New LED headlights tundra pro style
Discussion in 'Lighting' started by bft305, Jan 27, 2020.
  1. Apr 2, 2020 at 3:08 PM
    #91
    bft305
    bft305 [OP] New Member
    2016 tundra limited
    Both high and low are LED, unless they changed they were $300 when I got them. So well under half the cost of the Morimotos. That is why I gave them a shot.
  2. Apr 5, 2020 at 8:59 AM
    #92
    TxTundracm514
    TxTundracm514 New Member
    Andy
    2015 Tundra Crewmax Limited 4X4
    Both high and low beam are LED. I have not had any issues with them, but I did have to put in the resistors, but you can pick those up at Autozone for around $15/$20 for the pair.
  3. Apr 5, 2020 at 9:51 AM
    #93
    bft305
    2016 tundra limited
    I to install the harness that came with them to run the drl light strips but didn’t have to install resistors.
  4. Apr 5, 2020 at 10:56 AM
    #94
    TxTundracm514
    Andy
    Okay, that probably works too. So I have a friend of mine who is a mechanic, so I took it over to his place a few weeks after I installed them, and my friend just charged me for the resistors, which he got at Autozone. So if I had used the parts that came with the lights, I might have saved $20. But overall, I love the lights and haven't had any issues.
  5. Apr 5, 2020 at 12:32 PM
    #95
    bft305
    2016 tundra limited
    @TxTundracm514 glad you like them and they worked out for you too! For the price I don’t think you can go wrong! I just didn’t want others to think they had to install resistors.
  6. Apr 5, 2020 at 12:35 PM
    #96
    lonelydriver
    lonelydriver New Member
    can anyone comment on the light output / shape and pattern vs the oem halogens vs the oem LED's ? i'm interested in upgrading, but definitely want an improvement in light output and pattern. I know oem invests a ton into the design of the headlights, and as cool as these look, want to make sure it's not just a cosmetic upgrade... tempting tho as they are less than half of what a oem trd pro led setup w/ harness would cost.
    GixxerSteve likes this.
  7. Apr 5, 2020 at 12:56 PM
    #97
    bft305
    2016 tundra limited
    I can only comment on these vs the OEM halogens. These are a big improvement over OEM halogens. I didnty post any pics of the halogens against a wall, since I was using high watt (blue painted) bulbs for a while so they were brighter than stock. The LED are definitely brighter than even the high watt bulbs. For the price I don’t think you can go wrong. I know some worry about longevity and go towards the OEMs. I don’t drive too much at night now that I have little kids, so I took the chance. Can’t tell you how to spend your money, but yes the light output is much better! Would be interested in hearing comments from someone who has the OEM LED.
    lonelydriver[QUOTED] likes this.
  8. May 12, 2020 at 4:46 PM
    #98
    mightyowl
    mightyowl New Member
    i had these and return them. They look great but the light beam was very dim for me. Ended up going with the pro series that has the projector. Put a 55w HID kit in and its way brighter
  9. May 13, 2020 at 4:04 AM
    #99
    bft305
    2016 tundra limited
    @mightyowl I am surprised to hear you say they were dim. I have not seen projectors with 55w HID kit, though I can imagine that is brighter! Can you post a pic of yours?
  10. May 28, 2020 at 12:45 AM
    #100
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
  11. Jun 24, 2020 at 2:13 PM
    #101
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    I have a '15 with stock halogens and the automatic amber DRL. I replaced the DRL with a set of VLED switchbacks, which basically still functions as a full-time DRL, but it uses a 5k white for DRL and switches to amber when the turn signal is activated. It looks like these headlights reuse the factory turn signal bulb, so it should be able to plug-n-play the turn signal? I'm guessing the turn signal will only function as a turn signal now and no DRL function since that's replaced by the LED bar? Hopefully that makes sense.
  12. Jun 24, 2020 at 2:29 PM
    #102
    bft305
    2016 tundra limited
    For mine everything functions as it came stock. I didn’t delete the amber DRL so everything should be normal. The harness you wire in just controls the led strips.
    kuokoa likes this.
  13. Jun 24, 2020 at 2:31 PM
    #103
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    how difficult was the wiring for the harness? (i'm terrible at wiring)
    both high and low are LED as well, correct?
  14. Jun 24, 2020 at 2:38 PM
    #104
    bft305
    2016 tundra limited
    @kuokoa not very hard. You will need a low profile wire tap with a 10amp fuse about $8 on Amazon. My directions are in this post just look back thru and you will find my post in reply to another guy on here.
    kuokoa likes this.
  15. Jun 24, 2020 at 2:46 PM
    #105
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    thanks! i went back through and found it. sounds pretty simple. the biggest plus for me is it's $325 shipped to Hawai'i. normally shipping anything here is $100 minimum :bananadead:
    bft305[QUOTED][OP] likes this.
