Need some lug nut info for Icon Rebound's
Discussion in 'Wheels & Tires' started by TheGibbster, Dec 7, 2018.
  1. Dec 7, 2018 at 10:32 AM
    TheGibbster
    TheGibbster [OP] Kumite Express leaves in five minutes
    SF Bay
    2018 SSM 1794
    Hey guys,
    I am about to order up some lug nuts for the Icon Rebounds I got, and I just wanted to check with those who are more knowledgeable than I.
    Am I correct, that these are the type to go with, since the Rebound's are hubcentric?
    https://wheelersoffroad.com/i-25489...-various-quantities.html?ref=category:1346071
    From my understanding, with these wheels, neither E/T or spline drive lugs are needed.
    And here's a Rebound shot to keep things from being boring :)
    Cement_Trd likes this.
  2. Dec 7, 2018 at 10:34 AM
    OBXTundra
    OBXTundra Member
    2010 Tundra, 5.7, 4x4, TRD
    JBA UCA's, Eibach/Toytec Coilovers, AAL.
  3. Dec 7, 2018 at 10:40 AM
    TheGibbster
    SF Bay
    2018 SSM 1794
    Yeah, that thread was concerning Icon Six Speeds, which are lug centric. The guys at Wheelers told me that only Acorn style with 60 degree Taper are needed for the Rebounds. I just want to double check before ordering anything.
  4. Dec 8, 2018 at 7:24 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    TRD Rear Anti-sway bar, TRD Pro skid plate, Bedrug bed mat, Icon Rebounds 285/75/17 Cooper Discoverer XLTs, Bilstein 6112s/5160s, Diamondback SE
    Discount Tire used their own ET lug nuts on my Icon Rebounds. Have had them for a few thousand miles so far with no problems.
    TheGibbster [OP] likes this.
  5. Dec 9, 2018 at 10:36 AM
    TheGibbster
    SF Bay
    2018 SSM 1794
    I got the chance to talk more with Travis @Wheeler's Off-Road Inc
    I ended up going with the Lugs that I linked along with a set of lug locks from Gorilla. I didn't want to screw around with an E/T lug and all the misery they bring when they break off in your wheel.
    Hope it helps somebody.:hattip:
    Wheeler's Off-Road Inc and equin like this.
  6. Dec 9, 2018 at 11:32 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    2010 Super White DC
    Be sure to post some pics once you get them mounted!
  7. Dec 9, 2018 at 11:36 AM
    TheGibbster
    SF Bay
    2018 SSM 1794
  8. Dec 16, 2018 at 8:18 AM
    equin
    Ed
    DFW, TX
    Was not aware of the potential for ET lugs to break off. For peace of mind, I ordered the same acorn lugs from Wheelers that you linked. Have you gotten yours yet? If so, any pictures you can share of them on your Rebounds?
  9. Dec 16, 2018 at 8:21 AM
    equin
    Ed
    DFW, TX
  10. Dec 16, 2018 at 8:34 AM
    OBXTundra
    OBXTundra Member
    Are there documented cases on this forum of ET lugs failing in any way? Only personal experiences need apply. I don't think the failure rate is moderate or even low, probably rare.
    I've not heard of it until a few members mentioned it. I don't believe SCS or Camburg would sell them if there was a chance of failure. Both very reputable companies.
    I went ET for the piece of mind in having more than 8 full turns of engagement. I tow and haul, wasn't interested in shedding a wheel.
    Based on the research I did prior to purchase, ET lugs will fail if an impact is used instead of a torque wrench. The impact will stretch the ET portion from the acorn, weakening it. I also always use anti-seize on my studs.
  11. Dec 16, 2018 at 8:50 AM
    TheGibbster
    SF Bay
    2018 SSM 1794
    Yeah, those are the same locks. I will be sure to post up once I get everything mounted.
    As far as the E/T lugs are concerned, I figured between the fact that both wheelers and Icon told me they weren't needed on the rebounds, and since eventually I will be bashing this truck around on rocky trails, that any possible BS that could be mitigated would be best.
    equin likes this.
  12. Dec 16, 2018 at 6:49 PM
    equin
    Ed
    DFW, TX
    Yes, my earlier google search found a few posts from those who’ve broken longer lug nuts. All that was left was a small broken ring piece stuck on the stud and within the wheel’s lug hole, making it very difficult to remove. So no, I have no personal experience, but reading about others’ experiences has left me a bit leery. It may be rare for them to break, but with my luck I'd rather not risk it.
    Looking at mine, I can see how their longer length can act as unwelcome leverage to the outer exposed area of the lug nut, adding some vulnerability to breakage. I think you're right about the risk of breakage with an impact wrench. And I think there may also be a risk if using a lug wrench that isn’t deep enough to cover the whole lug nut, again because of the leverage from the nut’s longer length.
  13. Dec 16, 2018 at 6:49 PM
    equin
    Ed
    DFW, TX
    Thanks!
  14. Dec 16, 2018 at 6:53 PM
    OBXTundra
    OBXTundra Member
    Use anti-seize, a torque wrench, and ET lugs.
    Or use standard acorns at 4-6 turns and hope yo' wheels is good.
    equin likes this.
  15. Dec 16, 2018 at 7:07 PM
    Vizsla
    Vizsla Dinkus
    Dave
    Arizona
    2018 Cement Crewmax
    Icon wheels do not use ET lugs. Plenty of engagement, and ET lugs are too long for them.
    OBXTundra and TheGibbster [OP] like this.
  16. Dec 16, 2018 at 7:23 PM
    OBXTundra
    OBXTundra Member
    Confirmed across all Icon wheels? How many full rotations of the lug nut are you getting?
  17. Dec 17, 2018 at 8:26 AM
    Owenfred18
    Owenfred18 New Member
    Owen
    2014 Tundra SR5 4x4
    Went ahead and picked up the same lugs and locks from wheelers. Thanks for the thread. I’m running the same wheels. I can’t wait to wrap them in 35s. AD956065-10E7-4D3B-A31D-F6BB521B5174.jpg
    equin and TheGibbster [OP] like this.
  18. Dec 17, 2018 at 8:42 AM
    TheGibbster
    SF Bay
    2018 SSM 1794
    Glad to hear it helped @Owenfred18
    What color Tundra you mounting those on?
    Owenfred18 likes this.
  19. Dec 17, 2018 at 8:46 AM
    Owenfred18
    Owen
    2014 Tundra SR5 4x4
    White!
    TheGibbster [OP] and equin like this.
