Need New Front Shocks
Discussion in 'Suspension' started by Junior4888, Dec 12, 2016.
  1. Dec 12, 2016 at 3:56 PM
    Junior4888
    Junior4888 [OP] 2007 Toyota Tundra Limited 4.7l
    Travis
    Moxee, WA
    2007 Toyota Tundra Limited Dbl Cab 4.7l
    I hust had my tires rotated and shocks need replaced. Cupping the front tires. What is a good replacement shock. Not alot of offroading. Just during hunting season. Mainly asphalt to and from work. Suggestions apprieciated.
  2. Dec 12, 2016 at 3:57 PM
    sdhq_offroad
    sdhq_offroad New Member Vendor
    GILBERT, AZ
    I would just do a Bilstein 5100 and set it at whatever height you would like (Stock to 1.85" or whatever top height is). Is you would like an all around ride quality different, replacement coilover would be next on the list in my opinion.
    Junior4888 [OP] and CM-LENNY like this.
  3. Dec 12, 2016 at 4:08 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Travis..........I agree, the Billy 5100 is a great budget minded shock with lift adjustment ability. You might want to get your alignment checked too. Good luck with everything.
    Junior4888 [OP] likes this.
  4. Dec 12, 2016 at 4:18 PM
    balou
    balou Texas Tundra
    2016 tundra cewmax 4x4 tss option
    bilstein 5100 adj front shocks led lights for bed
    I got bilstein 5100 adj for front. Had them set at 1.5in to level out truck. Very happy with looks and performance of the shocks. Waiting on rear ones now to finish out shocks. Should be here by wens.
  5. Dec 12, 2016 at 5:48 PM
    Hossdawson
    Hossdawson New Member
    Hoss
    Harrisburg, PA
    2004 4wd DC
    Hi
    I put 5100's on the front of my 2004 and set them at the center height. What a difference! I put Billstiens on the back too. Love 'em!
    Hoss
  6. Dec 12, 2016 at 5:51 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Well as everyone said 5100s are the most economical quality shock that you can get that will allow you to raise the front and level the truck for a better look.
  7. Dec 12, 2016 at 6:23 PM
    831Tun
    831Tun crazy Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    TC LT w/ king 2.5 C/O and bypass, ADS bypass rear, Toytech shackles, TRD dual exhaust dumped, KM3 37s on Method standard +18. N_Fab front bumper, Westin rear w/ hitch relocate, RCI skids, Desert Eagle tranny skid, All Pro sliders, ARB dual compressor, 5.29 gears and ARB rear locker
    Too bad you're not closer. I've got some 5100s with 2016 springs that, when I get time, I'm gonna get rid of. They've only got about 7k on 'em.
  8. Dec 12, 2016 at 7:03 PM
    scotch
    scotch New Member
    Denver, CO
    2010 Tundra
    2010 Tundra Method 20x9 Fat Fives 18offset, 305/55/20 Duratracs, Bilstein 6112/5160, SPC/LR Upper Control Arms, TRD Rear Swaybar, OME/Dakar leafs with CB +1 Shackles, Husky Weatherbeaters, Du-Ha, Extang Solid Fold, Line-X, Toyota Bed Mat, Stoptech Cryo Rotors and pads, Goodridge brake lines, Stoptech STR-660, Rigid Fog Lights, Odyssey Battery, Firestone Airbags with CB spacer, etc, etc... Previous Toyota's: 97 4runner, 02 tacoma, 09 tacoma
    MotoTundra and YotaDan like this.
  9. Dec 13, 2016 at 8:57 AM
    YotaDan
    YotaDan New Member
    Grants Pass, Oregon
  10. Dec 13, 2016 at 8:19 PM
    Junior4888
    Travis
    Moxee, WA
    Appreciate all the responses. Just got home. I will check everything out and let you guys know what i end up going with.
