New guy
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Bluetundra, May 31, 2024.
  1. May 31, 2024 at 2:51 PM
    2006Bluetundra
    2006Bluetundra [OP] New Member
    Amos
    Blue Quadcab
    none
    Just signed up. Hope to be a contributor, But I have many q's also.
    I have a 06 4 door quad cab. 139,000 miles in pretty good shape. like to do my own work, but I'm old and have joint problems, but I still do whatever I can.
    So far I've had, secondary air system replaced, ball joints, Brakes all around, air bag, left axle bearing, front shocks, and smaller stuff like plugs and battery.
    Presently I need lower control arm bushings which is masking clunking noises.
    One question I have is: anyone else have hard steering in parking lots? can't use one hand, need both hands to turn, its good while driving.
  2. May 31, 2024 at 2:56 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Usually one hand if moving slowly. Both if turning the wheel in place but it’s not impossible to do with one hand if necessary.
  3. May 31, 2024 at 6:27 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    Y'all got rack/PowerSteering issues. Or need to hit up the home gym
    i can use a finger at a stand still (probably not the whole 360, but a easy 180+)and my tires are chonky
  4. May 31, 2024 at 6:31 PM
    Jack McCarthy
    Bill
    North of Boston
    Yeah mine is definitely not that easy. Still works though.
  5. May 31, 2024 at 7:03 PM
    Welcome from NY.
  6. Jun 1, 2024 at 4:01 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    Please read and heed Shifty’s FGT megathread first. And it’s a double cab not quad cab.
  7. Jun 1, 2024 at 5:05 AM
    FishNinja
    Lee
    06DC2wd
    Whatever you call it. It's the superior cab.
    Kimosabe and abcinv like this.
  8. Jun 1, 2024 at 7:08 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  9. Jun 2, 2024 at 8:54 AM
    shifty` In South Dakota Trouble ain't hard to find
    You might want to test your power steering air control valve for functionality.
    Meanwhile, do yourself a huge f’ing favor and read this thread we collectively assembled: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Fair warning: Of you replaced lower balljoints, if you didn’t go OEM on that specific joint, you need to be aware of a phenomenal number of low-mile failures with aftermarket LBJ’s due to Toyota’s design, and aftermarket part supplier’s inability to make a an all-metal part that’s stout enough to handle the stupidly high amount of stress on the LBJ. More info on that in the megathread I linked.
    NickB_01TRD likes this.
