New LED headlights tundra pro style
Discussion in 'Lighting' started by bft305, Jan 27, 2020.
  1. Jan 30, 2020 at 5:59 PM
    #61
    bft305
    bft305 [OP] New Member
    2016 tundra limited
    @Beau if the color change makes your eyes go crazy why did you not go with HIDs for the low beam? Or at least some cheap high wattage 6000k (blue painted) painted halogens?
  2. Jan 30, 2020 at 6:10 PM
    #62
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2022 style
    I've got the racing vision lights which are some of the colder color halogens produced, while still maintaining some level of brightness although still not close to LED or HIDs. As far as the "why not get HIDs", I'm scared about condensation issues since I have only heard about issues from those that have modified their dust covers to accommodate HIDs and LEDs.
  3. Jan 30, 2020 at 6:27 PM
    #63
    bft305
    2016 tundra limited
    @Beau I hear you, I wouldn’t want condensation issues either! I had some some 80 watt cheap halogens before that were pretty close to LED, but your right they are not quite the same as LED.
  4. Jan 30, 2020 at 6:31 PM
    #64
    Beau
    Beau
    Mind sharing a link to them, I'll definitely check them out!
  5. Jan 30, 2020 at 6:44 PM
    #65
    bft305
    2016 tundra limited
    I had these but one burned out after about a year.
    https://www.amazon.com/CIPA-93443-F...eywords=evo+formance+h4&qid=1580438073&sr=8-1
    They did have a little too much scatter in their beam pattern in stock housings, but your projectors would probably correct that. Then I tried these
    https://www.amazon.com/gp/aw/d/B01MULV7LM?psc=1&ref=ppx_pop_mob_b_asin_title
    These lasted another year or so and had one burn out. That is why I finally took a chance on the new LED headlights cause removing the entire grill to swap bulbs is just a pain and such a dumb design! Hopefully these last at least a few years.
    Beau likes this.
  6. Feb 5, 2020 at 8:20 AM
    #66
    isuweller
    isuweller New Member
    I received these yesterday but there is no wiring diagram or information on how to wire the harness. Did you receive any instructions or did you just figure the wiring out on your own? I need some help. Lights look great in the box but would look better installed.
  7. Feb 5, 2020 at 3:43 PM
    #67
    bft305
    2016 tundra limited
    @isuweller i went to the alpharex website and they had an article on how to install the drl harness. Basically you need a low profile fuse tap with 10 amp fuse. In the fuse box there is a 10 amp fuse that is labeled “ign”. Remove the fuse and put the fuse tap in that slot. Then attach the brown wire to it from the drl harness. Red wire goes to the positive battery terminal and black to negative terminal. Then the shot side plugs into the small wire coming out of the light and then run the longer line to the passenger side light small little wire. All other plugs fit into the stock light plugs. I will try and find the link from alpharex.
    omgboost likes this.
  8. Feb 5, 2020 at 3:47 PM
    #68
    bft305
    2016 tundra limited
  9. Feb 5, 2020 at 4:04 PM
    #69
    bft305
    2016 tundra limited
    @isuweller If you need any other help then let me know and I can snap some pics. So far I have been very happy with these, you will have to adjust them a little bit but so far they have been great!
  10. Feb 5, 2020 at 7:57 PM
    #70
    isuweller
    @bft305 Thanks for your help! I decided to purchase these lights 100% based on this thread and successfully got them installed tonight. It was very easy once I read your explanation, so thank you! These lights look great! 20200205_214622.jpg 20200204_214015.jpg
    SpeshulED, EndoBuddy, FUNDR. and 10 others like this.
  11. Feb 5, 2020 at 8:12 PM
    #71
    Beau
    Beau
    The new ones look so much better!
    TheBeast likes this.
  12. Feb 6, 2020 at 4:40 AM
    #72
    bft305
    2016 tundra limited
    @isuweller they look great on your truck! Hopefully long term reliability is good for both of us! So far no moisture or led issues here!
  13. Feb 6, 2020 at 5:05 AM
    #73
    novae500
    novae500 New Member
    2016 Tundra DC SR5 upgraded package
    might have to jump on these for $300 not bad at all. Just hope the will last a few years without issues.
