Need help with LCA strategy
Discussion in '1st Gen Tundras (2000-2006)' started by CMPtundra, Feb 9, 2025.
  1. Feb 11, 2025 at 11:06 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    I just did this job a week or so ago. You have 2 the cam assemblies, but there is a front and back piece, and two on each side. I would also recommend new bolts why you're at it. Be careful though because there are two types of bolts. One is longer than the other. I was able to re-use my bolts when I did it otherwise I would have been screwed.
    joseph_womack likes this.
  2. Feb 11, 2025 at 11:24 AM
    Sirfive
    Sirfive Socially feral
    SATX
    ‘02 Limited AC TRD
    Bassani cat-back
    Dont forget there are 2 spots on each axis to align things, get things closer to where you want them (depending on a high-caster uca) before paying a toe&go alignment shop for a sheet of paper. I hit mine better than the laser table with a tpe measure (they just adjusted my steering wheel a hair crooked, that i had to fix myself). Kinda wanna raise my clips up a notch before my warranty runs out, but if they eff up my measurements i’m gonna be mad.
  3. Feb 11, 2025 at 11:45 AM
    CMPtundra
    CMPtundra [OP] Wandering Tundra Owner
    Alabama
    05' 'New To Me' DC Limited
    Yes, two of each cam assembly. #34020 is the front sleeve, and #34030 is the rear sleeve. I'm expecting to be able to re-use the the bolt and cam washer, but the sleeves I'm sure are seized and will need cutting out.
    Kimosabe[QUOTED] likes this.
  4. Feb 11, 2025 at 1:07 PM
    You're assuming the bolt won't be frozen into the sleeve, and will actually come out.
    That may prove to be a bold assumption, since they're known to eventually rust into the sleeve.
  5. Feb 11, 2025 at 1:10 PM
    CMPtundra
    Alabama
    You are not wrong haha (nervous laughter)
    shifty`[QUOTED] likes this.
  6. Feb 11, 2025 at 1:14 PM
    CMPtundra
    Alabama
