Need help yanking
Discussion in 'Recovery & Gear' started by EmergencyMaximum, Sep 15, 2023.
  1. Sep 15, 2023 at 11:37 AM
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
    Hey gang, I have a tree stump I need to yank out from the ground with my tundra. It's from a dogwood tree. It was a beautiful tree, but she eventually started going back.
    Now I'd like to yank the stump out of the ground and prepare the spot for some other tree.
    Any off the shelf ideas to help me in this endeavour? I'd like something with maybe a large hook on the end or maybe even just to loop a chain around and yank it out?
    Or any better less fun ideas?
    bulldog93 likes this.
  2. Sep 15, 2023 at 11:49 AM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Loop it with a chain or my preference is an old tow strap that you don't mind damaging. Try to pull it straight sideways first to see if it pops out or if it needs more convicing, put a tire right near the stump and run your chain or rope over it to change the pull to an upwards direction. Might have to cut some of the roots if it is really stubborn.
    EmergencyMaximum[OP] likes this.
  3. Sep 15, 2023 at 11:54 AM
    coTony
    Tony
    Montrose, CO
    Just a word of caution. If you 'yank' the stump out of the ground where do you think that stump is going to end up? Ideally having a winch would work much easier. I have done that in the past and with tension on it you can see what roots need to be cut and you can work it out instead of possibly hurting someone or something.
    Just wanted to share, I have seen this happen and would not want to hear a repeat story. Just a little work and you will get er out!
  4. Sep 15, 2023 at 11:56 AM
    APalmTree
    Brandon
    SW Washington
    Good point... I will agree if you can not pull it out slow and controlled, try a new method. Yanking is not a good one.
  5. Sep 15, 2023 at 12:01 PM
    EmergencyMaximum
    Well, perhaps my thought was not properly put into words. By yanking, I meant gently convincing it to let go.
    Nothing like what you see on viral youtube videos.
    I'm in the process of dismembering the body.
    APalmTree likes this.
  6. Sep 15, 2023 at 12:01 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    If you do decide to yank it with a strap or chain, don't forget to use some sort of safety in the middle to prevent it from coming through your rear window in case it slips off.
  7. Sep 15, 2023 at 12:31 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Rent or hire a stump grinder.
    Trying to pull that out with your truck is going to kill your fuel mileage!
  8. Sep 15, 2023 at 12:34 PM
    EmergencyMaximum
    @landphil , I will rev to 55mph, so that I'm in the fuel efficient range.
    This is hard work! My hands are hurting. Maybe I just keep watering it every evening for the next several months and she will rot to china?
    landphil likes this.
  9. Sep 15, 2023 at 1:28 PM
    EmergencyMaximum
    This fat dick has been eating my tree.
    I think I'm done for today. Working can't be healthy.
  10. Sep 15, 2023 at 1:50 PM
    SD Surfer
    Bruce
    So Cal
    Jeez, the guy serves up a fatty with a thread title like "I need help yanking" and not one single juvenile or off color response?!
    You guys rarely disappoint when it comes to inappropriate and sophomoric humor, but this is a sad day indeed. :(
    Be careful yanking yer wood too hard, or it may be violent when it comes out. :rolleyes::bananadance:
    There, was that so hard?
  11. Sep 15, 2023 at 2:35 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    F*cking stink bait thread title...
    REPORTED°
  12. Sep 15, 2023 at 2:36 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Bun it out, rent a small grinder, keep digging and cut a bunch more then try to yank it!!! And keep yanking it till something breaks!!:)
    I just saw that your hands are hurting?? If that is because of you yanking on it it means you are doing it way to much.
  13. Sep 15, 2023 at 2:38 PM
    coTony
    Tony
    Montrose, CO
    Like I always say "Beat it like it owes you money"
  14. Sep 18, 2023 at 12:58 PM
    EmergencyMaximum
    Gang, I saw chain and hooks I can probably acquire from the local hardware store.
