Need help identifying this
Discussion in 'General Tundra Discussion' started by Kerch71, Mar 15, 2020.
  1. Mar 15, 2020 at 9:07 AM
    Kerch71
    Kerch71 [OP] Surgical Precision
    Mechanicsville VA
    Just took a trip, did some off roading. When I got home I noticed something leaking/dripping under my truck. Put a container under it to catch some of the fluid. The drip was coming from the two bolts on the pan in the pictures. Fluid had the viscosity of water and no real odor or color. First of all, what is this pan that's bolted under the transmission? Any ideas what this leak would be? The bottom of the first pic is the front of the truck. Appreciate any input. It may just be water, just not sure why it was only coming from these two bolts. I tightened all of the bolts on this pan. It's no longer leaking. Just puzzled.
  2. Mar 15, 2020 at 9:10 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    It is condensation from the air conditioning system. Nothing to worry about.
    The drain for the evaporator is right above the transmission.
  3. Mar 15, 2020 at 9:12 AM
    Kerch71
    Mechanicsville VA
    I wondered if that's what it was. Just haven't run the air conditioner, only the heater. May be a stupid question, but will you get condensation from running the heater? Just never noticed it before.
    NewImprovedRon likes this.
  4. Mar 15, 2020 at 9:12 AM
    johnnyskullface
    johnnyskullface New Member
    Beaverton, Oregon
    2018 White Tundra Limited Crewmax
    That’s your transmission pan. I don’t know where the drain tube for the ac system is on those, but it was probably just evaporator moisture from the ac system. Transmission fluid should be red to brown depending on how old it is. Every fluid in the car should have a slick feeling between your fingers and some sort of odor. If it felt and smelled like water it probably was.
    NewImprovedRon and Kerch71[OP] like this.
  5. Mar 15, 2020 at 9:18 AM
    Kerch71
    Mechanicsville VA
    Right on. That puts me at ease. Just put a new tranny in this thing for an ungodly amount of money, so I got a little on edge when I saw leaking. Much appreciated.
  6. Mar 15, 2020 at 9:33 AM
    ViktorG
    Viktor
    Calgary, Canada
    Your a/c compressor may turn on automatically even when there is no demand for cold air.
  7. Mar 15, 2020 at 10:03 AM
    ezdog
    ezdog New Member
    Gateway To The West
    And for Defrost which is the season we are in here right now!
  8. Mar 15, 2020 at 5:22 PM
    Kerch71
    Mechanicsville VA
    10-4. Appreciate the help!
