Nerf bar repair?
Discussion in 'General Tundra Discussion' started by dutchd20, Mar 19, 2018.
  1. Mar 19, 2018 at 2:21 PM
    dutchd20
    dutchd20 [OP] New Member
    So I banged up one of my bars (N Fab brand) on an invisible boulder and I'm looking for some advice. The bar itself still has 100% integrity, however the impact bent all 3 brackets which in turn twisted the bar counterclockwise badly enough that I either want it repaired or replaced. Here's what I feel my options are from best to worst..
    1) Uninstall bar and hopefully a welder can remove, straighten, and re-weld brackets? Could be pricey
    2) Uninstall bar and have the Incredible Hulk bang the brackets with a rubber mallet to straighten?
    3) Re-order an entire new set (which I would have to order both bars and spend approx $575)
    4) Leave as is which will eat away at my core knowing they are bent.
    Attached is a photo of one of the brackets on the underside of truckIMG_8860.jpg
  2. Mar 19, 2018 at 4:25 PM
    If it were me, since I have the tools to do, Option 2
  3. Mar 19, 2018 at 4:36 PM
    Vizsla
    Vizsla ☠️☠️☠️
    You can bend them back, they are mild steel, that’s why they bent. Probably have to touch up the finish after, may damage from bending. If you find invisible boulders, I suggest real sliders. Recently got sliders, had no idea, did a run with a bunch of switchbacks and not caring about rockers and doors is helpfull.
    Mountun Goat likes this.
  4. Mar 19, 2018 at 5:07 PM
    dutchd20
    Thanks for that info, very helpful
    NickyF25 likes this.
  5. Mar 19, 2018 at 5:16 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I would do number one. Mild steel will inevitably fail again. If it were me I’d make friends with a welder real quick haha.
  6. Mar 19, 2018 at 5:17 PM
    dutchd20
    thanks for the suggestion!!
  7. Mar 19, 2018 at 5:34 PM
    SnowroxKT
    SnowroxKT New Member
    Kyle
    Alaska
    Yeah bend them back then shoot them with some black paint. I got my nfabs used and had to do this exact process and they turned out great. The wife doesn't even know which side was bent.
  8. Mar 19, 2018 at 5:42 PM
    Vizsla
    Vizsla ☠️☠️☠️
    They need to bend, or they will destroy the floor of the cab. Bend them back and forget about it.
