Luckydog, bmf4069 and 6 others like this.
  28. Oct 18, 2021 at 6:07 AM
    #58
    kirbotc
    2001 tundra
    I think today’s project is going to be getting my hands on an engine hoist…
    Didn’t have time over the weekend, and I don’t really wanna commute all week with a 500lb anchor in the back of my truck.
    landphil likes this.
  29. Oct 18, 2021 at 1:24 PM
    #59
    kirbotc
    2001 tundra
    Finally got it outta the taco, and started looking it over a little. Now to start ordering parts…
    landphil, bmf4069 and Sirfive like this.
  30. Oct 18, 2021 at 1:33 PM
    #60
    Sirfive
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Any drips on the pallet?
