Need part help. Front brake lines 2013 Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by Jwood562, Apr 5, 2020.
  1. Apr 5, 2020 at 9:30 PM
    Jwood562
    Jwood562 [OP] New Member
    2013 Tundra 4x4
    3" Suspension lift 18" method roost 35x12.5x18 ridge grapplers 2020 sequoia LED headlights
    So I am looking for Toyota oem hard brake lines that go from the caliper to the flexible hose.
    I am having a hard time finding them and can only find the flexible lines after the hard lines.
    I am going to replace the calipers and flexible lines soon and figured in having new hard lines to ease the whole install.
    2013 Tundra 4x4
  2. Apr 5, 2020 at 9:40 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    @Roman is the forum parts guy, he should be able to help you.
    Roman likes this.
  3. Apr 5, 2020 at 9:44 PM
    Jwood562
    2013 Tundra 4x4
    Thanks. I have used his knowledge before.
    I have also been reading about guys using Tacoma soft lines one the front. I would open to this as well. I think the hard lines are just a hassle. I had to have my wife hold the calipers as I swapped rotors lol
  4. Apr 6, 2020 at 12:12 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Can those hard brake lines be replaced with SS braded lines?? I've already snapped one..
  5. Apr 6, 2020 at 12:23 PM
    blackdemon_tt
    I called the stealership about those and they didn't know, I walked into the parts store and they didn't know either.... so I had to pull the line, plug it with an ear plug and tape... measure it at the local parts store... this is the line you're looking for.
    3/16 x 8 or 4.7mm x 20.3cm metric thread.
  6. Apr 6, 2020 at 2:50 PM
    Jwood562
    2013 Tundra 4x4
    I would be happy to replace the factory steel lines with braided flexible lines.
    what is the thread pitch and size of the flare nuts?
    I think the 3/8” x 8” referees to lines size and length
  7. Apr 6, 2020 at 4:51 PM
    blackdemon_tt
    Yes, its the with and length... I believe those are universal metric fittings as I bolted them on skeptically, and they threaded on fine without an issue... they came in already flared out with nuts. Picked them up as seen at Oreilly
    Edit: there's standard and metric, I picked up the metric as most Japanese imports are metric.
  8. Apr 6, 2020 at 5:14 PM
    Jwood562
    2013 Tundra 4x4
    By googling the part Number I found the thread pitch to be 10mm X 1.0
    so I wonder if I find some steel braided lines in that pitch with male fitting that would work.
    but I doubt the flex lines would be cheaper.
    I think I found OEM replacements for $13 each. Just waiting for @Roman to chime in
  9. Apr 6, 2020 at 7:21 PM
    blackdemon_tt
    Probably wont be cheaper... may be worth it though over time... less worry on snapping a line. In my case again
  10. Apr 7, 2020 at 2:17 PM
    el_taco
    el_taco New Member
    My dealer had it, you just gotta help point it out on the diagram. But if you're away and calling they prolly dont know.
  11. Apr 7, 2020 at 2:32 PM
    Jwood562
    2013 Tundra 4x4
    I am glad you said this. I had to go to two dealerships.
    first one told me I was wrong and I had flex lines and wanted $34 each.
    second dealership pulled it up on no time. $6 each!
    thanks for everyone’s help. I just needed to find time and pop in a dealership
  12. Apr 7, 2020 at 2:54 PM
    el_taco
    el_taco New Member
    YULP, some dealers are swine lazy and dont wanna help ya. Juss gotta keep explaining or wat i do is take a picture of it wile its still on the truck and they wont be so dumm about it.
  13. Apr 8, 2020 at 6:55 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  14. Apr 8, 2020 at 8:29 AM
    Jwood562
    2013 Tundra 4x4
  15. Apr 8, 2020 at 12:45 PM
    Jwood562
    2013 Tundra 4x4
    Damn! I picked up my hard lines and they are different part numbers than the ones @Roman have above
  16. Apr 8, 2020 at 1:12 PM
    Roman
    Roman
    Franklin, TN
    Did you get these two?
    47314-0C021
    47315-0C031
  17. Apr 8, 2020 at 1:14 PM
    Jwood562
    2013 Tundra 4x4
    Yes I did. I even gave him my VIN
  18. Apr 8, 2020 at 1:18 PM
    Roman
    Roman
    Franklin, TN
    They go on your truck, they're just not the ones you need. Check out this diagram.
    The ones they got you are the highlighted numbers 47314 and 47315. They go from the rubber lines to the unions that tie into the other hard lines. The highlighted numbers 47316 and 47317 go from the caliper to the rubber lines. They were close. :D
    Droskii2018 likes this.
  19. Jun 15, 2023 at 10:49 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    great info in here, thanks! i've never done brake lines before but am putting new rotors & pads on my old 270k clunker, figured i might as well dig in to replacing brake lines too. is it a pretty involved process? i know adding the braided SS flexible lines will help, is there any reason i should be replacing these hard lines too? my truck is heavy and i want to have good stopping power for our long road trips. and every other day too.
  20. Jun 16, 2023 at 7:08 AM
    blackdemon_tt
    I only changed my hard lines because they snapped first the driver side, was a nightmare to figure out without the line, then the passenger side 6 months later. I'm at 270k as well.
    grave[QUOTED] likes this.
  21. Jun 16, 2023 at 3:22 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    is this like coil packs? if the hard lines are fine, just leave 'em?
    blackdemon_tt[QUOTED] likes this.
  22. Jun 16, 2023 at 3:34 PM
    blackdemon_tt
    if it's not broke don't fix it
  23. Nov 11, 2024 at 1:08 PM
    Droskii2018
    Droskii2018 New Member
    2018 SR5 Silver
    Hello Roman. Can I please get the part numbers for these parts but for a 2018 Tundra? I damaged my hard brake lines as well. Thank you.
  24. Nov 11, 2024 at 6:41 PM
    82nd Airborne
    82nd Airborne New Member
    2012 SR5 DC
    I went through this recently with rear brake lines. Used vin and thought I had everything right. Turns out model code also makes a difference. It's on the driver door jamb information plate. Use your vin and model code and the diagram to figure out your correct brake line part numbers. It will be 47136 and 47137 but the second set of numbers depend on your vin and model code
    Droskii2018[QUOTED] likes this.
  25. Nov 11, 2024 at 9:52 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    This is from 2020 and Roman is not part of the forum any longer.
    He used to work at A Toyota dealer and run their parts plus he pretty much had everything in his computer brain.
    He has not been heard from since the parts dept did not want yo deal with all the business it was creating. :)
    One good answer above and hope that helps you out.
  26. Nov 12, 2024 at 7:09 PM
    Droskii2018
    2018 SR5 Silver
    Thank you sir.
    grave likes this.
