Need help. Wheel offset for Zone 5" Lift
Discussion in 'Wheels & Tires' started by marlon671, Sep 11, 2017.
  1. Sep 11, 2017 at 1:00 PM
    marlon671
    marlon671 [OP] New Member
    Marlon
    2017 MGM Tundra SR5 4x4
    Ive purchased the Zone T5 5" Lift kit for my 17 tundra. I plan on running 35/12.50/18 tires. I also will purchase 1.5"-2" fender flares. Im looking for the right offset to run. Im looking for 18" wheels obviously. lol. Zone recommends a 5.5" backspacing which is a +13 offset. The look I'm going for is to have the wheel/tires poke out about an 1"-2" past the fender flares. Just a wee bit of poke past the flares. Dont want my truck looking like a turtle, or a ford. haha.
    I was thinking of going -12 offset. If anyone has a similar setup, please chime in. I also may take my lift up another inch or 2 with coach builders kit. So I need ideas on what I offset I need to look for to achieve this look.
    Any help (especially specs and pictures) would be greatly appreciated! have good day folks!
    Jsena likes this.
  2. Sep 11, 2017 at 1:24 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    -12 will be good. I'm -25 and mine stick out about 3 1/2 inches past and I don't have any flares
  3. Sep 11, 2017 at 1:24 PM
    marlon671
    Marlon
    awesome thanks for the reply
  4. Sep 11, 2017 at 1:37 PM
    big_t1986
    big_t1986 New Member
    I had the zone 5 on my 2013 tundra with 35x12.5r20 and 20x10 -12. Had to cut the liner a little bit and the trim the body mount but it was fine. It stuck out 2.5 inches at least without flares I believe
    marlon671[OP] likes this.
  5. Sep 11, 2017 at 1:39 PM
    marlon671
    Marlon
    Yea I think I'm set with -12. but now it seems impossible to find 18x9 with a -12 offset. It seems like 20" wheels have more selection with the -12 range.
  6. Sep 11, 2017 at 1:44 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Here's a picture of my +20 offset wheels with 1.25" spacers putting me around a -12 with my flares ...
    rear
    front is more like a -5 since I only used 1" spacers
    I've got rubbing on both front liner and cab mount, but I'm only leveled 3/1 ... maybe that 2 extra inches will help you prevent rubbing
    dcsleeper408 likes this.
  7. Sep 11, 2017 at 1:51 PM
    big_t1986
    I haven't seen an 18x9 with much negative offset. Maybe an 18x10. Personally I think I would stick to a 18x9 and 0 offset. No need to go 10in wide. It adds weight to the vehicle. I think like 10lbs of wheel weight is equal to pulling 600 pounds
  8. Sep 11, 2017 at 2:03 PM
    marlon671
    Marlon
    the way you have your rear setup is exactly what I'm going for. except I was trying to avoid spacer. I probably would end up considering spacers if I find wheels that I really like.
    These look pretty cool. and its a 0 offset.
    http://www.kmcwheels.com/wheel/34804/xd832
    r4z0r51o[QUOTED] and Jsena like this.
  9. Sep 11, 2017 at 2:07 PM
    big_t1986
    I like those. I also like the bullys.. Good luck man
    Jsena likes this.
  10. Sep 11, 2017 at 2:12 PM
    marlon671
    Marlon
    thanks!
    Jsena likes this.
  11. Sep 11, 2017 at 2:30 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    -25 with no flares. You get -12 which is 1/2 inch less out, plus gender flares, you'll be maybe inch or less past your flares
    GNTundra likes this.
  12. Sep 11, 2017 at 2:47 PM
    marlon671
    Marlon
    Thanks for the info!
    I always laugh a bit when I see Gender Flares. lol
    Jsena[QUOTED] likes this.
  13. Sep 11, 2017 at 2:57 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    lol didn't see that. *autocheck ¯\_(ツ)_/¯
    marlon671[QUOTED][OP] likes this.
  14. Sep 11, 2017 at 4:10 PM
    r4z0r51o
    Dave
    Nice looking wheels!
    Yeah, when I bought my wheels I did so without the thought that I might end up adding fender flares. After I was shown a great deal on the flares through Craigslist, I ended up buy them and then ended up with the tucked in look ... Not cool, so therefore the spacers :oops:.
  15. Sep 11, 2017 at 5:21 PM
    Kdgcng
    Kdgcng Rock steady
    Kyle
    2017 Magnetic gray tundra SR5 crewmax
    Let me know how it goes imma run the same set up but imma use the TSS rims which are a 20" rim with +50 offset with 35 MT's wondering if ill need spacers to push them past my fender flares or if itll be good enough.
    Jsena likes this.
  16. Sep 11, 2017 at 5:23 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    You'll need spacers if you want them past your fender flares for sure. +50 is almost stock
    Kdgcng[QUOTED] likes this.
  17. Sep 11, 2017 at 5:23 PM
    Kdgcng
    Kdgcng Rock steady
    Kyle
    Damn lol im kinda outta it for buying a lift and rims and tires lol!
  18. Sep 11, 2017 at 5:27 PM
    marlon671
    Marlon
    I was gonna say, +50 is pretty much opposite of where u want to go if your trying to have em stick out a bit. Actually, see if anyone has ran a +50, that might actually cause rubbing on your shocks and/or springs.
    GNTundra and Jsena[QUOTED] like this.
  19. Sep 11, 2017 at 6:17 PM
    r4z0r51o
    Dave
    Wow, +50 offset ... To get it close to a -12 you'll need nearly 2.45" spacers. Since you're thinking about using 35"x12.5" tires, at minimum I see 2" spacers to get you outside pocket style flares.
  20. Sep 11, 2017 at 6:31 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Look for same rim diff offset. Usually they have a few choices
    froggy78 and r4z0r51o like this.
  21. Sep 12, 2017 at 4:34 AM
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    If you want to stick out past the flares, I would say definitely at least a +0. I have +12 and its about even with my BW flares. I thought about spacers too, but I am not interested in a BC.
    I am running the Zone kit.
  22. Sep 12, 2017 at 4:38 AM
    marlon671
    Marlon
    Awesome. How do you like the zone kit so far? Any pictures of your ride?
    froggy78[QUOTED] likes this.
  23. Sep 12, 2017 at 4:41 AM
    froggy78
    JP
    SF Bay Area
    1794 TRD
    I have a couple pics in my gallery. I have about 8k miles on my lift so far, so good. Now, that I think about it, I am not totally sure the +0 will stick out, but mine seem to be about dead even or may be in just a tad. All depends on how you stare at it. I can stare at it all day.
    joonbug likes this.
  24. Sep 12, 2017 at 5:30 AM
    marlon671
    Marlon
    Thanks for the reply. I'll check out your truck!
    Just saw your pics. Awesome truck man. I love black on black but hate the attention and care needed for black vehicles which is why I went the next darkest color, MGM. lol
    froggy78[QUOTED] and Kdgcng like this.
  25. Sep 12, 2017 at 8:20 AM
    Kdgcng
    Kdgcng Rock steady
    Kyle
    Not to mention the best color!
    froggy78 likes this.
  26. Sep 12, 2017 at 8:24 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :amen:
    joonbug, GNTundra and froggy78 like this.
  27. Sep 12, 2017 at 8:30 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    :benchpress:
    Jsena[QUOTED], GNTundra and froggy78 like this.
  28. Sep 12, 2017 at 8:41 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    joonbug[QUOTED] likes this.
