Need help with where to start!
Discussion in '2nd Gen Tundras (2007-2013)' started by Willdo18, Jan 25, 2024.
  1. Jan 25, 2024 at 11:38 AM
    Willdo18
    Willdo18 [OP] New Member
    07 Tundra
    I have a 07 tundra with close to 200,000 miles on it. A while back I had several lights on the dash come up;
    VSC off light is flashing
    4lo light flashing (4-wheel drive will not work in high or low)
    ABS light constant on
    Traction control light on
    I have changed out the front passenger wheel speed sensor with no change to the lights.
    Anyone else had these issues? Any ideas on where to start to resolve this issue/issues?
  2. Jan 25, 2024 at 12:02 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Go to autozone or any similar auto parts store and have them run diagnostics on your truck. There's no way we can figure out what it may be as codes should sort of guide you to where you need to go. There is a matrix out here so that you can sort of figure out what the issue may be, based on lights, but unless you're pulling your exact codes this may be a shot in the dark. Any changes will take 2 driving cycles to clear, or you can clear them via the battery disconnect, but I would highly not recommend this unless you already have codes in hand. The parts store will not clear your codes, just keep that in mind.
    PhotoNerd likes this.
  3. Jan 25, 2024 at 12:26 PM
    Willdo18
    07 Tundra
    The check engine light came on one time, scanned the codes and reset. Check engine light has never came back on. Codes were;
    P2419
    P2402
    P2401
    P043f
    P2419
  4. Jan 26, 2024 at 2:59 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
  5. Jan 26, 2024 at 4:22 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
