Need help identifying this ...
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ps1stoy18, Nov 18, 2019.
  1. Nov 18, 2019 at 7:02 PM
    Ps1stoy18
    Ps1stoy18 [OP] New Member
    Abilene, TX
    2018 Toyota Tundra
    My 2018 has oil leaking from center of tailgate and ponding on the bumper...has anyone had this issue before?
  2. Nov 18, 2019 at 7:13 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    You got me
  3. Nov 18, 2019 at 7:20 PM
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  4. Nov 18, 2019 at 7:23 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    I know...she be bleeding. Really odd cuz I did not know the tailgate had fluid in it in the first place.
  5. Nov 18, 2019 at 7:25 PM
    Has it been cold enough for ice, and then warm enough to melt it? What color is it?
    Odor?
  6. Nov 18, 2019 at 7:25 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Mine did that although not that bad, after I generously sprayed the tailgate latch with silicone spray.
  7. Nov 18, 2019 at 7:35 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    It was in the upper 70s today, no ice at any point in time. The oily liquid is clear like water but it feels like baby oil...doesnt really have a smell either. It was not like this earlier like about 5:30pm (that's when I loaded groceries in back)..I would definitely had noticed. I thought my jugs of water had ruptured on way home but..nope, not the case.
  8. Nov 18, 2019 at 7:36 PM
    Marty McFly
    Morty McBoonJug
    Maybe you struck Texas gold in your truck :notsure:
    but seriously, what da f*ck :confused:
    GODZILLA and HappyGilmore like this.
  9. Nov 18, 2019 at 7:38 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Mine does this when it gets around 78 degrees outside.
  10. Nov 18, 2019 at 7:41 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I've spilled oil on my tail gate on other trucks and forgot about it. I just wiped up the visible oil and shut the gate. Days later it looked similar to that because it ran into every damn crevice.
    You didn't install any sound deadener or anything in the tailgate?
    Marty McFly likes this.
  11. Nov 18, 2019 at 7:42 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    It saw a boy tundra in the parking lot
    Yzed608 likes this.
  12. Nov 18, 2019 at 7:43 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    I have been having locking issues with it..as in..it will lock, sometimes the whole truck will lock by itself but the tailgate will not unlock using the fob..I have to use the key to unlock it. I tried taking it to Toyota dealer after it did that the first time..but got the usual "little lady" treatment like I was imagining it cuz they couldn't duplicate problem.
  13. Nov 18, 2019 at 7:43 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    seems plausible
  14. Nov 18, 2019 at 7:45 PM
  15. Nov 18, 2019 at 7:46 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    No sound deadening needed, I usually make sure they are completely knocked out before putting in the back .
    Haven't installed anything and if this is the result..I wont be anytime soon!
    Seyc, Borador and HappyGilmore like this.
  16. Nov 18, 2019 at 7:46 PM
    Mr Badwrench
    Mr Badwrench New Member
    Are you the original owner?
  17. Nov 18, 2019 at 7:47 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Did you install a pop-n-lock or did the truck come with one? Maybe the lock actuator blew up.
  18. Nov 18, 2019 at 7:47 PM
    HappyGilmore
    Trent
    Lakewood CA
    If it has a power lock actuator in the tailgate, it is dealer installed. Or you had it installed after purchase. Did the dealer lube it when you brought it to them? They may have done a careless job with silicone spray as suggested above and got it all over.
    I installed one on mine and it looked like it could hang up easy if it got dry. I greased it well and it's been fine.
  19. Nov 18, 2019 at 7:48 PM
    HappyGilmore
    Trent
    Lakewood CA
  20. Nov 18, 2019 at 7:49 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    The truck came with the locking gate..
  21. Nov 18, 2019 at 7:49 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    And yes, original owner
  22. Nov 18, 2019 at 7:50 PM
    HappyGilmore
    Trent
    Lakewood CA
    My only guess is a careless lube job when you brought it back with the intermittent problem.
    Seyc likes this.
  23. Nov 18, 2019 at 7:50 PM
    roypark
    roypark Semi-pro High Fiver
    Roy
    Orange County
    2016 Tundra
    A little of this and a little of that. Its pretty run of the mill.
    Pretty sure that is the rear blinker fluid. When mine leaked, it did that. Just go to autozone and ask for DOT4 blinker fluid. Should be fine.
  24. Nov 18, 2019 at 7:53 PM
    Mr Badwrench
    I would bet something oily was spilled in the bed and washed out with a pressure washer at some point and it made its way into the tailgate beneath that cover.
  25. Nov 18, 2019 at 7:53 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    And did you wear a dress and heels when you went and bought "blinker fluid"?
    Seyc, Tundra Fan and T-Rex266 like this.
  26. Nov 18, 2019 at 7:55 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    Like an alien encounter?! My truck hasn't been going out without me behind the wheel...I am 100% sure I didn't do that....ever.
    Primalbryan likes this.
  27. Nov 18, 2019 at 7:57 PM
    HappyGilmore
    Trent
    Lakewood CA
    :eek:
    Seyc and Marty McFly like this.
  28. Nov 18, 2019 at 7:59 PM
    Mr Badwrench
    Was the bed liner installed before you bought it?
  29. Nov 18, 2019 at 8:00 PM
    Ps1stoy18
    Abilene, TX
    2018 Toyota Tundra
    It was powder coated at dealership before I bought it.
  30. Nov 18, 2019 at 8:01 PM
    Mr Badwrench
    That's not powder coat. No clue. Good luck.
