New 2014+ ARB Summit Bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by Black Wolf, Aug 20, 2018.
  1. Mar 1, 2021 at 1:08 PM
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    How much further does it stick out, compared to the factory bumper? I have length limitations in my garage and am trying to see what it'd be like with one of these installed.
  2. Apr 25, 2021 at 9:29 AM
    BeachTundra19
    BeachTundra19 New Member
    Zak
    2019 Tundra Platinum "Silver Sky Metallic"
    None Yet
    Attached the specs It states it adds 7.3 inches.
    The Tundra Winch Bumper does not come pre-drilled. The drilling template is provided.
    Protection & Styling Characteristics:
    • Registered design of styling and components
    • Durable steel construction for maximum protection
    • Incorporates ARB’s renowned multi-fold upswept and tapered wing design for optimum strength and approach angle
    • 30mm radius on wings and center section
    • Engineered, air bag compatible mounting system secures to the chassis via high tensile bolts
    • Split pan design for maximum strength and airflow
    • Three-piece grille design for split pan
    • Extensive protection panels on center and either side (pressed form top pan and aluminum (powder coated black) winch cover panel)
    • Twin jack points located beneath each buffer for optimum strength
    • Durable two-piece buffers
    • Includes ARB LED indicator and driving light
    • Will accommodate Warn low mount model electric winches up to 12,000lb
    • Provision to accommodate ARB Intensity AR21, AR32, AR40 and IPF lights
    • The standard ARB fog light kit is included in 3415020K
    • Provision for optional ARB fog light covers part no 3500680
    • Provision for optional summit roller fairlead cover part no 3500850
    • Bumper adds approximately 7.3in to the overall length of the vehicle
    • Approximate weight of the bar, chassis mounts and fitting kit is 205 lbs
    • Zinc rich primer for additional corrosion resistance
    • Finished in Integrit™ , textured black powder coat
    AggiePhil[QUOTED] likes this.
  3. Jul 27, 2023 at 4:44 PM
    koditten
    Kirk
    Midland of the Mitten
    Wow! The last update was April 21.
    I guess I'll look for a more active thread.
