New 2019, 1794 owner
Discussion in 'New Member Introductions' started by rockmup, Nov 10, 2019.
  1. Nov 10, 2019 at 11:10 AM
    rockmup
    rockmup [OP] New Member
    Todd
    Greenwell Springs LA.
    So I found one 40 mi away that was what I thought was a smoking deal. 2019 with 1240 miles on it for 44,500 +TTL Original sticker msrp of 56,500. Has factory bed cover. Really stoked to have found this deal. Certified CPO truck.
    First question, how to set up the folding mirrors to fold then you lock the doors ?
    Second question, How do you fold the panel next to the cab back ?
  2. Nov 10, 2019 at 1:26 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Sounds like a great deal! I don't think there's a way to get the mirrors to autofold on lock ... gotta push the button before you turn off the truck. Not sure which panel you're referring to in the 2nd question.
  3. Nov 10, 2019 at 1:36 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    If it's a OEM tonneau, you can't get the last panel to fold. It on only folds 2 panels. Looked at the factory and that was a big factor for me going with another type when I bought mine recently. But the OEMs are quite solid and don't leak. Guy I know stands on his sometimes. No way in well I would do it on my MX4
    Pinay likes this.
  4. Nov 10, 2019 at 1:38 PM
    abomb60
    Massachusetts
    Ah I get it now :) Yeah mine has the oem cover as well and the last panel doesn't fold. It does have 2 cables you can pull on the ends by the cab to remove it though.
  5. Nov 10, 2019 at 1:54 PM
    rickc5
    rickc5 New Member
    Rick
    2019 Grey Tundra Platinum
    Rock Warrior Wheels
    My OEM tonneau was installed by the selling dealer and while I find it sturdy, it leaks like crazy above the tailgate when I use the car wash.
  6. Nov 10, 2019 at 2:29 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Tail gate seals maybe? I put some on mine and it cut that out. tailgateseal.com. They have to drain at the tailgate but try to make a seal where each side drains beyond the seal so it doesn't get in the bed. It's been a drought here so not much rain but a 1/3 of the bed sticks out from under the carport with the rear sitting lower had some good soakings. I've would guess that I'll find a cup of water in the entire bed. I got the OEM bedmat and anything sitting on it would never get wet.
    I really liked the OEM cover and sure you can fix it right up. The 2/3 fold and the price sort of turned me off
  7. Nov 10, 2019 at 2:50 PM
    rockmup
    Todd
    Thanks for the info on the cover, I assumed since the previous years had they'd just changed the way it did it. Bummer
    Nothing on the mirrors ?
  8. Nov 10, 2019 at 2:57 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Welcome from SoCal!
  9. Nov 10, 2019 at 3:03 PM
    Welcome from NY.
  10. Nov 10, 2019 at 3:21 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Too new for me to help. Nice ride. Welcome from NE Pa
  11. Nov 10, 2019 at 3:32 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!!
  12. Nov 10, 2019 at 4:00 PM
    Welcome from Colorado
  13. Nov 10, 2019 at 4:48 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Y0TA PR0 likes this.
  14. Nov 10, 2019 at 5:11 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  15. Nov 10, 2019 at 5:55 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  16. Nov 10, 2019 at 7:18 PM
    Mcoop
    Mcoop Throbbing Member
    Michael
    Berlin, NJ
    2015 Black SR5 5.7L DCLB 4x4
    Welcome from southern NJ.
  17. Nov 11, 2019 at 5:26 AM
    db52282
    db52282 New Member
    David
    Georgia
    2017 Silver Tundra Limited
    Welcome from Georgia.
  18. Nov 11, 2019 at 5:28 AM
    db52282
    db52282 New Member
    David
    Georgia
    I don't have an OEM tonneau and it leaks a small amount at the tailgate (on the ends). Otherwise it is dry.
    I think this is common with most of the "flush" tonneau's that are made for the Tundra.
  19. Nov 11, 2019 at 5:48 AM
    18" TRD Off Road Wheels
    Sounds like a killer deal on the truck. I believe @abomb60 is correct about the mirrors. You have to hit the button before you exit.
  20. Nov 11, 2019 at 5:52 AM
    rockmup
    Todd
    So I push the button before getting out and they don't fold when I lock the door either on the door or with the FOB.
    They do fold when I get back in and start the truck though, lol wth ?
    I've built a couple 4runners through the years but this is the first Toyota that I've ever owned
  21. Nov 11, 2019 at 5:53 AM
    That's odd. You are hitting the button before you turn the truck off, right? They should fold when you hit the button, and then you just shut it off and lock like normal.
  22. Nov 11, 2019 at 6:01 AM
    rockmup
    Todd
    Yes Sir.
  23. Nov 11, 2019 at 4:21 PM
    trinituner
    trinituner New Member
    Andron
    Orlando, Florida
    2017 Silver 1794
    Welcome from Florida, Great buy
  24. Nov 11, 2019 at 4:43 PM
    Pete1794
    Pete1794 New Member
    SC
    2019Tundra1794
    All stock
    Welcome from South Carolina.
  25. Nov 11, 2019 at 5:53 PM
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    Welcome from Western Massachusetts
  26. Nov 11, 2019 at 5:55 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    Welcome from CT
  27. Nov 11, 2019 at 6:02 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Your mirrors MAY be addressed through what's called the " convenience entry/exit" function which is only changed via laptop/reader/programmer. There are a few things there that I turned off, but I remember there being some things that could be enabled too. I think a list is in the owners manual of what is addressable , maybe the mirrors? I believe only Platinum and 1794 editions have this feature.
  28. Nov 12, 2019 at 8:46 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  29. Nov 12, 2019 at 9:02 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome aboard
  30. Nov 12, 2019 at 10:01 AM
    rockmup
    Todd
    I'll take a better look at that, thanks.
    Toyotoholic[QUOTED] likes this.