  16. Jul 1, 2020 at 6:46 AM
    #106
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
  17. Jul 1, 2020 at 6:46 PM
    #107
    SpeshulED
    On the pro tuning site it says black housing but the photos show chrome housing.
  18. Jul 1, 2020 at 6:56 PM
    #108
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Yep, I had a set through the AlphaOwl brand, and the v2 at that, that supposedly fixed the issues. Those are more than likely AlphaOwls too.
    They major suck, the light output sucks, they're not good for night driving, the leveling and adjustment is jank. Anyone looking at them cause they look nice, that's all they have going for them. I recommend staying far away from them.
    There's a few threads on here about them.
    Ended up selling them at a very low price(buyer knew what they were and its issues) and bought a set of Alpharex NOVA headlights
  19. Jul 1, 2020 at 7:36 PM
    #109
    jmevis
    jmevis New Member
    Nashville TN
    2017 Tundra Trd Pro
    Oh no way! Hahaha ok thanks. I couldn’t find the brand name for them to do a search. Right now the Xb’s are looking pretty good.
  20. Jul 22, 2020 at 11:27 AM
    #110
    3Riv1
    3Riv1 New Member
    Travis
    2016 Tundra Limited
    Lift, Custom tires/wheels, Leer canopy, Chrome Step Rails, Short ant.
    Hello Tundra experts. I'm so glad I found this post but I'm still a bit confused on what to buy or what to use... I have a 2016 Limited TRD Crewmax. I didn't think trying to convert my OEM headlights into newer version with the LED DRL bar strip(s) would be so challenging but after talking with 3 different online parts companies (they all just told me to buy a single bulb for the look I wanted) it's evident there's more owners out there with the same questions... I now know there's isn't a magical bulb that I can replace to all of a sudden make an LED DRL strip appear so if someone could reply with whatever link would be best to simply pull out my entire headlamp unit and install a new one without a bunch of rewiring or trouble (if that exists), that would be so appreciated! I have some pics of my truck for ref. (current stock look). Again, I am wanting to mimic what the newer Tundra's headlamps look like with the LED DRL strips either at top of the lamp, bottom, or even the ones that go pretty much around the entire lamp unit itself. Again, thank you for any time you can give to me and my challenge.
  21. Jul 22, 2020 at 12:24 PM
    #111
    YorkT
    YorkT New Member
    Buy new light assemblies and wiring harness from Ihacker. He makes everything pretty simple to convert. Plenty of posts about this subject.
    3Riv1 likes this.
  22. Jul 23, 2020 at 10:52 AM
    #112
    3Riv1
    3Riv1 New Member
    Travis
    2016 Tundra Limited
    Thanks!
  23. Aug 1, 2020 at 4:34 PM
    #113
    SpeshulED
    On the VLand lights is there a way to disable the stock amber Turn signal/DRL light on a trick that didn’t come with oem led drl’s?
    I essentially want that light to either 1. Not be used at all since the LED DRL’s on the VLand lights are switchback or 2. Only turn on when using turn signal.
  24. Aug 3, 2020 at 10:45 AM
    #114
    SpeshulED
    Anyone?
  25. Dec 12, 2020 at 9:29 PM
    #115
    Rica25
    Ricardo
    Tulare
    Can I get an update i will be looking at replacing the spyder headlights on my 2008. How are this holding up for those that have had them longer than a year?
  26. Dec 12, 2020 at 9:40 PM
    #116
    Mf32
    Mf32 New Member
    2020 TRD Pro Super White
    Looks great
    Rica25 likes this.
  27. Dec 13, 2020 at 3:10 AM
    #117
    bft305
    2016 tundra limited
    Still working great for me, no leds issues, no condensation in the lenses. Light output is so much better than stock! One of the best mods I have done so far for the money!
    Rica25 likes this.
  28. Jan 23, 2021 at 7:31 PM
    #118
    GixxerSteve
    GixxerSteve New Member
    When I first saw these "Alpharex" lights I was in love. They look just like the 2018+ Sequoia lights and really modernize the older Tundras/Sequoias. But I also really like a good beam pattern with a clean cutoff, and all the pictures posted in this thread make the beam pattern look narrow. It looks more like spotlights than a beam that lights up the road. For looks I want to get these, but for performance I'm leaning towards the Alpharex Pros with a drop in LED. Anyone have any suggestions?
    BTW, new member here but been lurking for years. On my 4th Toyota.....2012 Sequoia Platinum.
  29. Jan 23, 2021 at 8:51 PM
    #119
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    Does the newer style pro headlights come with the amber DRL? I’m not a fan of the led look. Want the new headlights with amber drl
    Rica25 likes this.
  30. Jan 23, 2021 at 8:54 PM
    #120
    Yota707
    Yota707 New Member
    David
    Bay Area
    2015 Tundra TRD
    I enjoy this look vs the newer style but want the upgraded headlights
    Rica25 likes this.
