New Battery, notable performance increase.
Discussion in '1st Gen Tundras (2000-2006)' started by toyoboyo, Aug 30, 2020.
  1. Aug 30, 2020 at 4:13 PM
    toyoboyo
    toyoboyo [OP] New Member
    I had a little over 2 years on my Super Start Platinum from O'reillys. I noticed a slow crank upon cold start with some light dimming... Ended up getting a replacement under warranty.
    Other than a very quick crank turnover and no light dimming, is it normal to feel smoother shifts and just overall a more smooth/linear pick up under normal acceleration? I noticed this after driving on the new battery after just one day.. Been three days now and she's smooth as can be.
    There's no HP difference but the transmission kick downs are much quicker, especially under heavy throttle...
    Just a neat discovery I thought I'd share. Anyone else?
  2. Aug 30, 2020 at 4:27 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    A happy electrical system can make a modern vehicle feel better for sure. Everything electronically controlled and batteries are used to help keep voltage stable when the engines running. So if your old one wasn’t great, it could of made things not work quite right
  3. Aug 30, 2020 at 5:53 PM
    A bad cell in a battery will drag the voltage and performance of the whole electrical system down. Also, swapping the battery is like a hard reset for the electrical system. Some parameters are reset and may behave differently such as shift points. Enjoy the smoothness!
  4. Aug 30, 2020 at 5:59 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    ECU has been reset. It will feel different for a bit.
    CodyP and FirstGenVol like this.
  5. Aug 30, 2020 at 8:05 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It's the "placebo" effect. Defies explanation by science or the supernatural. Big load off your mind = happy truck driving better. :homer:
    bokch0y likes this.
  6. Aug 30, 2020 at 10:35 PM
    toyoboyo
    hahaha, it's not fools gold. It's night and day. No more strange lugging and strange power surges under load (no it's not the VVTI). The old battery was bulging too.
  7. Aug 31, 2020 at 4:26 AM
    Professional Hand Model
    Hand Protectors
    Stoked for you!
    Electrical Optimization does wonders for an engine. Things work smoother and last longer. The Reset may be part of what you are noticing, but a fresh battery thats hooked up nice and tight with conductive grease is Nirvana. Adding in some Redundant Ground Wires to help the current flow is another plus.
    One step farther, you could clean up all your Existing Grounds in your Engine Bay. It would only cost you a few hours work and a small piece of sand paper and small tube of Electric Grease.
  8. Aug 31, 2020 at 4:33 PM
    toyoboyo
    Good to know.. Now I realize why others used to do copper wire upgrades in the past. I normally slap the battery and go, which is what I did. It was not until the next day which it got my attention by surprise.
