Nerf bar plastic step removal
Discussion in '2.5 Gen Tundras (2014-2021)' started by Donkeypunch, Jan 10, 2019.
  1. Jan 10, 2019 at 2:14 PM
    Donkeypunch
    Donkeypunch [OP] New Member
    Anyone try to remove and replace the plastic step on the Toyota factory nerf bars?
    I am chrome deleting, so I bought a set of used black nerf bars that I will need to repaint. I want to transfer the new plastic steps from the chrome nerf bars over to the used ones I purchased and will repaint.
    How to I remove the plastic steps without destroying them?
  2. Jan 10, 2019 at 2:47 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    If you have the wide, oval steps I'm not sure about removing the pads. If you have the 3" round nerf bars that long pad will be tough to remove. That pad has a bunch of plastic posts underneath it that are held to the bat with barrel retainer clips. The posts will almost certainly snap off when you try to pull them up. If you do save the post, you'll need to replace the barrel clips.
    Adriver71x likes this.
  3. Jan 10, 2019 at 2:59 PM
    Donkeypunch
    I have the oval steps. :-(
  4. Jan 10, 2019 at 3:07 PM
    Donkeypunch
    Anyone know who is the manufacturer of the oval factory nerf bars? They look like Westin.
  5. Jan 10, 2019 at 4:00 PM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Donkey punch, haha, haven’t heard that since high school. nice.
    15whtrd and Donkeypunch[OP] like this.
  6. Jan 10, 2019 at 4:49 PM
    zebian2
    zebian2 New Member
    Jamy
    I’ve a set of the oval boards
    One plastic step cover is alreyoff
    I’ll look,inspect and report back
    I believe the tabs will snap off ( break)
  7. Jan 10, 2019 at 6:10 PM
    Donkeypunch
    That would be helpful to show the locations of the tabs. If the tabs break, there is nothing Gorilla glue can’t fix.
  8. Jan 10, 2019 at 9:08 PM
    zebian2
    zebian2 New Member
    Jamy
    No worries.
  9. Jan 11, 2019 at 9:52 AM
    zebian2
    zebian2 New Member
    Jamy
  10. May 4, 2021 at 11:34 AM
    SheChirple
    SheChirple New Member
    Mary
    2013 Tundra Black
    Over bed Kayak racks, e-brakes for trailer, tow package, heavy duty tow hitch
    Reviving this post - two of my 4 pads have snapped off. The pads themselves are also broken. Can you replace just the pads? If so, where can I find them? Dealer says you have to replace the entire rail $$$.
  11. May 4, 2021 at 12:59 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I was in the same boat earlier this year. Wanted to redo the step pads and repaint. If you can find replacement pads, (big if) they are costly. To get replacement pads for my Aaries steps would cost almost as much as buying new full steps. So I just left the faded ugly pads on and covered everything in bedliner.
    The pads on most step bars cannot be removed and reinstalled. Removing them breaks the attaching clips/pins, then you need to purchase replacement pads if you can find them or just go with a new running board/step. The only other option would be to try and glue the pads back on.
  12. May 4, 2021 at 4:47 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
