need tire advice
Discussion in 'Wheels & Tires' started by raycutro, Sep 27, 2014.
  1. Sep 27, 2014 at 1:14 PM
    raycutro
    raycutro [OP] New Member
    2014 crewmax XSP - have 20" rims. these tires 285/55 r 20. Want something closer to 33", so bet bet 305/55 r20. have a 3.5 inch leveling kit/lift. will I be able to get the 305 on? Want a bigger tire, as tires look a bit small. What is biggest I could fit without rubbing and having to add spacers? Any help appreciated!
    Dilsky likes this.
  2. Sep 27, 2014 at 1:19 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    What backspacing and offset on the wheels?
  3. Sep 27, 2014 at 1:25 PM
    raycutro
    this is dumb, but i don't know. where would i find that?
  4. Sep 27, 2014 at 2:18 PM
    csuviper
    Broomfield, CO
    Look up the model and size wheel you have online and I bet it can be found.
    T-Rex266 likes this.
  5. Sep 27, 2014 at 2:42 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Look on the back of the wheel. It will show the offset. If it is +50 offset, like most of the aftermarket style rims toyota adds in the xsp and tss packages, they will fit... usually. probably a better size would be 295 55 20.
    But take a look here:
    http://www.tundratalk.net/forums/tundra-wheels-tires/304274-tss-rim-50-offset-305-55-20s-fit.html
    That truck has a 4 inch readylift on it, so those aftermarket upper control arms may make all the difference. The factory ones may rub the tire. Bottom line, if you are a +50 offset, it will be close. If you have +60 offset which isnt likely, forget about it.
  6. Sep 27, 2014 at 3:55 PM
    raycutro
    thx! i will. this site is awesome!
    T-Rex266 and Dilsky like this.
  7. Sep 27, 2014 at 4:01 PM
    raycutro
    th
  8. Sep 27, 2014 at 4:01 PM
    raycutro
    thanks!