  14. Feb 6, 2020 at 7:12 AM
    #74
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    If you shop around for used parts you can get OEM 18+ LED’s for around that price. I got my used TRD sport lights for around $310 total. I trust factory lights way more personally. Those AlphaRex lights look great though.
  15. Feb 6, 2020 at 11:55 AM
    #75
    Beau
    Beau
    Was this from Ebay, or another avenue?
    #75
  16. Feb 6, 2020 at 9:21 PM
    #76
    300BLK
    300BLK New Member
    Yes one from was eBay, the other from this forums’s Marketplace. Lots of deals to be had, just have to be patient.
    #76
    Beau[QUOTED] likes this.
  17. Feb 10, 2020 at 11:26 PM
    #77
    TxTundracm514
    TxTundracm514 New Member
    Andy
    2015 Tundra Crewmax Limited 4X4
    I bought mine after seeing the reviews from the above comments. I feel like my light pattern is alll over the place, but this is my first time dealing with LED’s. Here’s the link to the ones I purchased: https://www.protuninglab.com/pro-jh-ttu14-lb-c.html
    Please tell me what you think.
  18. Feb 11, 2020 at 1:18 AM
    #78
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Doesnt look bad. Are they able to adjust the same as oem? Stick a phillips screw driver down in there and turn the adjustment gear. Raise the passenger beam height (or lower the driver side). They dont always come preset at the right height.
    cant tell if thats scatter in first photo, or if its just reflections of light from you being so close to the building.
    TxTundracm514 likes this.
  19. Feb 11, 2020 at 4:01 AM
    #79
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    You need to adjust them. They are way off. Pull up real close to a flat wall. Make a plus sign in tape in the center of the light pattern. Pull back 20-25ft and adjust until the centers are back at the tape. It takes a while to adjust and to figure out which way they are moving, but they will go.
    FUNDR. and TxTundracm514 like this.
  20. Feb 11, 2020 at 4:43 AM
    #80
    Beau
    Beau
    I agree with the others. The beam pattern looks good, just WAY out of adjustment.
  21. Feb 11, 2020 at 5:49 AM
    #81
    TxTundracm514
    Andy
    Thanks, I appreciate the advice!
  22. Feb 11, 2020 at 6:39 AM
    #82
    bft305
    2016 tundra limited
    I agree, just look on YouTube for a video about how to aim headlights. You will need tape and a tape measure and a flat wall. As mentioned you can use a Phillips screwdriver to reach down to the adjustment screw and adjust the beam. If I remember right clockwise raises and counter clockwise lowers.
  23. Feb 12, 2020 at 6:06 PM
    #83
    TxTundracm514
    Andy
    Bft305, how did you adjust your head lights?
  24. Feb 12, 2020 at 6:20 PM
    #84
    bft305
    2016 tundra limited
  25. Feb 12, 2020 at 7:08 PM
    #85
    TxTundracm514
    Andy
  26. Feb 13, 2020 at 5:47 AM
    #86
    Noojen
    Noojen New Member
    DFW
    2016 MGM Limited CM 4x4
    @bft305 how long did it take for you to receive your lights after placing the order? I have the factory halogens w/ the amber DRL, so if I got the same set as you all I'd need to buy is the fuse tap for the DRL harness & the rest is plug and play, correct?
    If I do the amber DRL delete it will still function as my blinker, right?
  27. Feb 13, 2020 at 9:52 AM
    #87
    bft305
    2016 tundra limited
    @Noojen it took about a week for me to get my lights. The company is out of CA and I am in ME. Yes all you will need is a low profile mini fuse tap (I got one off Amazon with a 10amp fuse and it has been working great). I am not sure on the amber drl delete, didn’t look into that.
  28. Mar 11, 2020 at 4:39 PM
    #88
    16 blue crewmax
    16 blue crewmax New Member
    Doug
    Richmond Virginia
    2016 Blazing blue pearl crewmax trd
    Any updates on these how are they doing
  29. Mar 12, 2020 at 4:30 AM
    #89
    bft305
    2016 tundra limited
    I am still happy with them and have had no issues.
  30. Apr 2, 2020 at 12:41 PM
    #90
    ckkone
    ckkone New Member
    SLC, UT
    So are the high and low beam both LED or just the low beam? For half the price of the Mornimotos these look great.
