Need Part Numbers for Two Wire Bundle Clips
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Mar 29, 2023.
  1. Mar 29, 2023 at 2:23 PM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    South Carolina
    I’ve got a couple broken wire clamps on my 2000. First one is attached to the lifting hook on drivers side of intake and second one is a clip attached to underside of cam cover holding the harness that come up from the AC from rubbing on serpentine belt. Dealer was no help and told me to go to local hardware store.
  2. Mar 29, 2023 at 4:35 PM
    shifty` Waving My Dick In The Wind
    I can't remember your cab type but see you have a 2000 with a V8 and mystery drivetrain. That should be enough to go on.
    Toyota makes wiring & clamp situation difficult. And I don't know anyone who's posted a series of clamp pics for our trucks kinda like this Reddit gallery for Land Cruisers.
    Some of those clamps will apply to our trucks, but I don't see one that matches. So with the vague truck info, I went here, to the electrical section:
    https://parts.toyota.com/Toyota_2000_Tundra-Access-Cab-SR-5-47L-AT/Electrical.html
    There's a "Wiring & Clamp" subsection at the bottom of that page (link here). If you click "View Full Size", you'll see the biggest possible exploded diagram. Then click "View More Images" and you'll see the wild-ass array of various areas. But the exploded diagrams of interest will be the grids, like these three:
    Buried in there you're going to find every little metal bracket, lots of little clamps and harness, but you gotta look real close, for example, here's the one in the last column, I'm pointing out the three clamps showing in that one:
    It's a little bit of a snipe hunt finding them - I had to go through this when trying to find the little metal bracket and bolt that holds the alternator harness to the alternator. Here's a few more in the grid from the 2nd column, I'll hunt for a couple more minutes to see if I find more...:
  3. Mar 29, 2023 at 4:40 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    :eek:
  4. Mar 29, 2023 at 4:52 PM
  5. Mar 31, 2023 at 7:42 PM
    bfunke
    South Carolina
    Thanks 2000 AC SR5 V8 4.7 2WD
  6. Jul 8, 2023 at 12:53 PM
    bfunke
    South Carolina
    I actually ordered these two clips using part numbers I found on this diagram but they are a little different. The parts guy said they changed the design. upload_2023-7-8_15-52-38.png
