Need help wiring aftermarket keyless entry to 2020 Tundra Sr
Discussion in '3rd Gen Tundras (2014+)' started by 2020 dc, Jan 17, 2020.
  1. Jan 17, 2020 at 7:47 AM
    2020 dc
    2020 dc [OP] New Member
    2020 tundra dc sr
    Hi, new to the forum. Has anyone here try installing an aftermarket keyless entry to their Tundra SR model (no key fob came with SR model). I did some probing with my test light that makes me think the door locks are positive triggered...can anyone confirm that? Also which 2 wires you tapped into for the lock and unlock function. If anyone has any info on this.. Thanks in advance.
  2. Jan 17, 2020 at 8:02 AM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
  3. Jan 17, 2020 at 10:05 AM
    Beau
    Beau De gustibus non est disputandum
    Beau
    2008 Sequoia with a 2019 style
    The standard keyless entry should work off of the same wires which are highlighted in the guide by @erkme73 . OP may want to check out the passive keyless entry as well too though. It's pretty legit! I put a small video and more details in my build thread here.
    HappyGilmore likes this.
  4. Jan 18, 2020 at 1:15 AM
    2020 dc
    2020 tundra dc sr
    Thank you both for your help. I will read the threads to get useful info. Would you happen to know if the 2020 tundras uses positive or negative triggered to unlock and lock the doors?
  5. Jun 16, 2020 at 4:38 PM
    blackwaterfrog
    blackwaterfrog New Member
    Oklahoma/Texas
    2020 SR 4x4
    How did it go? Did you find a brand that works? If so what is it? I too have a 2020 SR without factory keyless and would like to have keyless/remote start. I have been told that Vipor offers one but with limited features.
  6. Jun 22, 2020 at 2:11 PM
    2020 dc
    2020 tundra dc sr
    Hi blackwaterfrog, I tried a generic aftermarket keyless entry system and that did not work. It looks like Toyota has created a complicated door lock system for the recent tundras. I was able to install a keyless entry system on a 2014 Tacoma by using a negative signal trigger to open and close the door locks. Apparently Toyota somehow change the door lock system. The 2020 tundras neither work with a negative or a positive trigger signal. If you find information on what works, please share. Sorry I don't have any good news for you.
  7. Jun 22, 2020 at 3:07 PM
    blackwaterfrog
    Oklahoma/Texas
    2020 SR 4x4
    Here is what I found. This company (Compustar) offers many options for remote start with keyless entry for Tundra. These work with or without factory fob. There are 3 websites for 2 affiliated companies. The compustar website has a dealer locator. The customer service folks are very knowledgeable. And they offer a plug and play harness that so it won't affect Toyota warranty.
    https://www.compustar.com
    https://www.idatalink.com
    https://compustar.idatalink.com
  8. Jun 23, 2020 at 12:01 PM
    2020 dc
    2020 tundra dc sr
    Thanks blackwaterfrog. I will check them out for sure. I really like the idea of a plug and play harness (less chance of frying electronics due to installer's errors).
  9. Aug 1, 2020 at 1:16 PM
    Sc2019tundra
    Sc2019tundra New Member
    I have a 2019 tundra sr model .
    Has anyone made a successful upgrade to the keyless entry or intermittent wiper switch?
  10. Aug 1, 2020 at 8:57 PM
    2020 dc
    2020 tundra dc sr
    Intermittent wiper switch is a simple swap(10 minute job max). I am looking into compustar keyless entry and remote start.
  11. Aug 7, 2020 at 9:41 AM
    Sc2019tundra
    Just did the intermittent wiper swap out. Easy fix. I can’t believe for the price of this truck they cheap out on a part that cost them a few dollars.
    ok, so any good news or updates on adding keyless entry?
    Thx in advance Brian
  12. Aug 10, 2020 at 11:06 PM
    Gordo1
    Gordo1 New Member
    Ed
    2020 tundra se
    I had a locksmith sell me the fob with the buttons. Programmed it and it works. No chirp sound. Just turn signals flash. I have a 2020 doubt about SR. Dealership wanted 400 for a key with buttons. Locksmith $150. Next up I’ll try adding the remote start kit from Amazon.
