Need help on TRD headlights for 2015 Sr5
Discussion in '2.5 Gen Tundras (2014-2021)' started by cavilac0432, Aug 19, 2019.
  1. Aug 19, 2019 at 2:06 PM
    cavilac0432
    cavilac0432 [OP] New Member
    Salvador
    Midland Texas
    2015 White SR5
    Im a newbie here and to the Tundra world I always had a Chevy but switched over a few weeks ago. Ive checked threads and posts and have not found what I was searching for so forgive me if it is there and I over looked it. I have a 2015 SR5 TSS crew max with chrome headlights non led with power level adjust. I recently was looking for TRD black headlights non led with power level adjust which I found some on ebay but the configure said they were not compatible am I searching for the wrong thing or or is ebay saying that cause I searched TRD and my saved vehicle is an SR5. any help, points and directions will be greatly appreciated.
    jewsNbrews likes this.
  2. Aug 19, 2019 at 2:08 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Maybe. If you get pro lights from 14-17 you should be fine. 19 pro headlights will require a wiring harness.
    Kerch71 likes this.
  3. Aug 19, 2019 at 2:11 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have a set of 14-17 black pro headlights
  4. Aug 19, 2019 at 2:23 PM
    cavilac0432
    Salvador
    Midland Texas
    2015 White SR5
    Yea the listing says 14-17 and I know on Chevys and Fords they're all the it doesn't matter if single, extended or crew so I kinda figured it would they same with the Tundras
  5. Aug 19, 2019 at 2:24 PM
    cavilac0432
    Salvador
    Midland Texas
    2015 White SR5
  6. Aug 19, 2019 at 3:09 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Tundras are the same. Depends on year, not so much model. But computers won't tell you that as they are model specific.
  7. Aug 19, 2019 at 3:34 PM
    billyray3110
    billyray3110 New Member
    Billy
    2006 Tundra Limited Double Cab
  8. Aug 19, 2019 at 4:00 PM
    Are you wanting the halogen headlights or the LED headlights?
  9. Aug 19, 2019 at 5:18 PM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    The trd pro headlights before 2018 are just blacked out in the inner part. Fit will be good for all tundras 14+, however if you get the 18+ they all have some for of led drl and you will need a wiring harness adapter to use thread headlights properly.
