Need New Bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by turkeycreek29010, Jan 10, 2020.
  1. Jan 14, 2020 at 6:39 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    The Cement grille is only available in the earlier style Pro grille. You will need a bracket of some sort for the sensor for that grille.
    Rica25 and LogCabins like this.
  2. Jan 14, 2020 at 6:50 AM
    Rica25
    Ricardo
    Tulare
    how much for inner fender liners for 2008 Tundra crew 5.7 the ones that cover the engine from water
  3. Jan 14, 2020 at 8:19 AM
    Roman
    Roman
    Franklin, TN
  4. Jan 22, 2020 at 5:51 AM
    turkeycreek29010
    turkeycreek29010 [OP] New Member
    Chuck
    Bishopville SC
    2019 Cement Tundra Crew Max
    3/1 Level Kit, 20 inch Gear Wheel, 285/65/20 BFG
    Update on progress...
    I've recieved the bumper from Extreme Terrain. Heaver than expected. Little concerenced about this. They said 95lbs when I asked about the weight. Shipped weight was 165 lbs. I also ordered and recieved Baja Designs SAE fog lights, but look like they may not work. The bumper has top mounts for the pod lights and the Baja's have bottom mounts. Not sure if the SAE lights can me mounted upside down? I dropped off the new grill and surround at the body shop to be color matched. Hopefull to have everything back on the Tundra this weekend.
  5. Jan 22, 2020 at 6:13 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Is that added weight out front a concern?
    It all depends on how you drive your truck.
    I drive my trucks more like a sports car on pavement, sharp turns, late braking etc.
    The added weight of the heavy Ranch Hand bush bar on the front end ruined the drive for me, so I removed & sold it. That N-FAB bumper in your original post would probably work for me... again, it all depends on how you drive your truck.
    jordan0317 likes this.
  6. Jan 22, 2020 at 7:15 AM
    turkeycreek29010
    Chuck
    Bishopville SC
    Little worried about handling and suspension sag. From what I have seen from searching, the OEM bumper is around 75 lbs? So if the shipping weight is correct, its will be over twice that. The bumper is similar to the Rough Country bumper, which shows 95lbs on their site. Hopefully the shipping weight was a little exagerated. I'll have a better idea this afternoon when I go to move the box. I dont have a way to actually weigh it.
    Rex Kramer likes this.
  7. Jan 22, 2020 at 12:42 PM
    95_BPmedic
    95_BPmedic New Member
    MARSHALL
    2014 SR5 4x4
    Either is great choice!
