New (disappointed) Tundra owner
Discussion in 'New Member Introductions' started by ron4953, Jan 2, 2018.
  1. Apr 7, 2018 at 6:13 PM
    #121
    dj1961
    dj1961 New Member
    Dale proulx
    2018 blue tundra 4.6L
    This is to let every one know that I had A brake controller installed to day on my 4.6 L 2018 tundra and it is working just fine, they hard wire it in because you can not buy A after market wiring harness plug yet, its A tekonsha 90160 not the top of the line but I really like it. Installations unlimited in syracuse NY Installed it, I had to go there because I leased the truck. If you own the truck it would be better to take it to A RV place. It might not cost as much, the price for me was around $250.00..... So they can be installed.
    Bhebbert and driverdog like this.
  2. May 10, 2018 at 4:11 PM
    #122
    Bhebbert
    Bhebbert New Member
    2018 Tundra
    This is my first time on this board and I found this site because apparently I’m having the same issue as other people with the Toyota Tundra SR 4.6. Truck has the 7 pin connector on the back but apparently no trailer brake quick connect.
    I popped the panel off near the traction control and my truck does have an extra connector taped to the traction control connector, but not two like I have seen in other pictures. No big white one like what will fit most harnesses. This does not appear to be a plug and play for brakes, but possibly a tow haul connector. The manual shows the plug and play here... but I believe this is on the larger motor only. (Definitely not the SR 4.6)
    Contacted dealer and was told it had to be hard wired. This is not a surprise or a huge deal... but dealer quoted me $850. Lol. Called around to a few places that work on trailers and found a place here that will hard wire it in for very cheap.
    If you’ve found this site while searching for a harness... don’t get your hopes up... just call around and get it wired in like the last guy said and definitely safer than going without.
  3. Jun 6, 2018 at 1:50 PM
    #123
    gmagno
    gmagno New Member
    I cannot locate anything either. New OEM controller worthless regardless of what dealer told me upon sale.
  4. Jun 24, 2018 at 10:17 AM
    #124
    dPfadt
    dPfadt New Member
    Found the connectors (yes two) behind the glove box and passenger kick panel. I had to remove the glove box to get to both of the connectors to probe them. The connector behind the kick panel has the 30 amp constant hot coming from the fuse box under the hood (black wire) and the blue wire that goes to the 7 pin trailer connector at the hitch. That connector does not have the brake pedal wire in it though. The brake pedal wire is in the second connector just to the left of the first. The brake wire is also a blue wire on the factory side, but a much smaller gage wire. I did not want to cut into the factory harness, so I removed the pins from the Tekonsha adapter that I had purchased thinking it would work and inserted them into the factory harness connectors. Be sure to ground the white wire from your brake controller harness. I included a couple of pictures to help identify it's location and pins.
    BTW - I also secured the wires to the factory harness with zip ties so the connections would not inadvertently become unplugged.
    DKnight, Wvmoonshiner and fspor like this.
  5. Aug 11, 2018 at 10:46 AM
    #125
    fspor
    fspor New Member
    I tested the harness points documented in the pictures in post #126, and while my setup isn't as neat as @dPfadt's, it seems to be working perfectly for my Tek P3. Thanks so much for the clear pictures!
    Prior to doing this hookup, I reached out to tekonsha for some guidance and received an email that they WON'T be making a harness for the Tundra 2018, but they nicely sent me the attached tech tip.
  6. Aug 14, 2018 at 5:33 AM
    #126
    Bill891
    Bill891 New Member
    Bill
    Question about post #126. if I wire this way do I need to add fuse or circuit breaker? I'm also going to install the Tek P3
  7. Aug 14, 2018 at 5:52 AM
    #127
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Wait, we can add a tow/haul button to the 4.6L? And it will function?
  8. Aug 29, 2018 at 12:16 AM
    #128
    Wirenut
    Wirenut New Member
    Charles
    2018 Toyota Tundra 4.6L
    I’m so glad to find this thread. I’ve been wondering about all this. Thanks for all the info.
  9. Aug 29, 2018 at 4:26 AM
    #129
    Bill891
    Bill891 New Member
    Bill
    I wired like post #126 and use brake controller P3 tek and all is good. Took awhile to find a video on how to remove glove box.
  10. Aug 29, 2018 at 4:51 AM
    #130
    Ericsopa
    Ericsopa Old man and the sea
    In TX, the trailer brake requirement is determined by the trailer weight. Any trailer over 4500# requires brakes, regardless of weight of the tow vehicle. https://www.dps.texas.gov/cve/brakes.htm
  11. Aug 29, 2018 at 7:49 AM
    #131
    SKRAM
    SKRAM New Member
    Scott
    2018 TRD Sport Storm Trooper
    TRR Dual Exhaust TRD Air Intake Spray in bed liner BakFlip tonneau cover 2 Way remote starter. 3M tape on leading edges.
