Need help with my Remington 870
Discussion in 'Guns & Hunting' started by joem1cha3l, Nov 10, 2016.
  1. Nov 10, 2016 at 1:34 PM
    joem1cha3l
    joem1cha3l [OP] New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I have a sling for my 870, but no clue what I should be looking at for sling swivels. I have no clue how these things mount, can someone help?
  2. Nov 10, 2016 at 1:36 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    There is a sling mount that goes under the screw cap under the barrel, the second is somewhere near/under the butt. Look for a little raised bump with a hole drilled through it.
    I've got an 870 at home, I'll take a pic later.
    NewImprovedRon likes this.
  3. Nov 10, 2016 at 1:37 PM
    Nor7
    The sling is not designed for the gun to hang like an AR but rather for when its behind your shoulder when you're walking.
    PermaFrostTRD likes this.
  4. Nov 10, 2016 at 8:10 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    There are many different types of slings, and the sling mounts need to be compatible with the sling. Post up a pic of your sling, that may help us determine which sling mount is best.
  5. Nov 11, 2016 at 5:47 AM
    Nor7
    Crap, I forgot to snag a picture. But this one I snagged from Google is exactly like mine. You may need to buy the swivels or sling mounts, and yes there is a variety but here is where the mounts are.
  6. Nov 11, 2016 at 5:56 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Yup, if you have a one point sling, you will need to add a mount compatible with your sling, typically the mount would go just forward or your buttstock, but they have different variations.
  7. Nov 11, 2016 at 1:48 PM
    joem1cha3l
    Albany, NY
    yeah, I bought that kit and when it arrived, I realized it was for a 12 gauge. Mine is a 20 gauge. Damn waste of $25
    This is the sling I bought, but I'm not limited to this. I'd buy a different one if it made finding the mounts easier.
    http://www.butlercreek.com/products/easy_rider_slings.html
  8. Feb 16, 2017 at 5:46 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I have the same sling. It is designed to slip over the but and hold the gun on the pistol grip. It's a bad design. I ended up cutting mine and converting it to be a normal 2 point sling with swivels.
    You should buy a sling stud. Can be found a Walmart or any gun shop and the proper magazine cap sling stud. Then you can have the set up like the picture above.
    Get this
    https://www.amazon.com/gp/aw/d/B01LXM86FJ?psc=1
    And this
    https://www.amazon.com/gp/aw/d/B01H...ifle+sling&dpPl=1&dpID=31q9kHjM0AL&ref=plSrch
    Or any other sling with the same type swivels.
  9. Oct 23, 2024 at 2:08 AM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    look into Spectre Gear slings.
  10. Oct 23, 2024 at 3:53 AM
    dklehman
    dklehman New Member
    Darin
    2024 sr5 Tundra
    How old is your 870 early models will not have sling studs you can either add them or use a slip on style which suck if you are gonna walk more than a mile or two