    How much lb capacity do i need for some safe yanking? I've seen some 4,000lbs capacity chain and hooks I can rig up. I probably won't be able to generate a lot of torque with a 2wd tundra over grass or gravel. Doing some gentle rocking can probably increase that potential, although it might get a little dangerous with a chain? Or maybe less dangerous?
    Now I'm not talking rocking the truck like they do on youtube fails and stump goes flying 20 feet through the air and into the rear window. Reasonable stuff I mean..
    Ps- it's a 20 foot chain, which can be looped around tree stump from underneath, increasing capacity to 8,000lbs effectively.
  15. Sep 18, 2023 at 1:00 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    If you’re good, it lands directly into the bed
  16. Sep 18, 2023 at 1:06 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Personally, I'm a fan of tannerite for small things like tree stumps to tooth pulls.
  17. Sep 18, 2023 at 1:45 PM
    EmergencyMaximum
    No.
  18. Sep 18, 2023 at 1:47 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    You sound like my wife
  19. Sep 18, 2023 at 2:05 PM
    All dick jokes aside, I really wouldn't use your truck for this job.
    Chain is not designed for "shock load" and can be quite explosive.
  20. Sep 18, 2023 at 2:05 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    rmorse[QUOTED] likes this.
  21. Sep 18, 2023 at 2:24 PM
    EmergencyMaximum
    Thank you, I should not have mentioned it. No yanking, that would probably be safer with ropes.
    The tree stump isn't even that big and sorta moves when I hammer it. I just want to wrap chain around it, tension it and then pull from different directions to loosen it up and dislodge it from the ground.
    Would 4,000lb rating sound safe enough? (No yanking)
    Edit: to add, I have pulled out smaller trees using my lifting straps, but they get trashed where they rub against the tree. That's why I'd like something more permanent and reusable, suited for the job.
  22. Sep 18, 2023 at 2:56 PM
    Putting tension on a chain isn't a problem.
  23. Sep 18, 2023 at 2:58 PM
  24. Sep 18, 2023 at 4:01 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    4000lb chain sounds really dangerous. I’d probably give it a try with a 30,000lb tow strap.
  25. Sep 18, 2023 at 4:32 PM
    EmergencyMaximum
    30,000lbs?! I don't think I would be able to create that much force even on concrete! Are you sure this is right, @joonbug ? Please don't be mad, I'm not questioning your expertise, well I am I guess..
    Chain looks fairly beefy.. I'm not planning on yanking.
    joonbug likes this.
  26. Sep 18, 2023 at 4:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. Zero expertise here. I have no idea. I’ve never yanked on stumpy wood before. :D I’m just saying a truck can easily put 4000lbs of force on that chain and I’d be a little weary of trying it. And I happen to have a 30k tow strap so that’s what I would use if I were to try it. Just be safe if you do give it a try and be sure to get it on video. :thumbsup:
  27. Sep 18, 2023 at 5:02 PM
    EmergencyMaximum
    Well now I'm a little worried. Do I really need something with at least 10k lbs capacity?
  28. Sep 18, 2023 at 6:00 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I've yanked half a dozen dead trees this summer. 4low & the HF tow strap in a loop. Granted, my dirt is dry & powdery & i rock the trees a bit before pulling. Kinda tricky when they're cut that low.
  29. Sep 18, 2023 at 7:00 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Set your rigging so the hitch of the chain is on the opposite side of the stump from the truck. Prop your spare tire or another inflated tire under the run of chain attached to your truck. Position the tire closer to the stump. The tire will translate your tension into an upward vector thereby assisstifying in uprooting.
    Please use the 5.7 liter quad cam. Stumps can be bearing eaters.
  30. Sep 18, 2023 at 7:07 PM
    EmergencyMaximum
    4.6 v8 here...no good?
    How much chain fatness do I need? Folk here say 4,000lb capacity won't work.
