NEW MEMBER ALTO PASS IL
Discussion in 'New Member Introductions' started by mraymyers1967, Nov 9, 2016.
  1. Nov 9, 2016 at 6:17 AM
    mraymyers1967
    mraymyers1967 [OP] New Member
    michael
    2017 Tundra TRD PRO cement
    20x9 0mm offset XD 820 Wheels 295/55/20 Nitto Ridge Grappler 2 coach builder shims per side in front 1" ready lift rear block
    Hello, I just purchased a tundra trd pro a few weeks ago. It is my second Tundra but my first time checking out forums. The reason I started looking at forums is to see what others are doing as far as upgrades etc. I work on a river boat and went back to work just after purchasing my truck. So far I have read many discussions and taken the info toward upgrading my own truck. I ordered coachbuilder shims (which I had never heard of) to raise my front end 1" and a 1" block for the rear. I have ordered spidertrax 1,25 spacers to give me more offset with my stock wheels and tires, which by the way I would think Toyota should have put a more aggressive tire on an off road edition truck.
    My last truck was a '12 tundra with a 3-2 lift I ran 305/55/20 terra grapplers on 20x9 rims. I do not know the offset. They rubbed the mud flaps and I had to remove them. I plan to try to run about the same size but will go with a 305/50/20 this time around. "My big question" what offset should I go with on this setup?????? Thank you for taking the time to read my post.20161023_091912.jpg
    Law323 and TXMiamiFan like this.
  2. Nov 9, 2016 at 6:23 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome, I think you want the offset to be about +20 - + 30. Someone else with more knowledge will chime in though.
    mraymyers1967[OP] likes this.
  3. Nov 9, 2016 at 6:48 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    welcome...nice looking cement TRDP.
    The spidertrax spacers your ordered are going to make your factory wheels close to +20 offset. If you're planning on buying aftermarket wheels, you may not want to run those spacers. Normally, people shoot for a somewhere around +20 - +30 offset (as mentioned above) to get the tires flush with the fender. Those spacers would turn a +30 wheel to a 0 offset. I would suggest either just running the spacers on your factory TRDP wheels, or run no spacers and get aftermarket wheels.
    That 305/50/20 tire is 32"...that may look a little small, especially if you're planning on lifting it an inch more. Factory Tundras come with 32s. Your Pro is 2" higher in front, plus you're adding CB shims...so, your front will be 3" higher than factory Tundra. I think a lot of TRDP guys are running in the ballpark of 295/70/18, which is a 34" tire
  4. Nov 9, 2016 at 7:12 AM
    2011_Limited_tundra
    2011_Limited_tundra BOOM!!!!! That just happened....
    Erik
    Bay Area
    02 Cummins
    Leveling kit 35s on 20s
    Welcome to the tundra crew
  5. Nov 9, 2016 at 7:14 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    +20-+30 would be my vote. But I wouldn't get spacers also. Only get spacers if you're keeping your current wheels.
    But welcome to the site! She looks awesome. Can't wait to see it built up.
    Law323 and mraymyers1967[OP] like this.
  6. Nov 9, 2016 at 7:21 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO!
  7. Nov 9, 2016 at 7:27 AM
    14tundra
    14tundra On Wisconsin!
    WI
    2014 Platinum Crewmax 4x4 5.7L 1G3
    Welcome from WI! nice looking truck
  8. Nov 9, 2016 at 7:33 AM
    Welcome from CO!
  9. Nov 9, 2016 at 7:38 AM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Welcome!
  10. Nov 9, 2016 at 7:58 AM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    Love that color. Cant wait to see what yours looks like with the shims and block.
  11. Nov 9, 2016 at 8:00 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Welcome bud
  12. Nov 9, 2016 at 8:49 AM
    Welcome from CO. Like the cement color.
  13. Nov 9, 2016 at 8:57 AM
    mraymyers1967
    michael
    Thanks, I will run the spacers with the stock wheels until I put the aftermarkets on.
  14. Nov 9, 2016 at 9:58 AM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Welcome!
  15. Nov 9, 2016 at 10:13 AM
    thumper7799
    thumper7799 Bad Girls Drive Bad Toys!
    Erika
    2007 Nautical blue Tundra SR5 duel exhaust
    Welcome from Texas.
  16. Nov 9, 2016 at 11:08 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Welcome from TN!
