Netmonkey's build thread
Discussion in '2.5 Gen Builds (2014-2021)' started by Netmonkey, Apr 1, 2017.
  1. May 10, 2019 at 9:28 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
  2. May 10, 2019 at 9:45 AM
    LiftMeUp
    LiftMeUp New Member
    Sorry, taking info from to threads. Yeah, I have the same wheels as you. I was referring to the reply you had mentioned about the limited wheels not having a problem with clearing the UCAs on the 275s. Wasn't sure if the offset on the Limited and our wheels were the same.
  3. May 10, 2019 at 9:48 AM
    Netmonkey
    Georgetown, TX
    they are different.
  4. May 10, 2019 at 11:03 AM
    LiftMeUp
    LiftMeUp New Member
    Let me ask you this. As mentioned I have factory wheels so not as familiar with offsets, but which set would be better with regards to clearing the UCAs? I don't want to go the route of spacers and don't have plans for new wheels. But thought about either keeping my set of landing a pair of the limiteds.
  5. May 11, 2019 at 3:44 AM
    Netmonkey
    Georgetown, TX
    the lower the offset, the farther that the wheel will stick out from the truck and the father from the UCA it will be. if you do not want to run spacers or get new wheels, then you are limited as to the size of the tire that you can run. as said before, with a 20x8 +60mm offset (your wheels), the widest tire that you should go with is a 285. however, if you do get new wheels, i recommend a 20x9 with either a +18 or a +25 offset (which are very common offsets), then you can run any tire that you want.
    LiftMeUp[QUOTED] likes this.
  6. May 11, 2019 at 7:42 AM
    LiftMeUp
    LiftMeUp New Member
    Thanks!! As long as I can get away with a 285 with my current wheels, then that will give me some time to find ones I like and save some pennies and get the size you mentioned. Perfect!!
