need opinion, get polled
Discussion in 'Wheels & Tires' started by MAGDADDY, Sep 15, 2019.
New wheels?
Poll closed Sep 19, 2019.
  1. Yes
    80.8%
  2. No
    19.2%
  1. Sep 16, 2019 at 1:49 PM
    MAGDADDY
    MAGDADDY [OP] TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Right on! Looks good! Are you having any rubbing issues at stock height?
    cc1999[QUOTED] likes this.
  2. Sep 16, 2019 at 1:56 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Meh, you can fit a 275/65/20 or a 285/60/20 on stock wheels.
    The first size is a 34x11.5.
    I think that’s big enough to be considered a “decent size.”
  3. Sep 16, 2019 at 1:57 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Is that what you have?
  4. Sep 16, 2019 at 1:59 PM
    MAGDADDY
    JON
    Houston TX
    18 Platinum CM MGM
    Yea that’s what’s on the truck now is a 275/65/20. Looks good, just thought it would be a tad bigger. Lol. Don’t we all
  5. Sep 16, 2019 at 2:01 PM
    TruckyTruck
    Gary
    :laugh::laser:
    MAGDADDY[QUOTED][OP] likes this.
  6. Sep 16, 2019 at 2:03 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Yep
    Will you post a picture of the size off of the sidewall?
    TruckyTruck[QUOTED] likes this.
  7. Sep 16, 2019 at 2:03 PM
    cc1999
    cc1999 New Member
    2018 Land Cruiser Silver/Black
    Not so far.
    I did nearly this same setup on my 2017 Tundra only with the Fuel Trophy 18x9 +20s and Toyo AT 2 LT285/65/18s. On that 2017 I did have to remove those little front wind flaps located down below the bumper on the front side of each fender. On the 2017 I was rubbing those bolt heads that hold those tiny little flaps in place. removing those flaps pretty much resolved the issue on that truck.
    I have not heard a thing rubbing under the 2020 with the Ridge grapplers. I can tell it is still very close to those same flap bolt heads, just not hitting them. I know if I had gone with the 305s or even 295s I would likely have a rub and need to either install a level kit or at the least remove those flaps again.
  8. Sep 16, 2019 at 2:10 PM
    MAGDADDY
    JON
    Houston TX
    18 Platinum CM MGM
    TruckyTruck likes this.
  9. Sep 16, 2019 at 2:10 PM
    TruckyTruck
    Gary
    Your truck, wheels and tires really do look nice. I had the same wheels in black. I couldn't fit the tire I wanted with them though. 35x12.5. Your right, decent size is subjective.
  10. Sep 16, 2019 at 2:12 PM
    MAGDADDY
    JON
    Houston TX
    18 Platinum CM MGM
    Check out Coachbuilder they have a front bumper spacer that spaces your front 1” out and you can’t even tell unless you look really close. Helps with more clearance. Thanks for the info!
    TruckyTruck and cc1999[QUOTED] like this.
  11. Sep 16, 2019 at 2:19 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    They just really don’t appear that large. Maybe it’s the angle of the first picture. Idk.
    :bananadance:
  12. Sep 16, 2019 at 2:22 PM
    MAGDADDY
    JON
    Houston TX
    18 Platinum CM MGM
    Yea pictures don’t do it justice.
  13. Sep 18, 2019 at 6:09 AM
    MAGDADDY
    JON
    Houston TX
    18 Platinum CM MGM
    Well obviously the pole hasn’t ended, but looks like the majority wins! Thanks for all the input and suggestions. Working on ordering the Fuel Anza on a Nitto G2 Terragrappler 295/70/18, but it will be a few weeks before I get them on the truck, I’ll post some pics when done.
