Need help in my truck. All alerts light went on
Discussion in '2.5 Gen Tundras (2014-2021)' started by thanhnike, Jun 25, 2019.
  1. Jun 25, 2019 at 7:05 PM
    thanhnike
    thanhnike [OP] New Member
    2018 Tundra platinum
    I was driving home from work today and suddenly all the alerts light pop up on my 18 tundra platinum lifted.
    All the alert lights went on.
    I brought it to the dealership immediately but the light went off before they see it. But I have the video of it and shown to the service man there. He told me because The truck lifted.and he not gonna do anything because it is lifted. Is it right? Please help what issues is it .got the pictures below
    Blind spot malfunction
    Pre collision malfunction
    ABS
    4hi/lo keep blinking
    I couldn’t up load the video
    Sorry for my broken English but I think you guys know what is the problem is. Thanks
  2. Jun 25, 2019 at 7:11 PM
    sstoddard
    sstoddard New Member
    Shawn
    2019 Crewmax Sport
    Alarm/start (Compustar Ft7000,Rf2wl1b 2-way remotes and Drone Mobile) Tailgate inserts NSV Lightbar Tailgate actuator Blacked out decals
    Tell them the Magnuson Moss act states just because you put aftermarket stuff on your truck doesn't mean it voids the warranty. It's a federal law if they want to push the issue. Plus they have to prove that your lift caused your issue. I can guarantee there is no code for lifted truck. I would also find another dealer to take it to.
    Metro14536, Upgrayedd, 1UPPER and 4 others like this.
  3. Jun 26, 2019 at 1:27 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Did you buy it with the lift on it?
  4. Jun 26, 2019 at 1:31 PM
    Fireace
    Fireace New Member
    Oregon
    2018 Crewmax SR5 CM
    BAmuffler Pro Comp 6” lift ADD bumper Smittybilt 10k winch
    thanhnike[OP] and Black Wolf like this.
  5. Jun 26, 2019 at 6:28 PM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
  6. Jun 26, 2019 at 6:50 PM
    InfernoTundra
    InfernoTundra New Member
    Not sure if the Tundras are the same but my wife's Subaru will do that if the gas cap is not on all the way.
  7. Jun 26, 2019 at 10:42 PM
    Fireace
    Fireace New Member
    Oregon
    2018 Crewmax SR5 CM
    Mine was well below 14k when it happened. Yes I had the dealership do the lift for things just like this.
  8. Jun 27, 2019 at 5:56 AM
    jdmek998
    jdmek998 New Member
    2021 Tundra Platinum
    Might be a low voltage issue. have your battery checked out. I know when my battery was going bad in BMW it would do things like that randomly.
  9. Jun 27, 2019 at 6:02 AM
    Mnorris1206
    08 tundra
    Maybe abs sensor wire got broken ? When lift was put on
    dgtulsaguy likes this.
  10. Jun 27, 2019 at 6:08 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    For sure take it to another dealership and ask to have the codes ran through the OBD2 plug.
    No way a lift will cause issues like you are seeing.
    I just had a CV boot grenade itself and the dealer was obligated to prove my lift caused the issue, but they could not so, boot fixed under warranty.
    You'll be OK.
  11. Jun 27, 2019 at 10:59 AM
    thanhnike
    Yes. I did. But it was sold at the ford dealership
  12. Jun 27, 2019 at 11:12 AM
    thanhnike
    I bought it from a ford dealership with 6k miles on it. I think so too after a long research
    I bought like that from a ford dealership with 6k miles on it. It’s keep pop up when I drive a long distance. Called the dealership and they said they can’t do anything unless I bring the truck in with the lights on. So I let the truck ran for 3 hours but it’s not pop up. I guess it’s only pop up when I drive a long distance home from work at night. But I am too busy during the day to drive it
  13. Jun 27, 2019 at 11:29 AM
    Mnorris1206
    08 tundra
    The only reason why I thought of that is because I broke mine while putting a level kit on a few yrs back and all the same lights came on. But I'm no professional. lol
  14. Jun 27, 2019 at 12:28 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    Take it to a reputable Toyota dealership and ask them to run a diagnostic on the computer and ask them to run the codes.
    The ECU should store the error code for a while .
  15. Jun 28, 2019 at 1:20 PM
    mrkastni
    mrkastni New Member
    Michael
    South Dakota
    2018 Limited CM Blazing Blue
    Mine had the exact issue with every light on the dash come on about a week after I bought it. Dealer said they found it was a broken wire near the left front wheel. (Maybe ABS). They claimed it was likely a rodent or something chewed it, and wanted to charge me $400. I of course put up a bit of a disagreement being under a week old and never even off pavement. They replaced the wire under the sales department budget, not warranty.
    thanhnike[OP] and Mnorris1206 like this.
  16. Jun 28, 2019 at 3:30 PM
    thanhnike
    I went to a different dealership today. And they still couldn’t find the issue what is wrong with it. They ran the diagnostic but still no code. And told me when the light come on again leave the truck running and drive straight to them.
  17. Jun 28, 2019 at 3:33 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
    If not a broken wire like suggested above, check your battery ground. My Silverado did some funny stuff when the negative battery cable went bad. Corrosion in the fittings or something along those lines.
    thanhnike[OP] likes this.
  18. Jul 2, 2019 at 5:05 PM
    thanhnike
    I checked and greased the battery. Still pop on again. And I ran for the diagnosed again. Still no code
  19. Jul 3, 2019 at 3:09 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    In my case, it wasn't the connection between cable and battery. It was corrosion between the cable and fittings. Not sure that this is your issue, though.
    thanhnike[QUOTED][OP] likes this.
  20. Jul 3, 2019 at 5:41 PM
    thanhnike
    I checked,cleaned and greased the battery. Still come back on. Sucks
  21. Jul 3, 2019 at 6:15 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Maybe that was the reason why it was for sale lifted and used at a ford dealership.
  22. Jul 3, 2019 at 7:02 PM
    thanhnike
    Ive been driving it 7 months with nothing happened. The lights suddenly pop up when it turned to 14k miles.
  23. Jul 3, 2019 at 8:22 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    2019 Silver Sky Platinum Crew Max
    Bed Rug, Tonneau cover, Window visors, Console organizer, Weather Tech's
    Do you have the hypertech speedo re-calibrater? I see other people have asked you that. When those things fail all the lights come on. I have a 15 and it happened to me within 6 months of it being installed. No check engine light I don't think, and if I remember right it won't throw a code either. It basically just filters what the truck is trying to send to the dash. Since the ECU doesn't have an error you won't get one.
  24. Jul 4, 2019 at 4:59 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Good point. Since it is used the only way to know would be to pull the instrument panel.
