New 07-13 Spyder's just ordered....
Discussion in 'Lighting' started by JerseyTundra1260, Mar 22, 2018.
  1. Apr 4, 2018 at 6:53 AM
    #91
    JerseyTundra1260
    JerseyTundra1260 [OP] 08 Silver streaking!!!!!
    Marc
    New Jersey
    08 Silver Tundra DC Limited 4x4
    Too many to list.....
  2. Apr 4, 2018 at 6:57 AM
    #92
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Marc that's tight:thumbsup: Definitely an option for me going fwd. I read on Spyders website that installing hids or less voids the warranty, which I'm not to concerned. Are you running hids?
  3. Apr 4, 2018 at 7:10 AM
    #93
    JerseyTundra1260
    Marc
    New Jersey
    Currently running what came with. Would like to get the vleds LED micro h1's eventually. They told me I may have to get a bigger dust cap to compensate for the extra three quarters of an inch that the fans take up on the back of the vleds
    http://www.vleds.com/shop-bulb-numbers/h1/micro-h1.html
  4. Apr 6, 2018 at 2:13 PM
    #94
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    64853A0B-E9A4-49BA-868A-CADEA0965663.jpg B317B553-D2A5-4834-B377-8EDE99A5283A.jpg Opinions needed
    With or without the new V2 spyder ?
  5. Apr 6, 2018 at 2:58 PM
    #95
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    I'm biased but I think the V2's look pretty solid
    TheBeast likes this.
  6. Apr 6, 2018 at 3:23 PM
    #96
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    Morimoto H1 kit installed today. I'll post up some night shots later.
  7. Apr 6, 2018 at 5:58 PM
    #97
    JerseyTundra1260
    Marc
    New Jersey
    :popcorn:
  8. Apr 6, 2018 at 6:54 PM
    #98
    Theyfzman
    Pa
    08 TRD
    Steve did the hid kit help ?
    I’m pretty sure I’m doing the same thing
    And are your cut offs even ?
    I’ll take a picture of mine it seems like the projector is almost twisted a bit
  9. Apr 6, 2018 at 6:59 PM
    #99
    Theyfzman
    Pa
    08 TRD
    See how they kind of tilt upwards on the outsides or is just me ? 37D1C802-9C82-493B-B858-A97D904C3F85.jpg
    Mountun Goat and drumzdj like this.
  10. Apr 6, 2018 at 7:28 PM
    #100
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
  11. Apr 6, 2018 at 7:28 PM
    #101
    Les7311
    Mine does the same.
  12. Apr 6, 2018 at 7:31 PM
    #102
    JerseyTundra1260
    Marc
    New Jersey
    Mountun Goat and Les7311[QUOTED] like this.
  13. Apr 6, 2018 at 9:43 PM
    #103
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    Mine look like yours. Slight angle but clean. The HID kit made a huge difference.
    Just the DRL strip
    Just the driver side low. Driveway is sloped
    A couple out on the road
    Mountun Goat and TheBeast like this.
  14. Apr 7, 2018 at 9:27 AM
    #104
    JerseyTundra1260
    Marc
    New Jersey
    What kit did you use ?
  15. Apr 7, 2018 at 2:09 PM
    #105
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    Gtfour43 likes this.
  16. Apr 7, 2018 at 2:47 PM
    #106
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I'm usually not a fan of retros, but those look really good.
  17. Apr 7, 2018 at 4:34 PM
    #107
    JerseyTundra1260
    Marc
    New Jersey
  18. Apr 7, 2018 at 7:02 PM
    #108
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    I had them installed. Took the shop about two hours. Yes, much better. It's only been a night but I would recommend them. There's more pics in my build thread.
  19. May 10, 2018 at 6:57 PM
    #109
    mkmarz
    mkmarz New Member
    I'm having trouble finding the spyder 2.0's online. On top of that, there's limited information on spyder's site about the 2.0 vs the 1.0s which has a lot of info.
  20. May 10, 2018 at 7:16 PM
    #110
    JerseyTundra1260
    Marc
    New Jersey
    https://www.boss4x4s.com/
  21. May 10, 2018 at 7:19 PM
    #111
    JerseyTundra1260
    Marc
    New Jersey
    They were $315 when they just came out on a special . Talk to Darren. He is a great guy with great prices. Generally beats any price I have seen.
  22. Jan 25, 2019 at 9:21 PM
    #112
    Cgonz9584
    Cgonz9584 New Member
    Carlos
    2010 Tundra DC RW
    Beautiful truck...
    What did you do to make your spyders work?
    I have a wiring issue. What does this connect to?
    I have two remaining connections that dont have anywhere to connect to on the headlight.
    Mountun Goat likes this.
  23. Jan 26, 2019 at 6:01 AM
    #113
    JerseyTundra1260
    Marc
    New Jersey
    They are plug and play..... Unplug your factory side marker bulb and it plugs into the connection there. Make sure you have it in the right way where it won't light up if it doesn't you just need to spin around and then light up from what I remember. Unfortunately don't have the truck anymore sold it 7 months ago. Good luck
  24. Jan 26, 2019 at 6:31 AM
    #114
    Cgonz9584
    Carlos
    2010 Tundra DC RW
    My side marker plug looks like this and the connector from the headlight in the picture from before wont connect to that.
  25. Jan 26, 2019 at 8:05 AM
    #115
    JerseyTundra1260
    Marc
    New Jersey
    Are these the new version Spyders or the old?
  26. Jan 26, 2019 at 8:53 AM
    #116
    Theyfzman
    Pa
    08 TRD
    You don’t unplug the wire from the socket you take the bulb out of the socket and then plug the Spyder wire into that
    Make sense ? You need to take the old socket out of your headlight
  27. Jan 26, 2019 at 8:56 AM
    #117
    Theyfzman
    Pa
    08 TRD
    And before you button every thing up double check the light adjustment mine low beam was off and once the headlight is in you can’t get to the adjusters you can get the high beams are reachable but not the lows you need to take the head light out guesstimate where it needs to go then recheck kind of a pain in the ass
  28. Jan 26, 2019 at 2:36 PM
    #118
    Cgonz9584
    Carlos
    2010 Tundra DC RW
    These are new gen spyders..
    And i dont get what you are saying, i already removed a bulb from original headlight and put it on this one.
    There is still the loose wire that im pointing out that i have no connection for.
