New Member from UT
Discussion in 'New Member Introductions' started by The Utahn, Nov 18, 2020.
  1. Nov 18, 2020 at 10:08 AM
    The Utahn
    The Utahn [OP] New Member
    Longtime Ford F150 / F250 and Ram 1500/2500 owner here with my first Toyota, a 2021 Tundra Ltd, Crewmax Cement TRD. Sold my last Ecoboost after over 40 days in the shop the last year and a need for something more reliable.
    The truck has 380 miles as of today, and so far my only complaints are the mileage (worse than expected at 13.7 freeway at 70mph) and unloaded ride quality (much more choppy/bouncy on the freeway than even my last F250 and Ram 2500).
    Only mods so far are 35% ceramic tint on the front windows, VLeds inside and out (cargo and reverse), FRAC harness/camera and ESP underseat storage.
    I've been reading here for months on mods, but finally 'joined' today.
  2. Nov 18, 2020 at 10:08 AM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  3. Nov 18, 2020 at 10:09 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
  4. Nov 18, 2020 at 10:12 AM
    Doctor Flex
    Doctor Flex Just browsing...
    Utah
    2020 White 1794 TRD
    TRD Pro skid, Line-X, Tonneau, drivers grab handle, wireless charger, RB 20's, TRD Pro wheels, Gator Liners.
    Welcome from the northern Wasatch Front. Any pics?
    Also, my MPG averages about 16 combined. May just be breaking in. Or you have a lead foot like the rest of Utah;) :burnrubber:
  5. Nov 18, 2020 at 10:54 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  6. Nov 18, 2020 at 12:47 PM
    The Utahn
    I've been driving with an EASY right foot, and even inflated the tires to 38 which hasn't helped the ride quality. Averaging around 14 on the freeway at 70mph and 13.7 mixed. Hopefully it's just breaking in!
    Here is a photo upon pickup from the dealer. It's a loaded Limited with spray in bedliner, Predator side steps, TRD, sunroof, etc.
  7. Nov 18, 2020 at 1:00 PM
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    Welcome from a fellow Utahn :wave:
  8. Nov 18, 2020 at 1:07 PM
    CavGirl21
    CavGirl21 New Member
    Sheri
    Southern Wisconsin
    2021 Cavalry Blue Tundra Crewmax SR5
    Nice truck! Welcome from Wisconsin
  9. Nov 18, 2020 at 1:18 PM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    Welcome from Winston Salem NC. Just based on what I get on the highway which is usually 15-18 mpg, it seems like your mileage will pick up a bit.
  10. Nov 18, 2020 at 1:50 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  11. Nov 18, 2020 at 2:23 PM
    Welcome from Ohio
  12. Nov 18, 2020 at 2:53 PM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    Welcome from the southern end of the state.
  13. Nov 18, 2020 at 2:55 PM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    Greetings from over the "hills" in Colorado.
  14. Nov 18, 2020 at 3:31 PM
    RainMan_PNW
    RainMan_PNW SSEM #82 RGBA #4 “That Guy” Vendor
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA.
    I had the TRD offroad Bilsteins on my 2008 and found they were a bit stiff...but also was too cheap to ever change them. There are plenty of aftermarket options out there that can give you a little lift/level and soften things up a bit.
  15. Nov 18, 2020 at 3:41 PM
  16. Nov 18, 2020 at 3:44 PM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Welcome - also in Utah
  17. Nov 19, 2020 at 3:46 PM
    The Utahn
    Thanks for the warm welcome everyone!
  18. Nov 19, 2020 at 6:42 PM
    Green Thunder
    Green Thunder Smooth in the Cruise
    Washington
    2020 Burnt Green TRD Pro
    Food crumbs and dog fur
    Welcome from WA
  19. Nov 19, 2020 at 7:16 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Welcome fellow Utahn. It took me a year to fix the bouncy bed problem. I switched to the TRD Pro shocks (the Bilsteins are way to hard) and the deaver overload helper spring replacement. Deaver also recommended only torquing the rear shackles to 90 ft/lbs and red lock-tite. I think that made the biggest difference.
    https://deaverspring.com/product/ta...years-3-leaf-overload-replacement-1-1-2-lift/
    If I could do it over, I would just get this spring instead because I think the added anti friction pads would help especially in the winter.
    https://deaverspring.com/product/tundra-2007-2020-2wd-4wd-1-inch-lift-under-shackle-required-pair/
  20. Nov 20, 2020 at 9:04 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  21. Nov 22, 2020 at 7:11 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
