New Cooper DISCOVERER RUGGED TREK?
Discussion in 'Wheels & Tires' started by Jsnake89, Jun 4, 2021.
  1. Jun 4, 2021 at 7:17 AM
    Jsnake89
    Jsnake89 [OP] New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    I’m the market for me tiered and came across these new tires form Cooper. But they seem to be brand new to the market and can’t find any reviews. Was wondering of anybody on here has bought them and had any feed back?
  2. Jun 4, 2021 at 7:19 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    On Tire Rack, I read three early reviews by buyers of this tire.
    Not a lot of miles but all three were happy with purchase.
  3. Jun 4, 2021 at 7:21 AM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  4. Jun 4, 2021 at 7:53 AM
    Jsnake89
    Dane
  5. Aug 13, 2021 at 8:06 PM
    FearTheBeard81
    FearTheBeard81 New Member
    2021 sr5 CrewMax 4wd cement
    I have a 2021 CM sr5 4wd with a stock height. Been eyeing the 275/60R20 115T. Have some 2018 platinum wheels I’d like to put on. Hopefully they fit with no mods or lift.
  6. Aug 13, 2021 at 8:12 PM
    Sarcastic Zword
    Sarcastic Zword What’s old is new again.
    Al
    U.S.A.
    2015 Tundra 5.7
    An acquaintance has them on an F150, albeit not very long. With that said, he’s been very happy with them so far.
    Good Luck!
  7. Aug 19, 2021 at 6:00 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I was looking at that size too. My problems with it is the width on a 10" rim and the 115 load rating. I haul some heavy loads at times and tow a heavy boat. The other concern for me is the max tire pressure. My TPMS is set at 46. Anything less and it lights up in cold weather. Others have suggested adjusting it but not interested in doing that.
  8. Aug 31, 2021 at 12:03 PM
    aroad4tundra
    aroad4tundra New Member
    Ben
    You need to adjust your TPMS tire pressure warning. Set your tires to 40psi and hit that TPMS reset button. Then air back up to 46psi. This way if it ever goes under 40psi, you will get your dashboard warning instead of 46. Just some cold weather will set that thing off. Very easy to adjust.
