Need tailgate height info for '15 Dbl Cab SR5 TRD off Road 4x4
Discussion in '2.5 Gen Tundras (2014-2021)' started by njs1956, Jan 26, 2016.
  1. Jan 26, 2016 at 7:53 PM
    njs1956
    njs1956 [OP] New Member
    Norman
    2015 Magnetic Gray Metallic Tundra SR5 Double Cab TRD Off Road 4X4
    None at present
    Just got my truck out of body shop after having the frame replaced from being rear ended in New Orleans back in early Nov, don't even have 14K on it yet. But the rear of truck seems lower than I think it should be. Can anyone give me the height from the ground to the top of the tailgate on theirs that matches mine?
    I have a 2015 Tundra SR5 Double Cab 6.6 bed with the TRD Off Road 4x4 package with 18" wheels. Haven't done any lifts or other mods yet.
  2. Jan 27, 2016 at 4:33 PM
    15whtrd
    15whtrd Mr. Blonde
    56 3/4 with 5/8 tank if gas. I have the same exact truck. Stock everything. About 38 psi front 28 psi rear.
  3. Jan 27, 2016 at 4:41 PM
    I would take your newly fixed Tundra to your nearest Toyota dealer for a look see. Any height info here is basically irrelevant due to the fact that most of us have no clue unless one of us here has the same identical set up as your truck. Also, If the body shop messed up , your local Toyota dealer will have more clout than any of us. IMHO
