New here and looking for some help
Discussion in 'New Member Introductions' started by TRDcrewmax16, Nov 14, 2018.
  1. Nov 14, 2018 at 5:21 PM
    TRDcrewmax16
    TRDcrewmax16 [OP] New Member
    16 black crewmax TRD
    Hey everybody, looking to get help and see if anyone has heard of my issue. Once this is resolved going to stick around and see what everyone does to their trucks! I have a black 2016 crewmax TRD 4x4 tundra which love btw. Anyways when I was towing a few months back, my ABS light and traction light came on and my speedometer would drop while was driving. Speedometer only does this when ABS light is on. Came on two times during that trip but just happened again the other day. Originally i chalked it up to an issue towing but nope, happpened again 3 months later. Light isnt coming back on after dealer said they were too packed to bring it in but have an appointment soon but wondering if anyone might know, appreciate all the insight, thanks.
    T-Rex266, Prostar 190 and Pinay like this.
  2. Nov 14, 2018 at 5:38 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!!
    Show us your ride!!!!
    TRDcrewmax16[OP] likes this.
  3. Nov 14, 2018 at 5:39 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    There’s lots of knowledge on this forum. I’m sure someone will chime in and help out.
    Inquiringone likes this.
  4. Nov 14, 2018 at 5:41 PM
    TRDcrewmax16
    20171222_183734.jpg Haven't done anything yet besides a cover for the bed.
    Prostar 190, TXMiamiFan and Pinay like this.
  5. Nov 14, 2018 at 5:43 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    That’s ok!! Show it off! Then we can see the transformation!
  6. Nov 14, 2018 at 5:46 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
    Hopefully someone will have an answer
  7. Nov 14, 2018 at 5:48 PM
    Rob371
    Rob371 New Member
    Rob
    Charlevoix, Michigan
    2007 Tundra Crewmax
    Steel bumpers front and rear,1.4" bilstien, KatSkinz Leather, rear airbags, halos.
    Does this only occur when trailer harness is connected?
    I've noticed with mine that sometimes if I plug the 7 pin harness while truck is running the VSC and ABS lights turn on. Key cycle and they turn off.
  8. Nov 14, 2018 at 5:49 PM
    TRDcrewmax16
    First time was towing, not sure if was just on the road or after a fill up. Other 3 times have not been towing
  9. Nov 14, 2018 at 5:51 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Im sure someone will be along shortly to help out.
  10. Nov 14, 2018 at 5:54 PM
    Rob371
    Rob371 New Member
    Rob
    2007 Tundra Crewmax
    So you get speedo innaccurate, abs light, and traction control light. sounds to me like a wheel speed sensor. I suggest getting a scan if it persists.
    Never hurts to clean power and grounds on the battery connections. Low voltage can cause all kinds of ghosts and doesn't cost you anything to try.
  11. Nov 14, 2018 at 5:56 PM
    Welcome from Texas
  12. Nov 14, 2018 at 5:57 PM
    Not one of the 4 ABS sensors wire clipped or broken sensor???
  13. Nov 14, 2018 at 5:59 PM
    TRDcrewmax16
    No, checked all the tires underneath. No wires looked messed up, everything looks good underneath. Dealer said it was going to run tests on each wheel checking the magnet distance on all tires.
  14. Nov 14, 2018 at 6:01 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. I'm guessing ABS sensor.
  15. Nov 14, 2018 at 6:03 PM
    TRDcrewmax16
    Heard it might be two different things but wont know until dealer takes it, should be warranty work
  16. Nov 14, 2018 at 6:04 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  17. Nov 14, 2018 at 6:13 PM
    Welcome from Ohio!
  18. Nov 14, 2018 at 6:24 PM
    T-Rex266 Moderator Staff Member
    Welcome. Wheel sensors dirty or frozen by chance?
  19. Nov 14, 2018 at 6:26 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    As others have mentioned I'm going with an ABS sensor going bad.
    Only real way to know what The Faults Are is to hook up a scanner.... I'm guessing AutoZone should be able to hook up to the brake module.
  20. Nov 14, 2018 at 6:26 PM
    TRDcrewmax16
    So its been forever since the light came on but it popped up after i went through a car wash. Washed it, went shopping then came on after start up
  21. Nov 14, 2018 at 6:27 PM
    TRDcrewmax16
    Unfortunately i didn't get to scan it and haven't seen it since but next time yes scanning for sure but have a few days until dealer looks at it
  22. Nov 14, 2018 at 6:53 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Welcome from East Tennessee
  23. Nov 14, 2018 at 7:45 PM
    Welcome from NY.
