Need suggestions to clean/renew textured flat handles and side steps
Discussion in 'Detailing' started by frichco228, Jan 15, 2020.
  1. Jan 15, 2020 at 9:02 AM
    frichco228
    frichco228 [OP] Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Truck is stock and has the door handles and side steps that have a bit of a textured, flat/matt finish. What is the best way to get them cleaned and looking like new?
  2. Jan 15, 2020 at 9:50 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    withing the detailing thread....myself , @Pudge, @War Machine, and i'm sure others I'm missing..... have been wondering how to get a good cleaner to take care of the steps and/or matte finish door handles without making them greasy, make them last longer than the 1-3 week time frame, etc. The handles are plastic and not the "liner" finish like the steps, so plastic treatment could take care of the handles. I've even heard of a heat gun (low setting and carefully) can get them back to a shiny finish without a greasy finish. I'm going to paint mine since my color is crazy expensive for already painted from somewhere. I haven't found/seen/discovered anything for the black stepsides though.
    War Machine likes this.
  3. Jan 15, 2020 at 10:19 AM
    War Machine
    War Machine SSEM # 5 3MW
    Solution Finish will restore the color to the handles better than anything else.
    As @Fotnot said, we haven’t discovered a great solution for the side steps. Plenty of products will get them looking black for a short time, but the only thing I’ve used that lasts more than a few days is Superior Cover All. It’s a spray that @Jim LE 1301 recommended to me, and can be found at O’Reily’s. It still doesn’t last incredibly long, but much longer than anything else I know of.
    Even though you have to reapply often, it’s cheap and easy. (It does last a good while on tires and trim, just not the metal on the steps.)
    https://www.oreillyauto.com/detail/...6c7d/superior-products-tire-shine/f96/4710878
    Only issues are overspray that you have to watch out for, and it leaves the steps pretty slick if you don’t go back over it and wipe the excess off. It’s also good for tires and will make faded / oxidized black wheels pop again.
    Sorry I don’t have a more long term fix, but believe me I’ve tried to find something.
    Jim LE 1301 likes this.
  4. Jan 15, 2020 at 10:36 AM
    frichco228
    thanks for the suggestions!
  5. Jan 15, 2020 at 10:47 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    not sure if @War Machine was aware...sometimes the O'reilly's have the cover all in a gallon for $30 bucks that you can do yourself. Can also dilute however you like. Thats what I have done. Just an FYI. I use it for my tires mostly.
  6. Jan 15, 2020 at 11:01 AM
    War Machine
    I knew it was available, just haven’t seen it in stock when I’ve looked yet.
  7. Jan 15, 2020 at 11:06 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    You have to ask them for it. Kept behind counter or in warehouse.
    War Machine[QUOTED] likes this.
  8. Jan 15, 2020 at 11:21 AM
    War Machine
    We still talking about tire shine?
    Fotnot[QUOTED] likes this.
  9. Jan 15, 2020 at 11:23 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    YEP
  10. Jan 15, 2020 at 11:28 AM
    War Machine
    Ok, cause that’s how I get my bootleg fireworks.
    Fotnot[QUOTED] and Pudge like this.
  11. Jan 15, 2020 at 11:59 AM
    :D:thumbsup:
  12. Jan 16, 2020 at 11:36 AM
    briarpatch
    briarpatch New Member
    I have the same black door handles, and most products keep them looking good for a short period of time. Solution Finish is a dye that will last a while, but will need to be re-applied at some point. I've used SToners Trim Shine, Wolfgang Exterior Trim Sealant and McKees Plastic Trim Restorer, all with similar, short-term results. As far as your steps, I've seen people use Car Pro Perl (diluted 10:1), and again, the results were short-lived and risky if you do not wipe all the excess off.
