Need some advice on a repair for P0418
Discussion in 'General Tundra Discussion' started by *D*, May 19, 2019.
  1. May 19, 2019 at 2:52 PM
    *D*
    *D* [OP] New Member
    Dimitri
    Rhode Island
    ‘24 DC Long Bed 4x4 SR5
    So I signed up with this forum yesterday strictly to ask about the problem I just ran into. I got a check engine light (P0418). The truck is performing normally. With everything I’ve read on here, it seems to me that my valve may be stuck open. I have also learned that this system is only necessary at start up, and means nothing in terms of emissions and performance when the truck is warmed up. I’ve read up on the bypass kits, doing the repair yourself, and the repeat failures of the replaced AIP. My question is, did I dodge the bullet here- or is my truck going to go into limp mode one day?
    There is more to this story, because I suspect an electrical or a computer problem. 3 weeks ago, I let the dealership replace both front and rear pads and rotors. The next day, all the lights came on on the dash (VSC, ABS, 4 HI, etc). I brought it back and they told me it was the rear wheel speed sensor. I checked both rear sensors and wiring, and everything was fine. Driving around later that day, I got a rough idle, flickering dash lights, and a stall. I knew it was the battery, so I replaced it along with the lugs and hold down (major corrosion! They couldn’t have pointed that out to me?) I also replaced a broken ground strap on the transmission near the speed sensor harness. That issue with the ABS has since been corrected, but I can’t help but think that the failing battery made the computer go wacky. The truck is 12 years old and has had a minimum of problems. It seems like too much of a coincidence that all these things happened together.
  2. May 19, 2019 at 3:36 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
  3. May 19, 2019 at 3:44 PM
    *D*
    *D* [OP] New Member
    Dimitri
    Rhode Island
    I haven’t! There’s a lot of homework there. I’ll check it out. Thanks.
  4. May 26, 2019 at 9:16 AM
    *D*
    *D* [OP] New Member
    Dimitri
    Rhode Island
    I have read through a lot of the links above, and most of that is stuff I researched or ran into before posting. I’m still not clear if the truck is going to go into limp mode though. Seems it doesn’t happen to everyone (this is starting to sound like a conversation you have with your doctor- did they have to call it limp mode?). Another thing I’m not clear on, is why would the engine limit power while driving, if this system is only needed at start up?
  5. May 26, 2019 at 9:25 AM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
    You have almost 250 hits and three replies.. I'd wager you have people's interest but they simply don't have advice, need more codes, or would need to do some research and couple it with personal experiences to provide a meaningful reply.
    I'm reading on the link.. Curious.
    JohnLakeman likes this.
  6. Jan 4, 2020 at 3:48 AM
    jimig
    jimig New Member
    2010 Platinum Crewmax
    2010 Sequoia with 5.7 here.
    CEL came on with the P0418 code but not in limp mode.
    Every link I looked has not explained to me what I need to replace.
    Where is the AIP located on this thing?
  7. Jan 4, 2020 at 4:22 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    In my first gen, it did go to limp mode very briefly, but I carry a scanner to erase the code. I did it for a few thousand miles and it never came back. In the fist gen it's under the intake manifold. Second gen I believe is behind the motor and water gets into it casing it to seize.
    AIP
    Watch the video
  8. Jan 5, 2020 at 4:09 PM
    jimig
    jimig New Member
    *UPDATE*
    First off, I didn't take any pics, so apologies for that.
    The AIP turns out, is located behind the passenger side fender.
    Bought new grommets for the plastic liner and a off brand pump from Amazon.
    https://www.amazon.com/gp/product/B07B638VF6/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
    https://www.amazon.com/gp/product/B07YTQYDVH/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
    I followed a couple youtube links on pulling the liner off, 4 screws (12mm) that hold the bracket for both pumps, disconnect 2 hoses and 2 plugs from up top, and pull it all through from the passenger side wheel well.
    Dealer wanted over $700 for each pump and about $300 for labor.
    All in for me was $100 and about 3 hrs of my time. Amazon next day Prime helped a ton as well.
    Easy work.
  9. Jan 24, 2022 at 8:19 AM
    frodotx
    frodotx New Member
    2007 TRD Limited
    i have an '07 and was getting the dreaded P2443 code (stuck closed check valve). i replaced both pumps first since thats where the problem typically starts. both pumps were dry and bench tested fine. i replaced them anyway. i also replaced the snorkel; mine had the old style without the "deflector". that took care of the P2443 code. I also used Amazon. the job wasn't bad. i wa reluctant to tear into the intake manifold for the check valve. if it reoccurs im going th bypass it all!! damn the torpedoes!!
  10. Jan 24, 2022 at 7:53 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I would not replace or have the valves replaced. I would opt for a a bypass kit.
    If done proactively the exhaust blocking plates are not needed which makes job much easier.
  11. Feb 20, 2023 at 8:31 PM
    kcreag
    kcreag New Member
    Trooper2 (comment #10) talks about the bypass kit. According to what the computer is telling me, one of my valves is stuck closed. Is the bypass kit a permanent fix or is it just temporary?
  12. Feb 22, 2023 at 3:03 PM
    Trooper2
    JR
    The bypass kit is a permanent fix. It basically deletes the function of this un-needed system.
  13. Jun 14, 2023 at 8:19 AM
    Slick2635
    Slick2635 New Member
    T
    2007 4.7 Doublecab 4x4
    2007 4.7L with P0418
    Already replaced valve and block off plate one side (original stuck open side). And bypass. My AIP still kicks on every startup. PID for air intake shows bypass working. But system still turns on. And now I have P0418. Going to do the valve and block off on the other bank. But AIP going to fail eventually if keeps turning on.
    Must note I'm in CA so I have extra layers of head smacking when smog time comes (this year)
