Neutral Safety Switch
Discussion in '2.5 Gen Tundras (2014-2021)' started by FIN, Aug 16, 2018.
  1. Aug 16, 2018 at 5:30 AM
    FIN
    FIN [OP] New Member
    Gerald
    2014 Toyota Tundra SR5
    Attepting to replace Neutral safety switch and to the point everything is loose but its not sliding off all the way. I dont want to apply to much pressure, shouldnt it come right off?
  2. Aug 16, 2018 at 8:17 AM
    15whtrd
    15whtrd Mr. Blonde
    Hmmm. Wonder if the truck needs to be in neutral. Or switch clocked to remove. How do you know it needs replacement.
    Oh and welcome to the forum!
  3. Aug 16, 2018 at 10:00 AM
    FIN
    FIN [OP] New Member
    Gerald
    I have it in neutral, followed the instructions from Chilton and Haynes manual. Its sliding out about an inch then stopping at the edge of the threads.
    Thanks for the warm welcome!
    15whtrd and NewImprovedRon like this.
  4. Aug 17, 2018 at 4:56 AM
    Danquoia
    Danquoia New Member
    2005 Sequoia
    None
    New member and following as I'll be doing this fix soon.
  5. Aug 19, 2018 at 6:56 AM
    FIN
    FIN [OP] New Member
    Gerald
    Finally was able to remove Neutral Safety Switch. The threads on the nut to transmission clamp down around selector that sticks out of transmission. You have to pry the slots of the switch to open them up enough to slide over the threads. Fixed my issue, P0705, money light(check engine). Drove it 2 days, no issues, works great.
    Dracko, bulldog93, Sunnier and 2 others like this.
  6. Aug 19, 2018 at 7:01 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Glad you got it fixed. Pictures?
    15whtrd likes this.
  7. Aug 19, 2018 at 9:29 AM
    Sunnier
    Sunny
    San Diego, CA
    Welcome from SoCal! Glad you worked that out. :)
  8. Aug 19, 2018 at 10:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Yes definitely thanks for the update. Curious for some pics and a little more detail on what happened. As it’s possible this could happen to my 15.
    gosolo likes this.
  9. Aug 25, 2018 at 10:02 PM
    FIN
    FIN [OP] New Member
    Gerald
    I would recommend spraying it with PB Blaster over couple days before attempting to remove it. Also I found some helpful info too, while the Neutral Safety Switch is off, be careful and not shift the gear shift inside, it will cause some sping inside the transmission pan to come off gear selector, then you have a big mess. It was a TSB issued after several made the mistake.
    bulldog93 and Infidel19K like this.
  10. Feb 13, 2023 at 3:38 PM
    Scotty275
    Scotty275 New Member
    scott
    2008 Tundra crewmax
    what year was your truck? I just bought a new switch to put on my 2008. It was slipping out of gear and hard to put in park and drive. happy to find out it was just this switch and not a transmission issue. Im worried about stripping the nut on the end of the shaft as it is very rusted. (thanks canada)
  11. Dec 22, 2023 at 8:13 AM
    Harveyparty
    Harveyparty New Member
    2015 Tundra
    None
    Had check engine light….diagnosed to an electrical issue inside the switch. Dealer broke the shaft removing it. Told me it could happen and if it did then I might need a new transmission. They are trying to “make it work” but I don’t like it