    That's a fact. First dealership I was at for my Tundra the guy knew nothing about it. I would expect them to know at least horsepower and torque numbers but he was not all that educated. So here's this guy (me) in his lot telling him about the the tower seals and picking apart everything that came out of his mouth. I like Toyota but he is still just some guy trying to do a job and that is definitely fallible.
  12. Aug 29, 2018 at 4:59 PM
    #132
    Wirenut
    Wirenut New Member
    Charles
    Quick question...will the Toyota dealer order the tow/haul switch for me or can I find it somewhere else? And what kinda price?
  13. Sep 5, 2018 at 7:29 PM
    #133
    DKnight
    DKnight New Member
    UPDATE
    So I decided to order the factory controller and it did plug right in and power up. However, the computer would not display the towing options on the vehicle information display screen at the cluster panel. I then had the dealer contact Toyota to see if they could program the computer to read the factory controller which plugged right in, and Toyota techs basically said that since it was a 4.6L the computer did not have the software to read the controller. They, Toyota, stated that the software is tied to the ABS and VSC, etc. etc. and that it's more complicated than just updating the software. So, I will be following through with a hard wire install and it looks like there has been some great post on how some have done it.
  14. Sep 5, 2018 at 7:36 PM
    #134
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME!!
  15. Sep 9, 2018 at 4:33 PM
    #135
    DKnight
    DKnight New Member
    Thank you!!! Hooked it up just like this and works like a dream! Not having to splice into the wiring of the stock harnesses is exactly what I was looking for. Thanks again dPfadt!
  16. Dec 25, 2018 at 4:12 AM
    #136
    1bad10tacoma
    1bad10tacoma New Member
    Mark
    2019 Tundra
  17. Dec 25, 2018 at 4:20 AM
    #137
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    If it has 7 pin connector in back it is definitely wired for brake controller. That is what the connector is for but buy a tekonsha and the adapter you will be all set
  18. Dec 25, 2018 at 4:32 AM
    #138
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    sorry for your bad deal, call a good lawyer, and BBB and your state attorney general office
  19. Dec 25, 2018 at 4:56 AM
    #139
    Adriver71x
    Adriver71x New Member
    Gerald
    2015 Tundra SR5
    Tow Mirrors
  20. Dec 25, 2018 at 5:03 AM
    #140
    grant1047
    grant1047 New Member
    Grant
    2017 1794 white
    Do what everyone is saying get a p3 and enjoy your trailer
    grant1047
  21. Dec 25, 2018 at 5:21 AM
    #141
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    Where in the world are all these new handles coming from? o_O
    Oh and never trust a salesman. Always do your own research
    Rex Kramer likes this.
  22. Dec 25, 2018 at 5:37 AM
    #142
    polymerhead
    polymerhead New Member
    Lol, this guy was active for 2 days a year ago and people are still giving him advice. The forum has put more thought into his purchase than he did.
    Brownsfanhere and tundracap like this.
  23. Dec 25, 2018 at 5:58 AM
    #143
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Sales people will say anything to get you to buy the vehicle, it's their job.
    Speak with parts & service personnel about specifics, and do your research BEFORE buying.
    aggie_tundra[QUOTED] likes this.
  24. Dec 25, 2018 at 6:03 AM
    #144
    aggie_tundra
    2021 2500 Custom
    I wouldn’t even trust parts and service folks at my local dealer. :rofl:
  25. Dec 25, 2018 at 6:07 AM
    #145
    Rex Kramer
    Georgia
    Mine are trustworthy & ethical ... lucky me.
  26. Mar 10, 2019 at 9:58 AM
    #146
    Barun
    Barun New Member
    2019 Tundra 4.6sr
    Hi Tundra guys,
    I'm nem member, just recently buy 2019 Tundra 4.6 sr and try to find a way to hook up Teknosha P3 control than I start reading your comments on electronic brake controlor, so I open panel on right driver site and found black small plug connector than open fuse box and find all relays and fuses already installed for brake controlor and haul and tow package
    I don't have buttons for tow and haul but I wonder can I add one? Thanks
  27. Mar 15, 2019 at 7:40 PM
    #147
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    I have a 2016 SR5 4.6 litter. I didnt Come equipped with a tow/haul button but had no issues towing a small big Tex trailer helping my brother move. I kept Speed limit to 60/65 mph and under 2,000 RPM. Do i really need a tow/haul button, what can i add Or how can i add A plug &play one? No too familiar with all this stuff or what the advantages are.
  28. Mar 16, 2019 at 1:21 PM
    #148
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    So when i removed the panel i found These two wires is one of these for the tow/haul ?
  29. Apr 20, 2019 at 11:43 AM
    #149
    1bad10tacoma
    Mark
    2019 Tundra
    Going to do this mod tomorrow, hope it works
  30. Jun 8, 2019 at 5:55 PM
    #150
    1bad10tacoma
    Mark
    2019 Tundra
    Thanks for sharing this, it saved me from pulling my hair out!
